Question about iRiver H10 MP3 Player
Iriver wibt charge
When i charge my iriverm the red light on the charger comes on but when i turn on my iriver, the battery with the slash appears on the screen. i bought a new battery but the problem remains. can u help me?
  • 8,596 Answers
Make sure the battery is a compatible type, and is not inserted in the wrong direction
Posted on Jun 26, 2008
Ideas Arlec PS906 mobility chair charger. It's saying that battery's charged, only on with one red light when charger off, all lights on when charger attached. It turns on but lowest of power, Elaine
Hi again I'm a bit confused a PsS906 arlec charger is a 12 volt charger ??? Can u supply more information .cheers Hi when u turn charger on red ( led ) should come on / when connected to battery / red & yellow ,( led ) should b on /it's in charging mode /when green ,,( led ) turns on battery is charged.cheers
Dec 09, 2017 | Health & Beauty
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
Though my Worx WG781 cordless 36V, 19 inch lawn mower came with what appeared to be a fully charged battery according to the battery LED lights , it is suggested that it be put on the charger "over...
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
May 20, 2011 | Worx WG788 19Inch 36 Volt Cordless 3In1...
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
Apr 24, 2008 | Universal Battery Charger Charges Multiple...
Iriver pmp 120 use the wrong charger
try this. the iriver doesn't boot at times ( wrong charger or using the right charger abroad), unlatch the battery and hold down the power button for about 20 seconds. also reset the instrument. hopefully that might work for you.
Dec 30, 2007 | iRiver PMP-120 Digital Media Player
Iriver PMP-120 will not turn on
try connecting it to ur computer or restarting it
Sep 24, 2006 | iRiver PMP-120 Digital Media Player
Will not turn on
Howdy! Same thing happens to me after only a while of having it. iRiver were of very little help but I found my solstice in selling it to some other unfortunate person. I found if you charge it for a hour and then take out the charger, remove the battery and replace it, it will go. What a pain! Perhaps the battery drains out when it sits unused for a few days.
Sep 17, 2006 | iRiver PMC-120 Digital Media Player
IRiver iHP-140
Open the player and test for battery's voltage. In case of a low voltage measurement,you should replace the battery.I don't want to be cruel with you but, maybe that the player power circuit was damaged as well,and in this case it should be repaired by a certified technician (I realy hope for you that this is not the situation). Good luck !!!
May 23, 2006 | iRiver iHP-140 MP3 Player
iRiver H10 MP3 Player Logo
51 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
