Question about Hunter Dryers
Receiver 85112-04 I am intended to get rid of the 85112 receiver and put jumper(s) in the connector to hard-wire the fan at med speed. Anybody knows witch pins to be connected?
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
  • 75 Answers
SOURCE: Color code for 4-pin Cobra M75 CB Mic
here is the link that i used
hope it helps
http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=8197
Posted on Jul 03, 2009
SOURCE: i have a westinghouse three speed fan. there are 4
ok. hope this helps, use a switch from FANTEC. it'll be called a 3 speed fan switch. CAM #5 No. 21105. this will also say Single Layer 3 or 4 wire application SPLIT continuity function.. THE SPLIT PART IS VITAL. now when wire it. the BLACK wire goes in SLOT 3. ORANGE wire goes in L. PURPLE wire goes in slot 2, ORANGE wire goes in slot 1. IF, and i repeat IF this does not work for you ensure you have a SPLIT CONTINUITY FUNCTION switch. NO MATTER WHAT the BLACK wire WILL go into slot 3. the ORANGE wire WILL go in slot L. switch the orange and purple wires only. ENSURE POWER IS OFF WHEN CONNECTING OR DISCONNECTING WIRES. YOU WILL GET THE SNOT ZAPPED OUTTA YOU IF YOU DON'T. please post if this helps.
Posted on Aug 04, 2009
  • 69 Answers
SOURCE: 920-fan command 2 pin connector from power supply not connected
then connect the fan to a 2-pin connecter if you cant do it take it to a computer place to do it for you
Posted on Sep 24, 2009
  • 2226 Answers
SOURCE: need dell gx280 tower CPU fan pinout (5-pin connector)
dell has web download manual jim
Posted on Mar 24, 2010
How to check fan blower switch I need diagram of the switch
id find blower motor and hit it with a hammer if it turn on its bad also look at the wire to the resistor they melt down if its bad put new connector and resistor in iv done a few
Mar 04, 2015 | 2005 Chevrolet Silverado
I'm working on a 93 escort and have no dash lights or heater fan. All other lights work Anyone have a fix?
ok under the hood were the blower motor is, or under the dash were over it may be there is a resistor there has 2 screws holding it in pace with a plug should have 4 or 5 wires on it with a test light or mult meter test for power there if you have power at the red wire the other 3 wires one is your low speed the other is med speed the 3rd id hi speed test them for power, you will need to turn your speed switch from low to med then hi to see volts there if you have power at one and not the others unplug it and put a jumper wire in there and you fan should work on what ever speed wire you have it in and if it work on all 3 speed by installing a jumper you will need to replace the resistor there a round 20 bucks .....
May 23, 2014 | 1993 Ford Escort 4 Door
Ceiling fan not wirking on Hi.
Check the brushes driving the solenoid,they may have worn out
Nov 12, 2013 | Dryers
Furnace transformer/fan-relay wiring to fan-motor
All you need is 2 fan speeds, 1 for cool and 1 for heat. Leave the low speed disconnected. Normally we have high speed for cooling, and med. or low for heat. So either speed connected to the heating circuit is fine.
Apr 12, 2017 | Heating & Cooling
I need a basic wiring diagram for a 3spd, 3 wire capacitor ceiling fan with reverse slide DPDT switch. The rotary pull chain switch was removed along with the cap, so i do not know how to put a new switch...
Try L-BLACK 1-GRAY 2-BROWN 3-PURPLE. IF THIS COMBO DOESN'T WORK. BLACK WIRE GOES TO L , 123 IS YOUR SPEEDS YOU WILL HAVE HOOK THEM UP BY PROCESS OF ELIMINATION FIGURE OUT WHICH IS HIGH MED & LOW. IT SHOULD BE 1-HIGH 2-MED 3-LOW.
Jul 24, 2010 | Hampton Bay Dryers
How do I change the heater fan speed control in a Jeep Liberty (2006)? Speeds 1-2 and 3 don't work, only 4 does.
On the back of the control panel there is a plastic connector that plugs into the fan speed control. You can unplug it and use a meter to find incoming (hotwire) take a jumper or a 6 inch peice of wire and insert it into the spade where the hot wire is wired to. Take the other end of the wire and insert it into the 1st spade in the plastic connector next to the hot wire spade this will let you know that the fan will run at the selected speed. Then pull the test wire out and plug it into the next spade and so on and so on. I am sure your fan will respond step by step , fan speed 1 then 2 and then 3. After you make this test you will know that your fan is ok. You will just have to replace the plastic connector with new spades in it. You should see some evidence of over heating on the old connector. It may be that you only need to unsnap the connector and then reconnet it and it will probably work fine. It has proberly just become partially unpluged. All the other info that I gave you early on was just to trouble shoot it. mike
micmor68@gmail.com
Oct 12, 2009 | 2006 Jeep Liberty
I ahve a 2003 vw beetle turbo with dual electric
4 wire likely a 3 speed fan you should be able to conect the medium and low circut to a set of releys and hook them both to the low speed side of the fan
allowing the low and med speed to work on low and the high speed to work properly
Aug 06, 2009 | 2003 Volkswagen Beetle TDI
2004 PT Cruiser radiator fan comes on in high speed mode when AND
You can either jump power from the high to low sides, or wire a switchable power wire so it comes on when the ignition turns on. It isn't really computer controlled. A sensor just sends power to it when it needs to run. No fear of hurting anything.
Jul 01, 2009 | 2004 Chrysler PT Cruiser
Need to replace the switch that has ,hi,low,med off on nit? please Help
you have 3 control wires (the 3 speeds) and a common wire. the common wire will go directly from the fan motor to the power source/cord and the other 3 leads will run through the switch. you could even use a standard dimmer-style lighting rheostat and connect it to the common and "high" fan speed wire and have infinitely variable fan speeds. hope that helps.
Apr 30, 2009 | Lakewood HV-18 Floor / Box Fan
Blower speed
Yes usually the black is high speed, the blue is low and red medium speed. plug the black wire from the fan motor to where the blue wire is, then put the blue where the black wire was
Jan 10, 2009 | Intertherm P3RA-048K Air Conditioner
Dryers Logo
20 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
