Question about iRiver PMC-120 Digital Media Player
My iriver pmc won't switch off
I can't switch off my iriver. I wanted to remove the device safely but couldn't so I pulled the usb port off my comp and now it won't switch off or reset even though I've pressed the off button several times
  • 594 Answers
Make sure the hold button on the bottom is showing white, not red (locked) if that doesn't work, just pop the battery off and put it back in.
Posted on Feb 09, 2008
6ya staff
SOURCE:
My laptop does the "found new hardware, mtp device" popup, but doesn't recognize it as iRiver
Here's the link for the user manual if you need it; http://www.iriveramerica.com/download/pmc/PMC-100.pdf check page 137 of the pdf and try the restore to original settings. do you have the setup cd? - it has troubleshooting for the unit, which is not available on the website there are no drivers available, it uses windows media player as a driver, but the manual and the support site; http://www.iriveramerica.com/support/multi/pmc100_faq.aspx both claim that you need windows media player 10, not 11 to synchronise. you can download it from this link; http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx or install it from the setup cd just uninstall wmp11 first. many of this type of unit and mp3 players etc have problems with wmp 11, hopefully reverting to 10 will allow you to sync Hope this helps :)
Jun 27, 2007 | iRiver PMC-120 Digital Media Player
IRIVER E100 stuck. Display "USB
Take out the batteries and hold power button for ten seconds. Replace batteries and see if anythings changed. If not, then plug it into a computers USB port and then hold the power button for ten seconds. Safely Remove from the USB port and then check again. If none of these work, you just have a malfunctioned device and it may cost more to fix it.
Good Luck,
FV
Mar 10, 2011 | Cameras
Does not open the iriver E10
  1. If your PC does recognize the iRiver as a USB device/drive, there is an issue with the Hard Drive.
  2. If your computer doesn't recognize the iRiver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
  3. Turn the lock off and connect it to the usb port and press the reset button (small hole in lower left of unit, use a small object like a paperclip. The screen should change eventually to the "USB connected" screen. Disconnect the USB at the PC to get the "Ok to disconnect" message. Pull out the usb cable and hold down the "off" button. Eventually the unit will turn off. Turn it on and then off to verify it is working.
If nothing works, your iRiver needs to be returned to the manufacturer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 22, 2011 | iRiver E10 Digital Media Player
I have a iriver spinn mp3 and i dont know how to to put music on it can you help me
Sure, connect to your computer via proprietary USB cable that comes with the device. Your computer should automatically recognize the new Spinn device. Software is also included in order to manage music, video, & ebooks (text files). Install Iriver Plus 3. Perform media search on your computer. Select files you want to put on your Spinn. Then transfer to your device. Make sure eject your device for safe removal. Thats it.
Nov 19, 2009 | Audio Players & Recorders
How can i get this iriver pmc-120(20GB)Digital media player
Ebay have them at around $300-350 +p&p.
http://cgi.ebay.co.uk/iRiver-PMC-120-20-GB-5000-Songs-MP3-Player_W0QQitemZ9709194994QQihZ001QQcategoryZ114622QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
http://cgi.ebay.co.uk/iRiver-PMC-120-MP3-Player-20GB-widescreen-MP4-PMC120_W0QQitemZ120206957789QQihZ002QQcategoryZ114622QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
Hope this helps,
erch.
Mar 15, 2008 | Televison & Video
Pulling music file from pmc120 to computer
look at it via explorer in windows, (my computer, K drive or whatever the iriver comes up as) there will be some folders in it and the music should be in there.
Jan 12, 2008 | iRiver PMC-120 Digital Media Player
Greatful if you can help me
i have a pmc with bad logic board. I want a logic board to fix mine. But I can sell u my screen.
Dec 09, 2007 | iRiver PMC-120 Digital Media Player
Open Questions:
pmc 120 when i set up a sync list on media player and start to sync it to the pmc, it works sometimes, other times it aborts. it gives me the message "you can now disconnect iriver Portable media centre" when i try to do it again it tell me Windows Media Player encountered a problem while synchronizing the file to the device. For additional assistance, click Web Help. when i go to th web help it explains the problem as You've encountered error message C00D1236 while using Windows Media Player. The following information might help you troubleshoot the issue. Cannot sync the file Windows Media Player encountered a problem while synchronizing the file to the portable device. Because this error can occur for a variety of reasons, there is no single solution. To resolve the problem, try disconnecting and resetting the device. See your device owner's manual for specific instructions on performing this procedure. In some cases, this error can occur if you try to sync a hidden file to a device. To resolve this problem, either remove the file from the sync list or change the file's properties so that the file is not hidden. Also the error details are Technical Details This error might have been triggered by an error in another program or component of Windows. The following information describes the original error. Original Error Code Original Error Message C00D1179Windows Media Player does not detect a portable device. Connect your portable device, and then try again. So im not sure why it keeps aborting. if you can tell me your views on this please do. Other information that may be useful i tried formatting the unit : 1. Through windows media player 2. through explorer the pmc is supposed to be used with windows media player 10. i had wmp 11 originally and it didnt really work too well. i rolled back to 10 and it worked better but still not consistantly. i tried installing wmp11 again and now the Pmc120 will abort after about 3 songs of an album i would have setup to sync. thanks for your help. Gavan Doran. Ireland.
Oct 16, 2007 | iRiver PMC-120 Digital Media Player
iRiver PMC-120 Digital Media Player Logo
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
