Question about Refrigerators
STR10TFPAW ANYBODY HAVE A PARTS MANUAL NEED TIMER NUMBER
I'm looking for the NEC NP3150 service manual. not the user manual. unit won't turn on due to overheat error code. isolated it to temperature sensor fail... not to true overheat issue... need to buy a...
I have the temperature sensor, I will send it to you ,if you need
the unit price is USD70 ,and the freight is about USD30
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 24, 2014 | NEC NP3150 Projector
I need the model number for the timer
here is maual for true t23F there is a number on top of manual for there parts department. http://www.truemfg.com/pdf/InstallManuals/T-SERIES/t_series_english.pdf
Apr 12, 2012 | True T23F Freezer
I NEED A PROGRAMING MANUAL FOR AN INTERMATIC TIMER, MODEL # ET70415CR
Here are all the ET7000 series manuals
Click product number and drop-down shows manual
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
Here is the ET70415CR manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et70415cr%20-%20english.ashx
This timer can be used for 120Volt or 208/240/277Volt circuits
The important thing is to install the 'voltage selector jumper' BEFORE connecting power
The jumper is supplied with timer
Oct 2010
If you need more help with specific parts of the manual, add a comment and I will respond
Oct 27, 2010 | Intermatic ET70415CR Electronic Energy...
I don't have an owners manual and want to know where I should set the freezer to avoid unnecessary ice build-up. Also is there a setting for defrost?
Click Here for your user manual=> MQU1556AEW.pdf The settings for defrost should come automatically every 12 hours. You may test the defrost timer that appears to be behind the kick plate at base and front bottom of refrigerator by removing the kick plate first and using a flathead screwdriver turn slowly clockwise until compressor stops. After a few minutes you should be able to hear a crackling noise or sizzle by opening the door and listening. Leave the timer like that for up to 35 minutes and if the freezer does not start on its own the the timer is not working properly and will need replaced. Click Here=> MQU1556AEW Unit parts number 15 in photo is defrost timer. The defrost timer is part number=> 4357124 Defrost Timer Check for air leaks around door seal as this will cause the same symptoms. If by chance the defrost timer works and the defrost does not then let me know here or here=> Appliance 911 The only other parts are the defrost heater number 16 in photo MQU1556AEW Unit Parts and part number for defrost heater is Click Here=> 8201749 If you change the defrost heater it is always good to replace the defrost thermostat number 18 in MQU1556AEW Unit Parts The defrost thermostat is part number=> 1-81801-001 The most likely problem is the defrost timer but I needed to cover every possibility. If you have questions please feel free to ask, Thanks, Sea Breeze
Oct 10, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Washer Doesnt Change Cycles
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This appears to be a timer / timer motor problem.
I'd alto look at the Whirlpool / Kenmore direct drive installation and maintenance manual for testing the timer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sep 26, 2009 | Kenmore 24032\24036 Top Load Washer
Fridge less and less cold. both sides. now totally not cold. defrost timer?new fridge
The parts manual on that refrigerator show a defrost timer inside the fresh food compartment behind the control panel. Need you to turn the timer clockwise with a flathead screwdriver slowly until the compressor stops. Leave it alone for 30 minutes and if it does not turn itself back on then we need to replace the timer. If not we need to unplug the refrigerator and remove the back panel inside the freezer. We will need to test the defrost heater and inspect the defrost thermostat. Let me know when you are ready. The part number for the timer is 68233-3
Item number 13 top right hand side of photo.
1acbff1.gif Let me know if I can help, Thanks Sea Breeze
SITE-> http://servicepartstec.blogspot.com/
Jun 18, 2009 | Maytag MSD2732GR Side by Side Refrigerator
I've got a pana inverter CS-E24FKR, and the timer icon is blinking. I have not set a timer and i can not get the unit to respond. I tried holding the "check" button down for 5 seconds, then...
This is a sign of a bad board. They are cheap and easy to replace. They will need to be replaced or you will continue to have this problem for as long as you own the unit
Jun 03, 2009 | Panasonic CW-1006FU Air Conditioner
User manual needed
Manufacturer's Phone Number may be 800-289-0980. Not sure if this is the manufacturer number, but it is the number listed on the Orion TVDVD092 box to call if you still have questions after reading the manual. I need a manual as well. I do hope that they will send me one.
Jan 02, 2008 | Orion TVDVD092 9 in. TV/DVD Combo
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
