Question about Holmes Products HPF650-U Stand (Pedestal) Fan
Parts I need a knob for the back of the fan the inside where the wires touch broke where can I find this part
Mazda protege 2001 how to open dash cover around stereo
The bezel is held in with spring clips. You can probably pull it off with your hands ger your fingernails under a corner and pull gently until they start to release. Then go round the edges pulling gently.
Oct 30, 2017 | Mazda Protege Cars & Trucks
I have a 2005 Ford Focus. My vent distribution knob turns freely but does not change air direction. It remains blowing from the defrost vents. I pooped off the face around the knobs and stereo to look...
The part you're describing is the blend door actuator. It diverts air through the different ports, (floor, vent, defrost, mix). The good news is depending on what you need (new lever or new blend door) the price runs about $30-40. As far as ease of installation, it sounds like you have unobstructed access so replacing it shouldn't be too difficult.
Jul 07, 2011 | 2005 Ford Focus
How do you open a wu pin switch. the chain broke & went inside switch
My chain was broken about 1.5 - 2 centimeters inside the wu pin. I took a chain connector (with some chain hanging off one end) and fed it into the hole, trying to connect it to the broken chain. After a couple of tries I managed to get the end of the broken chain inside the wu pin to connect to the chain connector by gently pulling down once it was somewhat inside the chain connector. I hope this works for you. I was so glad I didn't have to resort to cutting any wire or making a trip to a home improvement store!
Jun 13, 2011 | Westinghouse Electric Westinghouse...
What would cause a small electrical shock when touching the fan or light pull cords on ceiling fan, or even the metal parts of the fan? When you touch any part of the fan you get a slight tingle. We have...
You have a bad ground, be carefull this could lead to a big shock if there ae any bare wires in that Unit! I would turn off the power at the fuse box to this fan and remove it and check for bare wires inside the fan itself if you can. If you don't see any bad wires or any wires touching the fan itself, then I would check the ground wire to that unit! I suspect that it is not grounded!
Nov 23, 2010 | Dryers
Starter knob broke off. Need new one and instructions how to change. Or the number of a repair man in the Chambersburg PA area.
to repair yourself you will have to unplug, and remove top back plate. Label wires and there is a wiring diagram inside the top left corner folded. All you need to do is call a sales, service and repair shop and give them the make and model and the part needed. This way you will not have to take the part out until you have the new one then it is just a matter of replacing one wire at a time from old to new. Hope this helped Tim
Oct 16, 2010 | Dryers
Outside fan doesn't work. Inside it sounds like it works - there is a fan sound - but no cool air What part is broke?
If your compressor kicks on outside but the fan on top doesnt you need to ck the capacitor to the fan and the wiring to each. There is a schematic inside the elect panel on the outside unit it will give you an idea where the capacitor is it will be a silver or grey metal device with three wires coming out of it or you will have one small and one larger one with two wires coming out of each. the fan runs off a 5uf capacitor and the compressor a 35 uf capacitor. The most obviouse thing will be burnt or melted wires inside the elect panel when a capacitor goes bad it usually takes wiring with it. If wiring looks good buy a new motor and replace the capacitor at the same time. take the elect motor with you so it can be matched up.
Aug 08, 2010 | Ruud Matching Split Air Conditioner
The knob broke off. How do I fix it?
well if you broke only the knob, then thats an easy fix.. just obtain part # 154535903 - KNOB and replace.
however if you broke the shaft off inside the knob you will need to procure part # 154668901 - CONTROL MODULE
remove power from the dishwasher and remove the screws holding the inner door panel to the door.
once that is removed you should see the control assembly and related wire harness that needs to be disconnected and screws that need to be removed, etc..
hope that helps,
best of luck,
ttfn
Oct 19, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
A/C on/off ''Blower'' control knob (on left side) broke off
call your local auto parts salvage yard. You may have to buy the entire control assembly.
Check car-part.com for part and look at page with * for cheapest price.
Nov 17, 2008 | 2001 Oldsmobile Intrigue
Fan Switch broke off Jenn-Air CVE3400 Radiant Cooktop
I am wondering if you just need to replace the knob then perhaps you don't need to take much apart.
Is this a knob that has an allen screw in the side that unscrews to let it come off or is it a friction fit.
If the knob is so small that you can't get it off some times wrapping a thin rag around it gives you the way to tug it off. If it is the whole switch you are fixing then I see why you need to take lots of things apart. If found the installation manual online and that might give you a clue to how it is installed in the counter to take it back out if you need to get to the insides. I am not sure what you need help with so please let me know more if this was not enough.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=CVE340&siteCd=JA_EN_US
Dec 12, 2007 | Cooktops
Broken Knob for fan control
once you take off the front housing, the switch itself shoud be easy to remove and replace...sometimes, a used appliance store/repair office can get a suitable replacement part. Trick is to mark the wires as you remove them from the switch and take hte switch with you while you go part hunting. Also would help to have model and serial number (and brand name) noted to take along. Papdaddy
Sep 22, 2007 | Comfort-Aire CS-101A Air Conditioner
Holmes Products HPF650-U Stand (Pedestal) Fan Logo
24 people viewed this question
Top Holmes Products Dryers Experts
Jay Finke
Jay Finke
ray gallant
xkikbxr
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
