Question about Dryers
Coils DBVH512GF0WW
Trying to find where they are located
Wheres the spark plugs in a holden astra 2001
its on the top of ur valve cover under the powerpack or so called one piece coil take the coil assy and you will see your spark plugs
May 06, 2014 | Holden Astra Cars & Trucks
Need to find the coil wire that affects all the coils
either check with the manufacurer of the tach or a parts store because if you connect this to the wrong wire, you will get a no fire in the coil array..besides I think you only need one anyway..
Dec 21, 2013 | 2000 Mercury Grand Marquis
Where is the coil pack located on a 2000 saturn ls
It is bolted directly over the spark plugs on the 4 cylinder engine.
See picture below.
Aug 23, 2012 | 2000 Saturn Ls 4dr Sedan
The compressor is trying to come on but will not. Where are the coils located at so I can clean them?
THE CONDENSER COILS ARE AT THE BACK BY THE COMPRESSOR, PULL THE FRIDGE OUT ANT TAKE THE BOTTOMPANEL OFF , YOU WILL SEE THE COILS.its VERY IMPORTANT TO KEEP THE COILS CLEAN
AND
If you have an air compressor, that would work but awful dusty, It is where the fan is located, The probem could be frost on the freezer coils , check the freezer coils as well
Jul 22, 2012 | Hotpoint Refrigerators
MAZDA CX-9 P0354 CODE
Cylinder 4. Each cylinder has it's own coil above the sparkplug.
If you have a misfire, it's probably a bad coil. But if it's an intermittent misfire, it may be the wiring to the coil. If it's intermittent, start the car and wiggle the wires to that coil. If you cause a misfire you need to check the wiring to the coil.
Goode luck.
Nov 29, 2011 | 2008 Mazda Cx 9
Trying to find out if 2000 Mercury Sable 3.0 ODHC has coil pack or individual coils ... and how to test / locate ... car sometimes hesitates and stutters
f a coil pack, you will have 6 spark plug wires coming out of a coil pack.
If individual, you will have no psark plug wire but a coil mounted above each spark plug
Aug 10, 2011 | 2000 Mercury Sable
Trying to locate the coil packs
Usually the coil pack is directly on top of the engines intake. Later model SOHC engines had the coil pack on the back of the intake on the passengers side of the throttle body. All DOHC models have coil over plug systems and the coil is mounted on the valve cover and connects directly to the spark plug and is held in with a 12mm bolt and a black or white connector depending on the location of the coil. I hope this info helps.
Jul 26, 2011 | Subaru Impreza Cars & Trucks
First refrigerator stopped cooling, next freezer. Seemed like it was trying to defrost but their was lots of ice built up on coils. Jen-Air side by side, counter depth model number JCB2388ARB.
Causes of ice build up on coils:
Not enough freon (leak). Coil defrost heater not working (Coils on all freezers freeze up, but you should not notice). Coil defrost timer not working. Compressor thermostat not working (or end fell out of proper location).
:o).
Jun 04, 2011 | Jenn-Air JCB2388G Side by Side...
Misfire in # 2 cyclinder trying to locate
Driver side first cylinder.
Driver Passanger
FRONT
2 1
4 3
6 5
Jul 02, 2010 | 2004 Nissan Maxima
Location to bracket on or mount the ignition coil on 93 accord
i beleive it was up on or around the intake manifold.above the dist or near there...89 accord mount is on the strut tower area...
May 08, 2009 | 1993 Honda Accord
Dryers Logo
Top Dryers Experts
