Diagram tv sanyo cg29ys2
Kerusakan regulator
What is the regulator of sanyo crt tv model st-21g1
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
Circuit diagrams of many popular brand TVs and other devices are given.
Nov 22, 2016 | Sanyo Televison & Video
My sanyo tv won't turn on
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 23, 2014 | Sanyo Televison & Video
Sanyo LCD 32XR8DA i cant turn the tv on by remote or by pressing the button on top of the tv
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jun 26, 2014 | Televison & Video
Sanyo crt tv model st-21cf1 all burned resistor....may i ask what is the value of resistors
To which section circuit you are referring here? Power supply regulator section? If you wish to get some information, check the link below. It has schematic diagrams to Power Supply Regulator sections to some popular brand TVs. http://electronicshelponline.blogspot.com/
Nov 12, 2013 | Televison & Video
On a Sanyo Vizon HD TV where is the headphone jack?
Panasonic handle Sanyo TV Support now, Here are their contact numbers: Repair:-0871 3321711
Product Help:-
0844 335 2230
Apr 04, 2013 | Sanyo VIZON Multisystem 42" LCD TV 110-220...
Sanyo model 42848 tv parts diagram
Download its service manual. Try this link to download it.
Jun 06, 2012 | Sanyo Televison & Video
Schematic diagram for sanyo tv AVM-2979P
Only two choices here aside from Google the model number with "service manual" is to contact Sanyo or look to see if the set is covered by a Howard W. Sams photofact manual.
May 15, 2012 | Sanyo AVM-2509S TV
Sanyo 42 inch tv model number dp47460 turns off after a half hour
Hello
Check its power regulator board's soldering points for any loose solderings. Resolder all the suspected solder points by applying a little more solder.
Mar 05, 2012 | Sanyo 42 in. LCD TV
TV saya Toshiba Regza 32 " flat, suatu hari
Hallo,
Setahu saya , penggantian transistor pada model-model LCD atau plasma jarang di lakukan, karena beresiko kerusakan komponen yang lain. Jika memang mau melakukan penggantian part , sebaiknya di pastikan dulu kerusakan penyebab rusaknya transistor tsb. jika yakin tidak ada yang rusak, transistor seperti model apa yang kamu cari bisa di cari di internet.
Atau tulis no part nya , mungkin saya bisa bantu.
Terima kasih.
Mar 21, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
