Marshall AVT 150head no power
Lightning storm, turned all equipment off and now amplifier will not power back on. I am thinking possibly a fuse. I do not want to mess with anything inside until advised from someone who has seen this before. I have tried other power cables as well, that does not seem to be the problem. I am hoping this is something I can resolve with my own hands, so I learn something in the process. Thank you for your help.
  • criv001 Sep 02, 2007
    Problem solved, just a blown fuse.
  • sdrayer Feb 19, 2009
    My Marshall AVT150 keeps blowing the TDA7293 chip after i replace it, but i can't find a short anywhere else in the amp that would make it short out. what are some things that could make these chips short out?
Most of the problems with the AVT 150 amp blowing fuses have to do with the TDA7293 power amplifier IC being shorted. If you have good solder skills this and a new fuse will probably take care of the problem. If you do not have good mechinical / solder skills, take it to a Marshall authorized repair station.
Posted on Nov 13, 2007
    Champion:
  • 288 Answers
I would go ahead and take it apart, after you unplug it or course. if there is fuse on the back there will be one just off the ac line inside. These amps have an 12ax7 tube in them I beleive ,and large filter capacitors in them where voltage could be stored for a time after you unplug it ,but this is a fairly modern amp with bleeder resistors so it will be safe . you can wait over night to be safe, anyway you won't go touching the large capacitors anyway you are just changing a fuse. look for something like 2 amp or 5 amp in value. replace it with the same value.
Posted on Sep 18, 2007
SOURCE:
External Speaker hookup problem. I hooked up 2 external speakers (8 ohm, 160 watt) into my Marshall AVT 50 amp (tag on back says 4 ohm minimum). Everything worked fine, then I shut it down and now (next...
If you are competent with electronics, open it up and check the fuse(s). Especially if no lights come on. If you get voltage, then check the jacks you plugged into- they may have dirty interrupt contacts. When you plug the jack in- it opens those contacts that otherwise are closed making the circuit to the cabinet's built in speaker. Contact cleaner should clean them up if that is the issue.
While it is possible there is a power supply issue, you can see that quick with a voltmeter, it is not likely you did much more than blow a fuse.- very possible if you unplugged speakers with the amp operating..
If you think you killed it- you usually still get distorted noise.
Mar 29, 2012 | Marshall Amplification Music
Marshall AVT 100 dfx doesn;t work
junn561,
Thank you for asking me directly to help you with your problem. However, either the question you are asking is not within my area of expertise (I am an automotive repair technician), or the question is incomplete and does not contain enough information for me to help you.
Dec 11, 2011 | Music
After a lightning storm, my TV will not turn on. Is there a fuse or something on the in coming power that may have blown causing it not to turn on?
Any TV subjected to a power surge will have problems. If you can remove the back cover, do so. Locate the glass fuse. In the best situations the fuse is clear and opened, and replacement will repair your TV. In worst cases the fuse may be blackened, and you will see that many components are burned and shattered. If this latter is true, only replacing the TV is your best bet. In many cases electronics may be connected to surge protectors, but lightning will over ride these devices and cause damage. I have seen this happen many times.Thanks for asking and show all hands of support!
Jun 23, 2011 | Sanyo AVM-3659S 36" TV
I recently got a Marshall mg100hdfx head for free because it wont turn on, so I am investigating possible parts that may need replacing. The only description I got as to why it wont turn on anymore is...
You may find almost anything in this. I think the power amp is on a separate board so the connections to that might have been broken. Possibility include cracks in the circuit board. First thing is to do after visual check is to check power supply voltages to verify power switch/fuse/transformer/rectifier/capacitor/regulator health. Switches are sometimes damaged... and also wires can fall of or break.
May 02, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Hi I have a Marshall avt 150 head and it has stopped working completely, no light on nothing no sound I checked the back power lead is in and still nothing, I know it is a vague question but can someone...
first check for blown fuse, near the mains power input terminal. if thats not the case and u dare not open the unit, get it fixed by a qualified tech.
u have a blown power supply unit.
Mar 13, 2010 | Audio Players & Recorders
I have a marshall avt 100 which was working fine until i plugged new guitar in strummed one chord and the speaker went **** up, so i plugged into another cab and played a while then a week later plugged in...
This is a problem I would recommend for a qualified Marshall amp service person to look at. Worst case scenario is that somehow the speaker out put transformer or the power transformer burned out. They aside from output tubes are the most expensive parts to replace. Add shop labor on top. Ask for an estimate first. Consider how much a new amp will cost and then decide. I would personally go for the repair myself.
Nov 27, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
My behringer mixer phx2000 was took a lightning strike. the right speaker does not work. everything else seems ok
Should either unplug all electrical equipment during a storm or get a grounded filter to bleed off excess voltages from storms, power company fluctuation etc. Once the mixer electronics are fried you are SOL (**** Out of Luck) I'm afraid.
Sep 13, 2009 | Audio Players & Recorders
Someone please help
Good Day;
Two things normally happens after a L storm:1.) One must unplug TV for 5 minutes, then plug back in. 2.) Main glass fuse out, will be near a/c cord. 3.( Power regulator IC may be out. Try these first.
Good Luck!
Jun 13, 2008 | Panasonic PT-52LCX66 Projection Television
Tv will not turn on after lightning storm
Defective HV transformer. (Likely lost it during the storm)...accordianman
Nov 28, 2007 | Orion TVDVD092 9 in. TV/DVD Combo
659 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
