At startup, my Dell XPS L702X emits 4-4-4 beeps with no video display, then powers down.
Paeroa
  • 457 Answers
SOURCE: No display jus beeps
Your memory chips must be had i that sounds like a chip problem under the laptop secured by two screws will be where the chip lodged pull it out and re-enter it might go it might not but that your problem I am sure of it.
Posted on Oct 10, 2007
hughv
  • 196 Answers
SOURCE: cannot swith on
Beep codes are specific to the BIOS, but this seems to indicate a bad video card, which needs to be replaced.
See here for more codes:
http://www.pchell.com/hardware/beepcodes.shtml
Posted on Oct 11, 2007
localwonder
  • 6784 Answers
SOURCE: Dell XPS 600 turns itself on to solid amber
Hi. the mother board seems to be having some initialization issues during boot up. this is common when the mother board is failing. i would check to make sure the battery on this board is working. if it is, the board my be ruined.
power board seems to be fine.
please rate and god bless.
Posted on Mar 17, 2009
ArmenianTech
  • 24 Answers
SOURCE: Dell XPS M2010 Starting Problems
Ok. Here is the thing. I hope everybody sold their problem, but I will just post for others who may experience the same thing.
1st believe it or not : there is nothing wrong with motherboard, as when you press the power button, computer will shut down. with defective motherboard it will just continue running untill you will unplug it.
2nd believe it or not : it can not be battery issue or hard drive issue, because it does not make any scenes in any way. I have to agree that hard drive on the right is semi-correct answer.
REASON:
IT is video card that messing up everything. And it is located right under right hard drive. That's why when somebody removed hard drive he/she accidentally corrected the cooling system of video card , which returned M2010 to live.
CONFIRMATION:
1. First remove the top cover from the computer. There are 2 sides the plastic things. If you look at the back of your laptop you will see 2 small holes , one on every edge of the back. You stick something there it will loose the front cover.
2. unscrew all the screws hat have ">" or "<" signs next to them. there are something about 15-16 screws in total: this will allow you to open the cover under wich you can find the motherboard and stuff. When you open the cover pry to start the computer, and you will see that fans will not start even after 1-2 minutes after you hit the power button.
3. Remove the right hard drive and under it you will find screws A, B, C, D (silver) and also 1,2,3,4 (black) unscrew the black ones first, them remove video card with the cooling mechanism. now try to turn on the machine. you can see that after like 20-30 seconds fans start working which means that motherboard is fine and it was the video card that was giving problems.
SOLUTION:
1. I am not sure what causes the issue but I have fixed it this way:
uscrew silver screws and disconnect cooling part from the actual video card.
2. clean both, video card and cooling system not touching sky blue foam ICs. That staff is needed to cool the chips on the video card.
3. let them dry for an hour or so after cleening, than apply some Thermal compound, thermal paste and re assemble the video card with the cooling staff. (mek sure no screw is loose or something)
4. put it back and turn on the computer. If it works , whell .. it works now :)
if not then either you levae some liquid on the video card or screws are loose. try to play a bit with screws. but my personal suggestion is just to wait for a minute or two until video card gets hot and fixes liquid problems itself :)
Try it. It worked for me perfectly ...
Posted on Oct 08, 2009
SOURCE: The power light on my Dell XPS 8000 keeps flashing
It's not the light.Your CPU might be already dusty. I also had an experience that was just like you. I just cleaned up my CPU and the noise was gone.
Posted on Feb 14, 2010
Xps 8700 five beeps and five beeps starts windows goes to power save mode
Sundeep B posted this July 2013 on the DELL.COM>Community>Support Forums>Desktop>Desktop General Hardware Forum
DEL5 beep error code indicates an issue with RTC power and indicates an issue with CMOS battery. You may try reseating CMOS battery. You may refer to Owner's Manual Here. The location of CMOS battery is as shown below :
The video cards mentioned by you should function properly, however, Dell has tested XPS 8700 only with following video cards :
  • nVidia GeForce GTX 660 GTX 645 GTX 650Ti GTX 660
  • AMD Radeon HD 7570 HD8870
Dec 10, 2014 | Dell XPS 8700 Desktop - Windows 7
Dell xps 9100 constant beeps upon startup
Beep Codes
Your computer might emit a series of beeps
during start-up if the monitor cannot display
errors or problems. The following repetitive
beep codes help you troubleshoot problems
with your computer.
NOTE: To replace parts, see the Service
Manual on the Dell Support website at
support.dell.com.
One beep - BIOS ROM checksum failure;
possible motherboard failure
Contact Dell (see "Contacting Dell" on page 53).
Two beeps - No RAM detected
Remove the memory modules, reinstall
one module and restart the computer. If
the computer starts normally, reinstall anadditional module. Continue until you have
identified a faulty module or reinstalled all
modules without an error.
If available, install memory modules of the
same type in your computer.
Three beeps - Possible motherboard failure
Contact Dell (see "Contacting Dell' on page 53).
Four beeps - RAM read/write failure
Ensure that no special memory module/
memory connector placement requirements
exist (see the Service Manual on the Dell
Support website at support.dell.com).
Verify that the memory modules that you are
installing are compatible with your computer.
Five beeps - Real Time Clock failure
Replace the battery.
Six beeps - Video BIOS test failure
May 22, 2014 | Dell Studio Xps 9100 Desktop Computer
4 beeps on dell xps 13
4 beeps on startup is a RAM error. Locate the ram stick(s), remove and re-seat them. Make sure you do this with the machine powered off and the battery removed!!!
Feb 18, 2014 | Dell XPS 1340 Notebook
What problem is indicated by two beeps at startup on a Dell XPS 8500?
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer.
Oct 06, 2012 | Dell Computers & Internet
My Dell Inspirion Mini 10 is beeping 8 times when I turn it on. Nothing on the screen.
Try holding Fn + End with battery and power cord out and while still pressing Fn + End plug only power cable back in and try to power on.
Oct 12, 2010 | Computers & Internet
Dell xps 730 does not boot
I think it is a problem with your RAM memory. If you have 2 dims extract one and try to boot if not work extract the other one and try.
Jul 18, 2009 | Dell XPS 730X Desktop Computer
On startup it beeps and wont startup. i hit F12 and it works fine now. thats all i did. so what could be the problem? i've already replaced a power supply about a year ago. and also my dvd player is kinda...
On startup beep how many beep do you hear?
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Hope it Help you out ^_^
Jun 29, 2009 | Dell XPS 200 PC Desktop
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
