Question about Ruud Rheem Honeywell Fan Control Board St9101a 1014
Rheem rhqa 1200b - Ruud Rheem Honeywell Fan Control Board St9101a 1014
I have a Rheem rhqa 1010 b and need air filter size.
Just measure the filter housing (LxW) and buy it at walmart, lowes, hom depot etc.
Oct 07, 2013 | Heating & Cooling
How much BTU for a RHQA 1200b
It's 3 ton or 36000 btu
Thank you from bill at 123-hvac . Com
Staten Island ny
Apr 06, 2013 | Heating & Cooling
I have a RHEEM RHQA 1010B a/c unit that is pouring water out of the bottom....please help find cause and solution. PS it is very humid where I live!!!
Hello, usually water will leak from a furnace if the condensate line is clogged, or the condensate pan is cracked. If you have a shop vac try to hook it up to the outlet of the drain line and use the suction pressure to remove the sludge that is clogging it up. If the drain line appears to be clean the most likey the condensate pan is cracked or rusted and causing the leak.
Jul 13, 2011 | Heating & Cooling
How old is a rheem rhqa-122oj air handler and what is the max wattage.
ampsxvoltage=watts so if you know the amp draw should be on machine and voltage just multiply as far as age undetermined
Feb 02, 2010 | Heating & Cooling
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
Bissell little green steam machine
There is a small pump inside the unit that may be bad.
Dec 19, 2007 | Bissell 1200B Handheld Steam Vacuum
Ruud Rheem Honeywell Fan Control Board St9101a 1014 Logo
155 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
