Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Pen drive not showing in window explorer
I'm using Windows XP SP-2 and I've run into a problem. When I first inserted my FLASH DRIVE into the USB port of my computer, It shows, the safely remove hardware icon came up in the taskbar tray menu, but the drive was not displaying in windows explorer. So I went into Device manager and come under universal serial bus controller where I find my device,in USB mass storage properties I find driver,update details and made all effort but could not start it to window explorer. I tried the same usb with webcam its working properly.My flash drive is UMAX Apus210 and purchased just 2days back. Its working on all other computer. Its not open under auto run when I insert in usb port.I tried another pen drive too but it also not showup. Can any one please suggest what to do?
  • 7 more comments
  • Jalal Ahmad Aug 27, 2007
    Dear Rado, tnx for your suggestion. Still it does not solve my problem.When I check its maped drive letter `Z`. through disk management I changed my pendrive letterassign the same cosiquently when I check again its map drive letter changed to`X`In such a way I tried a lot but not find solution.Although from diskmanagement I can explore content of pendrive and drag to load too. but it will not open in explorer.When I tried to assign mapnetwork none it does not highlight ok
    Jalal
  • love_u_later Jun 06, 2008
    i have a kingston pen drive(2 gb), its not detecting in windows, but other pen drive does does, help me plz
  • sandy4uallll Jul 20, 2008
    I have updated my pc with SP2 after dat im unable to use my pendrive it is not at all sensing my device .
    I updated my usb port but of no use.
    I checked in properties nd found device status is also ok.
  • Anonymous Jul 26, 2008
    my pen drive not run
  • Anonymous Aug 14, 2008
    I have the same problem as jalathas. I can open the pendrive(Kingston) content by disk manager, after assigning a letter to the volume. But after this the pendrive follows not shown in Explorer window.
  • Anonymous Feb 17, 2009
    pendrive not showing in windows explorer
  • Anonymous Apr 11, 2009
    i hv d some prob u read , pen drive not shoeing in explore
  • nshtkum Apr 14, 2009
    yes I have the same problem
  • ajunin May 11, 2010
Thanks Rado.Your solution Works for me
Soura
Posted on Jan 02, 2008
  • 4 Answers
Hello Sir. Do you have mapped network drives on your computer? If you have this may cause your problem. When you insert the FLASH DRIVE into USB and the "safely remove hardware" icon appers try to right-click on it and choose "eject" or "remove" (don't remember :), then pull the FLASH DRIVE from the USB and connect it again. Go to Windows Explorer and try to open all your mapped drives, then the content of your FLASH DRIVE must be loaded into your Windows Explorer. This is happened sometimes, because FLASH DRIVE try to assign the first free drive letter after your phisical drive letters, and if you have a mapped drive letter, the FLASH DRIVE assign one of them. I hope this will help you :)
Posted on Aug 26, 2007
  • 51 Answers
Pen drive volume{memory} not showing
Posted on Nov 03, 2008
Just had this problem - probably because I also have network drives mapped. I just solved it by going to Control Panel (in classic view)>Administrative Tools>Computer Management>Disk Management, then right clicked the pen drive and selected "Change drive letters and paths". I then changed the drive letter to one that isn't already in use - I also used a higher letter so that if I map any more network drives they are less likely to conflict.
Posted on Mar 17, 2009
Do not accept the pen drive in windows 2000
Posted on Dec 22, 2008
I'm using Windows XP professional and I've run into a problem. When I first inserted my FLASH DRIVE into the USB port of my computer, but icon not came up in the taskbar .
Posted on Dec 08, 2008
  • 2 more comments
  • majeed945 Dec 08, 2008
    I tried the same usb with webcam its working properly.My flash drive is kingstoon and purchased just 2days back. Its working on all other computer. Its not open under auto run when I insert in usb port.I tried another pen drive too but it also not showup.
    I tried the same usb with webcam its working properly.My flash drive is kingston and purchased just 2days back. Its working on all other computer. Its not open under auto run when I insert in usb port.I tried another pen drive too but it also not showup.
    pen drive volume not known.
    inapropriate
SOURCE:
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
How do you use a flash drive on the computar
Hello
Install the USB Flash Drive:
Plug the USB flash drive into a free USB port on your laptop (it is an approximately 1/2" slot, either on the side or back of the laptop).
Windows XP operating system should recognize it. It may ask you what you want to do with it. Select "Open folder to view files using Windows Explorer" and click OK.
Operating system should assign it a drive letter (see the title of the Windows Explorer window that opens).
Use the USB Flash Drive:
In Windows Explorer, click Folders button on the menu bar to show the installed drives on the left pane of the screen.
To copy a file from c:\ (hard drive) to flash drive:
Find the file you wish to copy on the c:\ drive.
Right-click it and select Copy.
Right-click the location on the new drive where you wish to paste the file, and select Paste.
(File should now appear in desired location.)
Hope you find this useful, if you have any more questions, just leave a comment and i will get back to you as soon as possible.
Kind regards
Andrea
Nov 17, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
Malfunction
This can occur if the pen drive was inserted into a HUB rather than direct into a proper usb 2.0 port on the compuer.
It can also happen if the dmive has been mistreated in any way.
You may want to try re-format it from the computer mangement console
rather than my computer or windows explorer
Aug 23, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pen drive not showing in my explorer.
Its a common problem with the pendrive, in windows. some time it doesnot detect or not showing clearly that device. you have to check your pendrive manufacturer and driver details. and also check it out driver signing.
Do you have mapped network drives on your computer? If you have this may cause your problem. When you insert the PEN Drive into USB and the "safely remove hardware" icon appers try to right-click on it and choose "eject" or "remove" (don't remember :), then pull the PEN DRIVE from the USB and connect it again. Go to Windows Explorer and try to open all your mapped drives, then the content of your PEN DRIVE must be loaded into your Windows Explorer. This is happened sometimes, because PEN DRIVE try to assign the first free drive letter after your phisical drive letters, and if you have a mapped drive letter, the PEN DRIVE assign one of them.
Jul 22, 2008 | Microsoft Windows XP Professional With...
Pen drive does not open
Your pendrive is affected virus and do the format both pen drives and first cheak with your usb port also once and when you are pushing the pen drive in the pc should be smoth dont press just push some times light is appear but data cabe is not connected to pc
Jun 17, 2008 | Computers & Internet
STH7700D
just clearing out my work queue
May 27, 2008 | Computers & Internet
Transcend pen drive problem
Dear Sir,
i have a transcend pen drive 2 GB which runs perfectly on windows XP on other computer but it is not recognised by Computer. My Motherboard is Asus and Operating system is Windows XP. Initially it used to show a message "One of the USB driver sttached to this computer has malfunctioned, windows does not requesnized it". How can I do solve the problem. My email : [email protected]
Mar 25, 2008 | Electronics - Others
Pen Drive Driver
You must install a "Driver" for it to work under Win98, go to the manufacturers web site and download the driver and install.
Feb 07, 2008 | SanDisk 8GB microSDHC Memory Card with...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
3,632 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
