I dnt have to find the driver of sis 965L motherboard driver
Download belarc advisor from the link below. That will give you the manufacturer and motherboard model. Once you have that go to the manufacturers website and find your motherboard model. It will probably be in the support or downloads area. Once you find it all the motherboard drivers should be there
http://www.belarc.com/free_download.html
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
sis 965L isent a motherboard, its the chipset on a motherboard, and that chipset is an a lot of diferent motherboards.
So please find out the correct name and modelnumber on your motherboard i we will try to help you
Nic
