CAIUS TV STAND
MY QUESTION IS I CURRENTLY HAVE THE POST ATTACHED TO THE TV STAND AS SHOWN IN STEP 10 OF THE MANUAL WHICH IS WITH THE BOTTOM OF THE POST RESTING ON THE FLOOR I NEED MORE CLEARANCE BETWEEN THE BOTTOM OF THE TV AND THE TOP SHELF OF THE STAND THE POST HAS ADDITIONAL HOLES SET UP AS IF YOU CAN MOUNT THE POST HIGHER IF NEEDED WHICH MEANS THE BOTTOM OF THE POST WILL NO LONGER BE TOUCHING THE FLOOR AND ALSO ONLY FOUR BOLTS ATTACHING THE POST WILL THIS WORK ?? THANKS IN ADVANCE RICHARD
sreekidu
  • 60 Answers
SOURCE: How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Posted on Jul 16, 2007
SOURCE: Removing bottom stand Flat Panel LCD Magnavox 32MF605W 32
There are 4 shiny screws at the back of TV just above the stand neck. Unscrew those 4 scrws and then lift the TV up, stand will come out.
Posted on May 21, 2008
SOURCE: Base Detachment
If you lay the TV down on something soft but firm (towel on the floor or counter) put the screen face down on the back you should see 4 screw holes with the an (S) next to them. They are located at the center near the bottom. If you remove these screws the stand should then slide out of the bottom of the TV. Good Luck
Posted on Jul 13, 2008
  • 11 Answers
I have the same TV, and I bought a mount with 4 connector holes. I was able to connect 3 of the 4 and it has been fine as the TV does not weigh too much. The TV was not designed with the current mode of either wall or stand mount. It was just intended for stand. I have had it on the wall for over 2 years.
Posted on Jan 02, 2010
  • 102 Answers
SOURCE: i need a table top tv stand for my sony kdl
hi here is a link to the stand for your tv at sony parts store >
http://www.partstore.com/Part/Sony/Sony/KDL40W3000/Sony/Sony/A1257997A/New.aspx
please dont forget to rate me i need a few more for my badge thank you and if you need anymore help let me know..
Posted on Feb 04, 2010
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
Jan 08, 2015 | Samsung Televison & Video
Having changed my current account provider, how do I attach the standing order list to the new account without deleting the quicken records for the old account?
At the bottom of the window for each account under cash flow there is a heading "Bills and Standing Orders".
This allows you to plot direct debits, standing orders and regular bills which are then automatically entered into the account data according to the date they are due.
I have changed by current account provider, maintaining for the moment, the previous account details and starting a separate current account for my new provider.
I want to know how I can switch the list from the old account to the new one because when I have the new account window open and then open the Bills and standing order page it is blank and the Standing orders etc. are still being shown in the old account. For more help and support http://support.quickbooks.intuit.com/support/ and need guidance on any other issue follow Intuit Tech Support .
Jul 19, 2014 | Intuit Quicken Basic 2000 Full Version for...
How to assemble tv stand
To know more about this, you have to download the repair manual to this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 10, 2014 | Samsung LN32C540 32 in. LCD TV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
The plastic stand that is attached to the TV bottom, how do I remove it so I can mount the TV on the wall?
Click Sony Support link to download instruction manual about how to remove stand from KDL-V40XBR1 tv.
Hope this will help you.
Thanks.
Jan 28, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Fot to take stand off the bottom
Here is the link to the LG website with your tv 's manual and instructions:
Download it by clicking on the highlighted word ENGLISH beside the OWNER'S MANUAL label.
http://www.lg.com/ca_en/support/product/support-product-profile.jsp?customerModelCode=42LC2D&matchedModelCode=NOT_MATCHED&searchEngineModelCode=42LC2D&initialTab=documents&targetPage=support-product-profile
Follow instructions as on page 7 of that manual:
Carefully place the product screen side down on a
cushioned surface that will protect product and
screen from damage.
Remove the 4 bolts provided securely, in the back of the
product.
Unhook of the stand in the back of the
product as shown.
Good luck and post back if this helps.
Jan 25, 2011 | LG 42LC2D 42 in. LCD HDTV
Need to remove stand from small Polariod TV
When you remove the bottom of the stand the silver plastic oval will remain attached to the TV, look in the bottom of it, you will see a small screw, remove it and slide the silver plastic piece to the left and remove it.
Thats it
Nov 19, 2009 | Polaroid TLA-01511C 15 in. LCD Television
What is the ''cover bottom'' plate for?
Dont know this exact model, but I own a Samsung and so does my father so this proably applies:
The cover plate is supplied for use when the TV is wall mounted using a VESA mount secured to the four holes on the back of the TV. When wall mounted, the normal stand is removed and this leaves a bit of an unsightly "hole" in the case at the bottom. The cover you mention is then secured in place of the stand to make the bottom of the TV nice and neat.
You may find there was a separate leaflet in the box the TV came in detailing this aspect, which is why it isnt mentioned in the manual.
Oct 01, 2009 | Televison & Video
How to remove tv stand from toshiba 42 inch lcd model 42hl167
Remove 5 screws as shown in below image to remove stand of TV.
It is also mentioned in user manual of TV page-5, click Toshiba Support to download a copy, if required.
Thanks.
Aug 30, 2009 | Televison & Video
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
