Question about Bosch Dishwashers
Aqua sensor my Bosch aqua sensor dishwasher no SGS4352AU/17 soap dispenser will not open any suggestions please
  • 1314 Answers
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Posted on Feb 16, 2008
  • 351 Answers
SOURCE: soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Posted on Mar 02, 2008
SOURCE: Soap dispenser still has the soap in it after the dishwasher cycle has ended...
do you have a salt unit fitted. I had the same problem and the repair guy had to replace the salt unit as it was blocked up. Failing that it might be the board not opening the solenoid to allow the water to be jetted through the soap dispenser.
Posted on Mar 16, 2008
SOURCE: Dishsoap stays in soap dispenser
We had problems with soap remaining in the dispenser and dishes not getting clean when we used gel dish doap. We changed to the cakes of soap with a Jet Dry Power Ball in the middle, and now they clean fine.
Posted on Apr 14, 2008
  • 6 Answers
SOURCE: Bosch dishwasher shu4322 has code 1 aqua sensor what is the sensor do and where is it located
Most of the dishwasher has a Thermal hold period in which the machine will not advance to the next cycle until the water temperature reaches a specific degree. it is possible that your aqwa sensor/or heater is bad OR as in most of the cases, the Timer relay that is responsible in turning the heater on is stuck open, in this case you need a new timer. So,Check Timer/Aqua sensor/Heater
Posted on Aug 15, 2008
What to do if the soap dispenser does not open automatically during wash?
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Mar 19, 2011 | Bosch Dishwashers
Soap dispenser not working
Hi
Daniel
Jan 07, 2011 | Bosch Dishwashers
Soap door doesnt open
Hi
Daniel
Jan 07, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Soap tablet not dispensing happens every 2nd or
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Jan 05, 2011 | Bosch 24 in. SGS43E08 Exxcel Built-in...
The soap dispenser on our BOSCH dishwasher, SHE4AM, won't open during washing cycles. Please help
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Dec 13, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
The soap dispenser fails to open at times
Hi
Bosch dishwashers (not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced.
Older Bosch dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Oct 12, 2009 | Bosch Dishwashers
Doesn't cycle to open soap dispenser
RUN THE TEST PROGRAM TO DO THIS YOU WILL HAVE TO USE BOTH HANDS. Press and hold "Scrub Wash" &
"Delicate/Economy" buttons TOGETHER WHILE HOLDING THE 2 BUTTONS IN HIT THE POWER BUTTON RELEASE THE 2 BUTTONS AND HIT THE 2 BUTTONS AGAIN YOU SHOULD GET A 21 0R 23 CODE AND THE TEST PROGRAM WILL RUN IT WILL TAKE 45 MIN TO RUN BIT WHEN DONE IT WILL SHOW A CODE 1 OR 0 MEANS NOTHING BUT IF YOU GET A NY OTHER # OR LETTER IT CORRESPONDS TO A FAULT
2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
DON
262-893-4840
May 02, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Soap dispenser flap not opening
Not a solution but exactly the same problem. I should have sent the machine back (I bought mine about 2008 too) but by now, 2010, the machine is a complete waste of time and money. The soap dispenser fails to open every time, wasting money, water and my patience because I then have to hand wash after all. will try the suggested oil trick, but it was obviously a bad design to start with.
Jul 20, 2008 | Bosch 22 in. SKT5102 Free-Standing...
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
26 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
