Question about Garden
2003 polaris 600 twin grinding when going into high gear
  • 332 Answers
SOURCE: Does a 2004 polaris Sportsman 600 Twin need valve
Should not need to be adjusted under normal use.
My brother in law runs 4 of these machines on their 30,000 acre ranch and put about 4,000 miles a year on them - they never have to adjust the valves
Posted on Mar 30, 2010
  • 11 Answers
SOURCE: Polaris Sportsman 600 won't go into Park
Might need to change the needle bearings on the reverse shaft inside gearcase (transmission).
Posted on Apr 18, 2010
  • 11 Answers
SOURCE: i have a 2005 polaris sportsman 600 twin the stays
best thing to do is to check front diff fluid these old dogs get rusty if not changed often in fact polaris has now said every 100 hours right with your oil if the oil is bad try filling the case with some minirerl spirits it may break the rollars free if not pull it out and see what you need for parts make sure to check for power at the center diff wiring before anything is pulled out switch off no power swith on 12 volts
Posted on Jul 09, 2010
  • 22 Answers
SOURCE: oil change on Polaris 2004 ATV 600 twin
i have heard that you only drain the oil from the oil resevoir. there is a 14mm bolt at the bottom of the resevoir. remove this and the oil should drain. you may also turn the engine over a few turns to evacuate the remaining oil in the cranckcase. change the filter, fill the oil rsevoir to the specified amount and you should be good to go.
Posted on Aug 07, 2010
  • 123 Answers
SOURCE: 2003 Polaris 600 Twin --
On the Polaris twin motors the drain plug is located on the bottom of engine. There is a hole in the skid plate for access to plug. The plug will take a 6mm hex wrench or socket. On the plug there is also a sealing washer, make sure the washer stays on the plug or put it back on if it drops in the oil. Any questions let me know, good luck, Daniel.
Posted on Aug 04, 2011
My Polaris sportsman 600 twin 2003 starts and idles but won't reve seems to be missing and blowing black smoke ?
black smoke is over fueling--choke on or leaking injector or injector seals
check for blocked air cleaner
Dec 02, 2016 | ATVs
Why is fluid coming out of the weep hole on my 2003 600 twin polaris sportsman
possible it coming from you water pump
that happened to my 500 polaris ho
Jul 09, 2014 | Polaris ATV
Tire makes a grinding noise on perego polaris sportsman 800
Why dont u try adding grease to the nuts and screws then loosen the nuts a bit to give air space...try it out
Dec 28, 2011 | Polaris 800 Twin Sportsman Ride on Toy
2003 Polaris 600 Twin -- Where is the oil plug located? Trying to change the oil and cannot find it!
Aug 03, 2011 | Polaris ATV
Peg perego 800 Polaris 24v will not go into high gear..reverse and low gear fine, but will not kick into high gear..what to check for??
did you remove the high speed lockout? if so then you probably need a new foot pedal, let me know if you do i can order you one
Jun 04, 2010 | Polaris 800 Twin Sportsman Ride on Toy
Jun 17, 2009 | Polaris ATV
Reverse issues
i believe that your reverse gear is a kit. Now they are not gear driven, they actually run the motor in reverse to back you up, anyways, if you look down from your reverse lever, you will see a adjuster nut or guide bolt. try adjusting that some. you definitely don't want to keep grinding those gears!! reverse kits are around 500 bucks. Good luck
Jan 23, 2009 | Polaris New Genuine Polaris Snowmobile...
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
