Question about Boxing
Orbit walking sprinkler
Stuck does not turn
2 Suggested Answers
nonanon
  • 8 Answers
SOURCE: Orbit walking sprinkler
You probably just have the arms pointed the wrong way. To travel forward the angled part of the arm should be pointed in a clockwise direction. Aim them the other way and it travels backward.
Posted on Aug 05, 2009
Where do I get a new gear box for traveling sprinkler Orbit
Once again a couple simple GOOGLE searches...
Here is the item on the ORBIT website.
Orbit Irrigation Traveling Sprinkler Motor Assembly
I've never bought anything from these companies so I don't know how legitimate they are. Use at your own risk!
Orbit Traveling Sprinkler Motor Assembly
Aug 02, 2016 | Orbit Garden
Orbit sprinkler timer manual
Contact the manufacturer. They usually will have the manual online for downloading.
Jul 30, 2014 | Orbit Irrigation 57856 6-Station Easy Dial...
How do I adjust sprinkler head properly
Check to see if the small slotted screw is flush with the top of the spray nozzle. If so, it has been manually lowered. Turn the screw counter clockwise until it stops, be sure to hold the nozzle to keep it from turning. If no, unscrew the nozzle and remove debris from around filter. Tell the gardener to just mow the grass and not to touch the sprinkler system he is usually why it was turned down 9 times out of 10. If he says "No touch, No touch. He is lying fire him.
Apr 13, 2013 | Orbit Sprinkler System 2-inch Soft Top...
Orbit 57004 sprinkler controller does not turn on valves in Auto mode. Works OK in manual mode. All settings were checked carefully and repeatedly and verified by Orbit tech assistant by walk through
I am experiencing the same problem with my Orbit 57004. Did you ever figure out what was causing it not to start in "Auto" mode? he solutions above are not panning out for me.
May 12, 2012 | Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
My orbit tractor lawn sprinkler goes backwards instead of forward. So, it won't track on the water hose. What's wrong?
try turning the nozzles the other way - they should turn counter clockwise when looking from the top, not clockwise.
Jul 25, 2011 | Orbit Trvlng Tractor Sprinkler
I have an Orbit WaterMaster Sprinkler control, it is hooked up, but there is a light bulb that says power off and the sprinklers won't turn on. They will turn on manually at the sprinkler station. Can...
There are 3 things this "off power" "light bulb" could be. Blinking red light? means fuse has gone out. Check the power source where the unit is plugged in to. Is the GFI popped out? plug something else like a fan or something into the socket to test. the third thing is a short internally. Call orbit technical assistance. they're great.
Apr 11, 2010 | Orbit Sprinkler System Power Source...
Aug 25, 2008 | Electrical Supplies
Boxing Logo
196 people viewed this question
Top Boxing Experts
Karissa Smith
Karissa Smith
Level 1 Expert
Are you a Boxing Expert? Answer questions, earn points and help others
