Sanyo dp47840 stopped working
Tv stopped working will not power up
How can I fix my Sanyo Model FVM5082 TV?
You can get power supply boards and any other part you may need from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jul 28, 2017 | Sanyo Televison & Video
I have a 55 in flat screen model # dp47840 turned it off now it won't come back on. Its about 4 years old and never had problems with it
check circuit breaker in the main fuse box
If that is ok check the fuse in the power/wall plug
if that is okay check any internal fuses...
If the tv turns on via remote control change the batteries.
If that is not the issue and power is getting to the power button you will probably need the services of a GOOD technician
Jul 15, 2015 | Televison & Video
I have sanyo dp47840 and neded to know where the fuse is located
It can be located at the main power supply regulator board. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 25, 2013 | Sanyo DP50747 50 in. Plasma TV
Common issues for a emerson lc320em2
The TV powers up fine but the remote has stopped working any thoughts?
Aug 03, 2012 | Televison & Video
Sanyo big screen tv stop working. First the sound kept going on and off then the tv would turn off by its self. Finally it went off and it wont go on.
open your TV unit check possible loose contact. check defective parts to the power supply shorted regulator, blown fuse, open resistor and leak capacitor replace same ratings.
Apr 12, 2011 | Sanyo Televison & Video
I have a Sanyo model# DP 37819 just stopped working. Black screen , no sound and green power light blinks on and off
Tries tv unplug,replug the tv back like an hour later,now the tv is resetting itself back to the factory setting.Now,the tv should be working now.Not,than this problems,the cause is the power supply board have problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbuish power supply board for the replacement.
Oct 28, 2010 | Sanyo DP42746 42 in. Plasma Television
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
