Question about Sanyo 6450160929 Remote Control
Rcs 4vpis4u How do you remove the cover on the battery compartment on the back of the remote?
2 Suggested Answers
lslater99128
SOURCE: sanyo remote rcs-4vpis4u no display
Lift up front cove and hit reset button with end of papercli[p
Posted on Oct 10, 2012
How to change batteries on the remote control of my Panasonic air conditioner Model Number CU_RE24LKR
  • Remove battery compartment cover
  • Observe battery orientation and polarity
  • Remove old batteries
  • Install new batteries
  • Test operation
  • Install battery compartment cover
Aug 30, 2016 | Panasonic Heating & Cooling
How do i change my battery
REMOTE CONTROL HANDSET: (sEE Figure 3)
NOTE: PLEASE REMOVE THE PROTECTIVE STICKER FROM
THE REMOTE CONTROL BATTERY BEFORE OPERATION.
This unit includes one lithium battery, CR2025/3V.
Remove battery before discarding the remote.
Battery Replacement
a) Locate the battery compartment on the back of the
remote control handset. Slide the battery cover out
with your thumb.
b) Remove old battery.
c) Place new battery into battery compartment.
d) Slide battery compartment into the remote control
handset.
NOTES:
• Remove the battery from the equipment when it is not
being used for an extended period of time.
• Remove the used battery promptly.
• Do not discard used batteries into household trash
containers. Contact your local government for disposal
or recycling practices in your area.
Jul 01, 2015 | Bionaire BT200RCU Tower Fan
How to change battery
Either the remote control is regular size or miniature like the remotes for cars. The only real difference is the type and size batteries it uses. The regular size remotes usually use 1 or 2 "AA" or "AAA" batteries, or occasionally, a 9 volt battery. The miniature remotes take "button" batteries that are available at Radio Shack or the big-chain drug stores like CVS. Whether the batteries are the regular type or miniature here's what you do: On the back side of the remote there will most likely be a small phillips-style screw in the middle. Remove this screw and then you will be able to open the battery compartment door. Write down or take pictures (better) of how the batteries are configured and note this as you remove the old batteries. Radio Shack has a battery tester. If ALL the batteries are still good, then the remote is defective. If ALL the batteries are dead or very weak, then most-likely the remote is working fine & will come right back to life. Enjoy!
Jun 10, 2014 | Sanyo RCS-SH1UA Wireless Remote Control
Battery compartment
Battery compartment covers can be very tight fitting and difficult to remove. You may have to apply some gentle downward pressure on the cover and persistent pulling on the thumbnail breaking arrow to get it loose.
Nov 21, 2013 | Sony Nsgmr1 Remote Control
Remote control for vmb070 does not work
There should be a clear indication on your remote where the battery compartment is. Usually there is a slideoff cover that has to be removed. Some remotes have covers that are difficult to remove. Once you have the compartment open, you can remove the batteries. Check for signs of corrosion inside the compartment and clean it before installing new batteries. Be sure to observe proper polarity when installing new batteries
Mar 17, 2013 | Televison & Video
How do you replace batteries in a sony rm-sp350 remote
On the back of the remote, press the battery compartment cover where indicated and slide the cover off. It may be difficult to remove
Dec 02, 2012 | Televison & Video
Directions to reprogram hunter 952g
You need remote control.
Go to your circuit breaker or fuse box, and turn off the power to the fan you will be programming.
  • 2 Turn the fan's remote control over, and remove the battery compartment cover. Take out the remote's 12-volt alkaline battery, and set it aside.
  • 3 Match the DIP switches inside the remote's battery compartment with the DIP switches on the fan's receiver unit.
  • 4 Reinsert the 12-volt alkaline battery into the remote's battery compartment, and replace the battery compartment cover.
  • 5 Go back to your circuit breaker or fuse box, and turn the power to your fan back on.
  • 6 Press the "Hi," "Med" and "Lo" buttons on the remote control in quick succession. Complete this step within 20 seconds of completing Step 5. The remote is now programmed and ready to operate your fan.
  • Sep 06, 2012 | Hunter Dryers
    Directv remote
    Assuming there are no visible screws on the back cover, look for screws in the battery compartment.
    Feb 16, 2008 | Universal Remote Control DIRECTV Universal...
    Televison & Video Logo
    10 people viewed this question
    Top Sanyo Televison & Video Experts
     Grubhead
    Grubhead
    Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
