How to factory reset ken xin da m2 - Computers & Internet
My headphones no longer work on my experia m2 after I connected the wrong headphones and got a list of settings that I dismissed without reading by accident. I can not find those settings ( nor any others...
One option may be to factory reset the experia m2 without loosing your data. Follow carefully the instructions on page 115 in this manual.
http://www-support-downloads.sonymobile.com/d2303/userguide_EN_D2303-D2305-D2306_3_Android4.3.pdf
Once the reset is complete then reconnect the headphone and listen to your music.Make sure you are using compatible headphones.
Aug 06, 2014 | Audio Players & Recorders
Password1752809
If you forgot your password and/or want to reset the router back to the default settings:
Step 1 Power the unit off by unplugging its power adapter.
Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
Step 4 Watch the lights on the front of the gateway. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, recycle the power on the gateway.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure.
The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case). The default IP address is 192.168.0.1.
BEST OF LUCK
Dec 15, 2013 | D-Link DI-704P Router
I want to reset my D-link 4046 to factory default. How do i go about that?
in general, to reset the D-Link to the Factory Default Settings, please follow these steps:
Turn off the router
Locate the Reset button on the back of the router.
Use a paper clip to press the Reset button and power on.
Hold for about 5 seconds (don't hold too long) and then release. (Or, release when M1 and M2 flash at the same time.)
After you have completed the above steps, the router will be reset to the factory default settings
May 19, 2011 | D-Link 24 Port Gigabit Unified Layer 2+...
Paswort vergessen
try the default login/pass
admin/admin
if that doesnt work you will need to reset the router to factory settings
1. Turn off the router
2. Locate the Reset button on the back of the router.
3. Use a paper clip to press the Reset button and power on.
4. Hold for about 5 seconds (don't hold too long) and then release. (Or, release when M1 and M2 flash at the same time.)
5. After you have completed the above steps, the router will be reset to the factory default settings
Mar 05, 2011 | D-Link DIR-300 Wireless Router
Xin cho hỏi cách unlock
To Unlock code from service provider and unlock it...
Jan 26, 2011 | Samsung SGH-d415
Vui long cho xin drive xerox docuprint c1110b
Hello
Xin vui l?ng s? d?ng n?y ?? t?i c?c tr?nh ?i?u khi?n
Drivers for Docuprint c1110b
N?u gi?p ??, xin vui l?ng cho b?nh ch?n
Oct 13, 2010 | Office Equipment & Supplies
Factory setting
Step 1 Power the unit off by unplugging its power adapter. Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure. Step 3 Power the device back on by plugging it in. Continue to hold the reset button. Step 4 Watch the lights on the front of the router. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button. The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, unplug the power on the router and plug it back in. If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure. The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
Feb 16, 2006 | D-Link DI-704P Router
Factory settings
Feb 16, 2006 | D-Link DI-804HV - 4-Port Broadband VPN...
Factory settings
Feb 16, 2006 | D-Link Express EtherNetwork DI-804HV...
Computers & Internet Logo
214 people viewed this question
David Payne
David Payne
