Question about Exercise & Fitness
How to test your console when it's not respondingproform treadmill control panel
How to test your console when it's not responding)
    Top Expert:
  • 12,223 Answers
Adjust the REED switch, see the diagram attached, test for open or faulty. Clean it, and tight the connector very well.
God bless youHow to test your console when it's not respondingp - 60f81460-7a45-4a5a-ba47-93e98b045460.gif
However try to RUN the software calibration for easy diagnostic
Posted on Jul 09, 2013
4 Suggested Answers
SOURCE: Merit 725T. The treadmill has
Merit 725T. The treadmill has gone into a "10 degree" incline mode on its own, and will not respond to the control panel
Posted on Jun 16, 2011
ercupa190
  • 12223 Answers
SOURCE: My ultrafit treadmill won't run-the control panel
2_15_2012_4_45_37_pm.gifAdjust the reed switch as indicated by the diagram by 1/8- 1/4". Run the calibration software instruction under the Hood motor or see your user manual.
sincerely.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 15, 2012
ercupa190
  • 12223 Answers
SOURCE: TROUBLE SHOOTING VISION FITNESS TREADMILL
seethe video and proceed according. God bless you
Posted on Nov 28, 2012
My Z100 Tredmill screen will not reset or respond when any button is pushed on the console. The fuse on the board is good. The outlet is properly grounded. Need Help
Safety key is installed? No response from key presses usually indicates a "halt"state for the upper control "brains" like when the safety key is pulled. You can also try jatinah electronics for further help.
Feb 01, 2015 | Spirit Fitness Z100 Treadmill
Front console not working
Try this first: 1) Replace the batteries by new ones, clean the contacts batteries very well with c. cleaners.
2) adjust the REED swtich, test for open or faulty, clean it, and tigh the connector very well.
3) tight the ribbon cables inside, clean it, and tight very w.
4) see the diagram attached and try again.
God bless you
Dec 10, 2012 | Nordic Track NordicTrack T7 si Treadmill
Track 5500 Treadmill problem
Dear Sir:
Please adjust the Reed switch, see the diagram below 1/8-1/4" 2) Tight very well the ribbon cable from key panel 3) Tigh the connector from display board vs the lower board(main motor board).4)main motor board.can be faulty. 5) However RUN your software utility for easy diagnose and troubleshooting. see the block diagram attached.
2_18_2012_5_06_16_pm.gifsincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Feb 17, 2012 | Exercise & Fitness
Incline raises full and wont go down,t84
1)signal false coming console or display board
2) main motor controller is faulty.
3)Pot attached of the elevation motor ,need adjustment
4) geared slip from elevation motor , carring false signal to console.
Proceed to Test it.
Dec 11, 2011 | Horizon T84 - Treadmill
When standing on treadmill, if incline # ie:5 is entered, bed raises, pauses, then lowers back down while #5 continues to be indicated. this occurs with all incline #s but not a problem if I'm not sta
If your incline is not working it can be a few different things.
1)There may not be any signal from the console which could be a damaged cable tight the flexible cable vs keypanel( spray too with contact cleaner spray) vs display board.
2) the console itself has failed :tigh the connector comming to lower board (main motor controller board).
3)The motor control board may have failed from a worn treadmill belt and deck(exchange it) Test if the Voltage with DVOM is there present 120VAC
4) the motor may have burnt out Test the motor with 120VAC.
5)also a potentiometer geared to the motor so the console knows what height the incline is at ADJUST IT.
6) the gearing can slip, giving the console false information which can cause chassis damage FAULTY.
12_7_2011_6_27_57_pm.gifNow with the block diagram you will have strong resultant for determine what is wrong. This I did for people like you, and to know how the main motor board controls functions by 90% aprox of any treadmills. sincerely.
E.CUADR
MANAGUA, NICARAGUA. C.A
Dec 07, 2011 | RTO Sole F80 Treadmill
Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Nov 17, 2011 | Exercise & Fitness
I have a nordic Track EXP2000i that works for about a minute after it is plugged in but then the control console stops responding to buttons being pushed. The only buttons that beep are the 5 and 6...
hi,
check the other push buttons on the control console. if found faulty replace it. it is the only thing u can do in the control console. if problem remains u should replace the control console with a new one. for that u have to consult the manufacturer.
do one more thing before consulting manufacturers, remove the control console put out its circuit board. using a hair drayer heat the whole board. do not over heat.. then re fix it and test it.
ok
Dec 22, 2010 | Nordic Track Nordictrack Power Board...
Merit 725T. The treadmill has gone into a "10 degree" incline mode on its own, and will not respond to the control panel to reduce the incline.
Sep 21, 2010 | Horizon Fitness Merit Fitness 725T...
I turn my treadmill on and it immediately goes full speed
That sounds like a motor control that is shorted out,the only thing you can do is replace the motor control.When replacing the controller follow the instructions to calibrate it to the console.
Jul 06, 2009 | Nordic Track /proform Treadmill...
Exercise & Fitness Logo
27 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
