Question about Dryers
Whirlpool quiet dry 1 gas dryer no heat
No heat
  • 213 Answers
SOURCE: I have a Whirlpool Gas Dryer LGV6848AWO.
the ignitor bar that lights the gas might not be coming on, the coils that open the gas valve in the dryer might not be opening the valve, or the flame sensor might be bad which would not allow power to the ignitor. these are the most common problems with whirlpool gas dryers
Posted on Nov 28, 2007
SOURCE: kenmore 90 series gas dryer, NO HEAT!!!
Hi, if you get no glow on the ignitor and you have voltage its the little white two terminal fuse on the exhaust side that has no continuity on the series 80 it has 2 blue wires, these complete the circuit for both gas valves and the ignitor. If you have an ohm meter it you will find it rite away. Hope this helps.
Posted on Aug 17, 2008
  • 7 Answers
SOURCE: whirlpool gas dryer #lgr 4634 jq0 not drying and rattling noise
is the dryer tumbling
Posted on Jun 12, 2009
  • 23 Answers
SOURCE: Gas dryer gets hot for a few minutes then goes cold.
Sounds like you need to replace the coils on the gas valve. Just make sure your venting is clear 1st. If it is, the coils are easy to replace. Remove the front panel and the coils are on the bottom right hand side. Two screws and the bracket for both comes off. One has two terminals and the other has three. Real easy once you get into the dryer.
Posted on Jun 19, 2009
SOURCE: The gas maytag neptune intellidry gas dryer does
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Posted on Jul 11, 2010
I have a whirlpool dry mod#5636 in my home I have 110 the cord on the dryer is for 220 can I change it to 110 and will it work right..
No it will not,dryers with 110 volt plugs heat on gas,220 dryers heat with electric,putting a 110 vac plug on dryer for 220vac,the motor will run but it will not heat
your 2 options are
1) have a electrician come and run 220 vac circuit
2) purchase a gas dryer
Jul 28, 2011 | Whirlpool LER5636P Electric Dryer
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My whirlpool cabrio gas dryer is not heating. it is just a little over 1 year old is there a reset button for the ignitor what is your recommendation it dryed the sheets until they were damp to the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 27, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My whirlpool ler8648pg dryer has heat but not enough to dry larger loads. Takes multiple cycles to dry. Does anyone have a solution? Thanks
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 24, 2010 | Whirlpool LER8648P Electric Dryer
Whirlpool gas dryer no heat
One the terminals on the flame sensor fell off. II guess this is a common problem. relaced the sensor and
I'm back to drying clothes.
Oct 03, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer won't start
There is a good chance it's the 'thermal fuse'
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 07, 2009 | Whirlpool LEQ9858P Electric Dryer
Heat and clean vent, but way too long to dry
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE';
Aug 22, 2008 | Whirlpool LGR7646E Dryer
Dryer no heat but runs
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
DON'T FORGET TO RATE:
May 15, 2008 | Whirlpool LGR7646E Dryer
Spins but no heat
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
DON'T FORGET TO RATE;
Apr 11, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
18 people viewed this question
Top Dryers Experts
