Question about Sewing Machines
How To Thread A Bernina 1530 sewing machine - Sewing Machines
  • Sewing Machines Master
  • 7,365 Answers
You try youtube for a video or try this link for a manual
http://www.sewusa.com/Sewing_Machine_Manuals/Bernina_Manuals/1530_Instruction_Manual.htm
Posted on Jul 09, 2013
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
SOURCE: Threading a Bernina 900
Place the thread spool on one of the two thread guides. Bring the thread across to the notch on top of the machine guide it to the left and down the front of the machine. Directly under that threader close to the needle wrap it down under and go back to the top right to left then go to the top lever in the up position use your wheel to the right , wrap from right to left going down and threading. Wrapping just means placing around. Now for the bobbin. take casing out wit bobbin thread counter clockwise place in casing and release handle of casing put in machine making sue it is locked in. THen go fishing.
Posted on Dec 13, 2008
Mimito7
  • 128 Answers
SOURCE: user manual download bernina activa 140 sewing machine
Try this... www.2instructions.com
Posted on Apr 30, 2009
  • 30 Answers
SOURCE: How do you thread a bernina 1008?
I hope I can explain this in an understandable way!
1. Pull the end of the thread from the spool to the left and "click" it into the little metal guide (on the top of the machine) that is at the back of the long **** in the top. It's easiest to do this by holding the thread tight between your two hands, placing it behind the guide, and pulling forward until it clicks in.
2. for the remaining steps, let the thrread slide between the fingers of your right hand, keeping a little tension on it, as you thread the machine with your left hand.
3. Bring the thread end forward, laying the thread into the ****, and continue downward, along the right side of the vertical silver bar/hook thingy.
4. Bring the thread under that bar from right to left, and go back up towards the top of the wide **** in the front of the machine. As you pull up, the thread will click into the lower bar/hook thingy.
5. Lay the thread along the right side of the wide ****, go over the top of the needle bar (the part that goes up and down in the ****) and bring it down the left side. It will click into the needle bar.
6. Bring the thread back down towards the presser foot. Right in front of the screw that holds the foot on, there is a hook that opens on the left side. Slide the thread behind this hook, and then thread the needle from front to back.
7. Hold onto the end of the thread and run the needle down and back up once. Pull on the thread, and it will pull up a loop of the bobbin thread. Stick the tip of your scissors or seam ripper into the loop and pull the end of the bobbin thread out.
8. Slide your top thread through the slot in the presser foot so it comes out from underneath the foot, and you're ready to go! (Be sure and hold onto both threads for the first few stitches when you start a seam, to keep if from jamming up inside.)
Let me know if you need any clarification.
Posted on Jun 21, 2009
SOURCE: Bernina Bernette 65 sewing machine
I had the same problem. I'm a novice sewer. I just bought my machine. It did the samething, tension didn't work, the thread kept knotting up underneath, and the fabric kept curling up in the back.
I adjusted the tension knobs to no avail. Then it kept bothering me that it was curling up. I then decided to set the dials back to where the factory had them and adjusted the presser foot just a hair counterclockwise and I haven't had anymore problems.
The other day the needle almost broke because the tension was tight on the thread. You have to make sure that the needle is at it's highest point to get it to release the fabric so you have a thread tail.
This is my first purchased machine. I had a New Home years ago that was given to me, however it blew away in the tornado of 1991 in Kansas and I never replaced it. I really do love this machine. I don't believe I will ever want another.
Posted on Nov 11, 2009
I am trying to free-motion quilt using my Bernina 1530. Everything is fine until I quilt a curve or a circle. Then the thread on the back is too loose. I have tried adjusting the top tension, as well as...
I don't have the BSR (Bernina Stitch Regulator) and presume you don't either. I have found that I tend to move the fabric to quickly when sewing curves and circles. I did as you did and changed tension, stitch length...everything, but nothing worked. I finally found that the best solution was to SLOW DOWN on the curves. No problem ever since. I hope this helps you. If it does, please let Fixya know by rating my solution!
Nov 20, 2010 | Bernina Sewing Machines
My Bernina 1530 stitches are faulty - with loops underneath, even though it looks ok on top. When I remove and rethread the bobbin, the stitches are ok for 6-12 inches then start looping again. I tried to...
This is almost always indicative of an upper tension problem.
First, make sure you're using a good quality thread. If you're using thread that's not of European manufacture, you're probably filling your tension assemblies with little fuzzies. Coats and Clark Dual Duty is the most notorious thread for causing tension issues. If you have a bunch of this thread: throw it away or use it for hand sewing.
Turn your machine off, and use some canned air to blow out your upper tension assembly. (It looks like a couple of little cymbals inside the thread path.) Set your tension dial to 4.5.
When threading, right before you actually thread the needle itself, and with the presser foot up, "floss" the thread back and forth by holding the thread at the top by the spool with your right hand, and down by the needle with your left hand. This will ensure that you force the thread into the tension assembly.
Also ensure that your bobbin is oriented the right direction, but this would be a less common cause for your symptom.
If none of these fixes work, you probably need to have your tensions professionally calibrated.
-R
Mar 04, 2009 | Bernina 1008
Sewing Machines Logo
299 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
