Question about Mitsubishi WD-65000 65" Rear Projection Television
Reset power, power comes on and then gose off 4 seconds later.
How to factory reset marantz sr6006
Hope this helps: How to reset the SR6006
Microprocessor reset (p. 150 Owner's manual) - Press and hold the Zone Select/Display buttons while powering on the AVR ......release 4-5 seconds later
Network reset - Press and hold the M-Dax/Display buttons (resets network card and does a microprocessor reset)
Jul 17, 2014 | Marantz Audio Players & Recorders
Alarm light on #6 and 0 degrees blink alarm gose off every 24 hrs
reset the alarm follow the instruction and fix it.
God bless you
  • 1
    Close all of your car doors.
  • 2
    Insert one key in the door lock and cycle it to the "Lock" position, and then back to the "Unlock" position two times. Leave the key in the lock cylinder.
  • 3
    Enter your car and insert your key into the ignition cylinder.
  • 4
    Cycle the key in the ignition from the "Off" position to the "On" position twice in a row. The alarm will emit a chirping sound after turning the ignition to the "On" position the second time. This will reset the alarm, making it ready for reprogramming (if necessary).
May 30, 2013 | Cars & Trucks
Cd rom is not wrking no power supply.not showing in my computer
you have to plug in the back of your cd rom it has a plug inside your decktop it will only plug in one way 4 wires red gose to the left on cd rom ribbon gose white side right it mybee red on ribbon put it on the number one pin .make sure that the computer is turned off first.then turn it on watch for the light to come on the drive ok jim
Jul 17, 2011 | Computers & Internet
42 projection sony wega tv model kdf46e2000 turn on but red lite flash for 3-4 second then tv gose off
Your TV set has entered a protection mode, the system detects a failure. Try to unplug your set for 5 minutes to reset the system...
Sep 24, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Cuts on start loading then gose out
Reset the unit by sliding the power button the the left and hold it at that position for 15 seconds, then release.
Aug 18, 2010 | Garmin nuvi 200W GPS Receiver
How to Orange SPV C500 factry reset
1. Press and hold soft1 and soft2 keys.
2. Press and hold power button for around 1 to 1.5 seconds. Release power button. Keep hold soft1 and soft2 keys.
3. Later, screen shoould show instructions to ask user to press '0' key to reset to factory default.
4. Press '0' within the timeout period, which is only several seconds only.
5. If no instruction is shown on the screen, repeat steps 1 to 4.
The timing is sensitive.
Mar 19, 2010 | Orange SPV C500 Pocket PC
Power comes on for 5 seconds the outr it gose.
Make sure you have the appropriate load on the supply. If no load, then the supply will overvoltage and the circuit will shut down in a few seconds.
Nov 29, 2009 | Gateway Computers & Internet
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Mitsubishi WD-65000 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
