Question about Home Security
SmartGuard Motion Light Model: AEC939ASD+Manual
How do you set time and date on this unit?
2 Suggested Answers
  • 14 Answers
SOURCE: SmartGuard Motion Light
No manual but clear contact info and web site found.
http://www.aurum.com.tw/sitemap.php
TEL :+886-6-2720116  FAX : +886-6-2711890  E-mail:aurum@aurum.com.tw
Posted on Jul 26, 2010
Just installed a motion activated light (model 021746). The light will not turn off; there is no switch.
in the installation notes , it probably reads to this effect
to run the light all the time --switch of power supply and switch on
to run a light sensor - turn the power off , back on back off back on
one action changes the internal program to leaving the light on , the other activates the sensor mode
the switch is the light switch that controls power to the unit
Oct 26, 2016 | Home Security
Brinks motion activated security light model 7160w. Only stays on for about 15 seconds. Setting is on 10 minutes. Can someone help?
Sounds like the motion sensor is not picking up motion. Or, does it actually sense motion and only stay on for a short time each time? Try moving the setting, if this is the case and see if you see ANY change. If not, then replace the motion sensor.
Oct 24, 2014 | Home Security
User manual for fl09sbk light
It appears this device is rate 10 amps at 230 volts = 2300 watts.
Use at least #14 wire and 15 amp breaker.
Connect wire at connection point on light.
Unit appears to have a transformer, and might make humming sound.
There is override located somewhere on unit. Possibly as a button on the motion sensor
If infrared motion detector requires separate wiring connection, then use following wiring illustration:
http://waterheatertimer.org/images/How-to-wire-motion-sensor-230V.jpg
Motion sensor will probably have 2 settings.
1st setting for sensitivity, so it will not activate when cat walks up driveway.
2nd setting for time duration, selectable from 30 seconds to 7 minutes
ML FL09SBK IP44 36W Fluorescent PIR Floodlight c/w Lamp
IP44 Low Energy Floodlight c/w PIR & Override.
Black finish.
T4 twist and lock lampholder.
36 Watt 6500k T4 spiral compact fluorescent lamp included.
(replacement lamp - product code FL09L).
Electrical termination via 10 Amp connector block within secure enclosure c/w cord grip.
PIR detection range of 12 meters at 2 meter height from ground.
Detection arch of 160 degrees.
Time range 30 seconds to 7 minutes.
Manual override.
Nov 12, 2012 | Woods Outdoor Lighting Timer
Trying to set switch for 5 minutes , and i only get 30 seconds or 15 minutes
Which brand and model number specifically?
Leviton: 1-800-824-3005
Leviton Decora manual says:
"PR180 operates by detecting motion (such as body heat) within its field-of-view (area of coverage) and automatically switches lights ON. When motion is no longer detected, lights remain ON for a selected time and automatically switch OFF.
Adjustable light and time-delay controls are located on the front of the device."
The manual is not specific about set times.
In any case, the device has off-delay timing circuit, so once infrared heat is no longer sensed, the delay period begins, and once the delay period expires, the device is switched off.
Delay timing circuits are common for many home and industrial applications.
As a general rule, delay timers can be set for different time durations, however the Amazon page that sells PR180 product does not specify available time settings either.
Legrand RW3U occupancy sensor spec sheet says adjustable time delay 15 seconds 5 minutes, 15 minutes and 30 minutes
http://www.amazon.com/Legrand-RW3U603I-Occupancy-Vacancy-Decorator/dp/B005FMLL5G
Delay switches
Here is manual delay-time switch Tork SS20 SS13 where you can 'fine-tune' the delay circuit, but my experience is that exact 5 minutes is not easily set:
http://waterheatertimer.org/images/Paragon-ET-series-243.jpg
GE 15318 switch offers 5 minute, but there is no guarantee that you can get 5 minutes exactly:
http://waterheatertimer.org/images/GE-15318-countdown-timer.jpg
My conclusion is that there are very limited delay-time choices with this model number, or device is defective and suggest to call Leviton.
Sep 23, 2012 | Leviton R01-PR180-1LI Decora 180 Degree...
How do i set date/time stamp on photos for DSC-W80? i have read manual nothing refers to this????
I'm sorry to inform you that the new cameras do not have the superimposing feature to add date and time on images automatically.
This is because many customers do not want that feature..
However, these cameras come with exit technology. The exit technology write the date and time information in the picture as meta data.
You can use an exif compatible software to add date and time on images.
You can also the supplied picture motion browser software to add date and time.
Please click on the below link to view the instructions to add date and time on images using the Picture Motion browser Software:
http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/feature/edit/attach_date.html
Thanks for understanding
Jan 28, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
SmartGuard Motion Light Model: AEC939ASD need setup manual how do you set time and date
Jul 03, 2010 | Home Security
Time and date stamp dsc-s650
This model does not support superimposing of date and time on images See page 28 of your manual. You can print date and time on your photos by using Picture Motion Browser
If you dont have a manual or have lost it here is a link
http://www.nycv.com/manuals/Sony/DSCS650-S700_ENES.pdf
Please rate our help to keep the free service online
Aug 26, 2009 | Sony Cybershot S650 Digital Camera
Motion sensor light stay on
Hi, You don't say what the make or model is, so I will give you the best advice I can. Most motion sensor lights today have a switch or two on them for "on", "test" and then some time like 3 minutes, or 5 minutes. The switch is tiny so it or they are easy to overlook. The "on" position will keep the light on all of the time. The test position does different things on different models but you will want one of the time settings. If this doesn't work for you get back to me with a little more info and we'll keep on it. Good Luck!
Feb 06, 2009 | APC Electrical Supplies
SmartGuard troubles
I am having the same exact problem with the Pro L. Did either one of you figure it out? I just spent $100 on the SmartGuard and now I cannot get it to work
Sep 29, 2007 | Fargo Pro LX ID Thermal Card Printer
Home Security Logo
307 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
