NAC048AKC3 What is the BTU / size for this model
I LOOKING AT RUSSO #2cw WOOD STOVE WITH NO MANUEL DOES ANY ONE KNOW THE BTU OUTPUT FOR THIS STOVE??
they have a number of sizes looks like 1 cu foot small wood stove approx. 20k BTU to a biggest 4 cu foot model around 62 k BTU
https://chimneysweeponline.com/wscompha.htm
Dec 29, 2016 | Home
What. Square footage is my ac unit model#NAC048AKC3 rated for
serial numbers are useless unless you provide make , model, year of unit and rating
ac units are rated as BTU's, Kw's or tonnage
with out that information there is no way of knowing the volume of a room that the unit would work well in
May 05, 2016 | Heating & Cooling
Mitsubishi Heavy Industries Cassette Out Door Model: FDC506HES. What is the BTU size?
1 ton of ac is 12000 btu. you should probably call mitsubishi they have a tech support that will help you with this. the number is usually in the paperwork that came with the unit. you may find it on the tag where you got the model number
Oct 15, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
Buying a house and want to know the size of the air conditioner...model is goodman clj60-1c and s/n is 0505041878....
That is a five ton unit...that's what the "60" in the model stands for.... 60,000 BTU.....12,000 BTU equals 1 ton...5 x 12 equals 60.
heatman101
Jul 10, 2011 | Goodman CLJ60AR61 Air Conditioner
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
Hitachi RAS-10C2M. What size of air conditioner
If the number you say is the model number, it appears to be a 10,000 BTU.Check on the sides of the unit, or inside where the air comes out, and it should give the numbers.It should say 5000 to1800 BTU, if it is a 110 volt unit. BTU is what you are looking for if you want the output, not HP.
Feb 23, 2010 | Hitachi Heating & Cooling
Btu's
That air handler can accamodate different size coils. Look for the coil model number. Also you can look at the outdoor unit model number they should be matched up. There is generally a set of 2-3 numbers in the model numbers that will tell you. xxx036xxx is 36,000 btu. tonnage is 12,000 btu per ton so 36,000 btu's would be 3 tons. xxx040xxx= 40,000btu's or 3.5 tons etc.
Mar 16, 2009 | Heating & Cooling
Heating & Cooling Logo
196 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
