Question about Plano 7271 Tackle Box
Need plastic door - Plano 7271 Tackle Box
Door release buton does not open the door
You can disassemble the microwave oven and check out the release mechanism. You'll find several hooks that hold the door closed and a linkage mechanism to the door opening button. There may be a broken piece of plastic or maybe just a loose or missing screw that holds linkage together. In the case of a broken plastic part, you can fix it with a 2-part epoxy adhesive, but you'll need to permanently splint across the break with a piece of metal or strong plastic that you've scavenged from somewhere. Before epoxying the splint in place, rough up all plastic surfaces where you want the epoxy to stick well.
Good luck.
Mar 16, 2015 | Panasonic Microwave Ovens
The mullion is broken in my Lg refrigerator
I have a related question. My lower spring broke and I have the replacement spring. How do I put it into both plastic fittings at the same time. One arm on the spring goes on mullion while the other arm goes into a fitting on the door. Please help!
Aug 15, 2012 | LG 4-door French Door Refrigerator...
Rear door on 06 jetta wont open
At a guess the outside handle has become detached from the linkage inside the door and you've got the child lock on as well.
Well to get the child lock off, you need a long fairly broad plastic strip, I've used the long side cut out of a plastic milk carton in the past.
Wind the window in the offending door down, then insert the plastic strip in the door gap underneath the handle, once in try the internal door handle, if it fails try again working your way down the door by widths of the plastic strip, trying the internal door handle as you go, with luck you'll have release the child lock by the 3-4th try.
Once open, its taking the inside door card off and re-attaching the linkage for the outside handle.
May 01, 2011 | Volkswagen Jetta Cars & Trucks
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
I purchased a replacement side view mirror for a 2010 Silverado. I need to remove the door panel to get to the wiring connection How do I remove the door panel?
Try with this procedure...
1) Start with opening the driver's side door and lowering the window. Remove lock lever (1A).
2) Using a plastic pry bar [slotted screwdriver], slowly pry plastic cover to reveal screw.
CAUTION: These plastic covers are fragile and break easily. Be very gentle in disengaging them.
3) Remove screw with a 10mm socket.
4) Slowly pry plastic cover using a plastic pry bar [slotted screwdriver].
5) Remove the (2) revealed screws with a 10mm socket.
6) Pry off the door panel controller using a plastic pry bar. Disconnect wiring and remove the controller.
7) With the plastic pry bar, pry around the triangular panel as shown.
8) Lift up and slowly pull door panel out partially.
9) Release the door lever rod with a needle nose pliers. Remove and set door panel aside.
Keep us updated.
Jan 11, 2011 | 2009 Chevrolet Silverado 1500
1999 porsche boxster; when opening drivers side door with key...lock mech spins free with no resistance and door doesnt open
It sounds like it could be the plastic connecting bit that links the lock tumbler lever to the rod that operates the door lock mechanism, has broken or become disconnected. To check, you will need to remove the trim on the inside of the door, after removing any screws and the inside door lever and window winder.
Once you have the inside trim off and the plastic sheet, you will see an access hole for the door mechanism and the lock tumbler. It should be attached to the actuating rod by the aforementioned plastic bit. If plastic bit appears OK try re-attaching it or replacing it if broken. If the lever part of the lock tumbler which attaches to the rod is broken the lock will need replacing.
Jan 10, 2011 | 1999 Porsche Boxster
How do I take the door panel off of a 95 Ford F150 to replace the handle?
All there is is just screws around the outer sides of the door panel(3 on bottom). There is one located on the arm rest where the handle is. Then you need to take the screw out where you can lock your door and open your window ect... And just move the panel around until it comes off. You might have to pull the door opener out a little to get it through that hole.
Nov 02, 2010 | 1995 Ford F150 Styleside Regular Cab
I need to remove the drivers internal door panel
Remove plastic studs from door closer. Unscrew three retaining screws. remove grab.
Unhook window winder retaining clip. Best done with small long-nose pliers. window winder retaining clip located inside plastic winder handle section. Will need to prise away winder handle from door slightly to expose clip. locate and gently pull clip from winder shaft.
unscrew door opener / lock assembly retaining screw.
gently prise lower trim retaining press studs from door. remove lower trim.
gently , from rear of door, pull upper trim from door and similtaniously prise upper trim press studs from door.
gently giggle door opener / lock assembly through upper trim . remove trim
gently with flat blade, peel off plastic dust sheeting.
access to inside off door is now possible.
Reassembly reverse of above
Cheers !
ozzy11
Feb 04, 2009 | 2001 Suzuki Swift
Bosch dryer nexxt 500 (wtmc3521uc) broker plastic window
The plastic window can be repalced you dont need to get a new door...
Just remove the door from the washing machine and undue the screws around the rim and unclp the plastic rim and you should be able to fit in a new one with no problem...
hope it helps any questions dont hesitate to ask..
Jan 20, 2008 | Bosch WFMC 3200 Front Load Washer
Plano 7271 Tackle Box Logo
Top Plano Sport & Outdoor - Others Experts
Are you a Plano Sport and Outdoor - Other Expert? Answer questions, earn points and help others
