Question about Hotpoint RB790SHSA Electric Kitchen Range
Beeping Problem - Hotpoint digital clock and timer
Our stove started beeping randomly. the only solution we have found is to take the fuse out. when we put it back in there is a period of a few ours of peace and then it starts up again. otherwise oven and range work fine. ????????
  • 473 Answers
SOURCE: Hotpoint Gas oven doesn't light
Sounds like the oven ignitor is weak.  If everything else is working it must be a bad ignitor.  These are usually easy to replace and can expect to pay $70-$100 for the part.  Check to see if it glows when in bake mode first.  If it does then replace the ignitor.  You can look at the ignitor,  when not on, if it is white-ish then it needs replace or if it doesn't have a full glow, can compare to broil ignitor, then it needs replaced.  Let me know if you have further questions.
Posted on Oct 13, 2007
  • 473 Answers
SOURCE: self cleaning hotpoint stove
Sometimes in self clean it can burn out the element.  Need to check the element with an ohm meter and see if it shows resistance.  If it shows open then the element is bad.  If it shows resistance then the element is ok.  Next see if you are getting 220 volts to the element when in bake mode.  If you are not getting 220 volts then the control is bad.
Posted on Oct 21, 2007
  • 2651 Answers
SOURCE: kenmore stove top cermic range
you would need to replace entire glass top itself. part depending on model can run 300 dollars.(part only)
Posted on Mar 16, 2008
  • 1073 Answers
SOURCE: hotpoint glass top stove
sound as if you only have 120 volts going to the range check the voltage
Posted on Apr 12, 2008
SOURCE: Tappan Series 110 Gas Stove Owners Manual
stovetop works well, oven will not ignite. Whats up?
Posted on Oct 03, 2008
Is the gas valve easy to replace on a gas oven?
Posted on Nov 19, 2008
0 characters
1 Points
How to disconnect beeping hotpoint stove digital timer/clock?
Good Afternoon Patti,
I understand that your Hotpoint stove digital timer/clock is beeping and you are wondering how to disconnect it. I suggest resetting your stove by either unplugging it or disconnecting the power at your home's circuit breaker for 3-5 minutes. When power is restored, if your stove is still beeping, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what the cause of the beeping is. They will also be able to assist with repairs, if needed. Hope this is helpful.
-Best Regards-
May 06, 2014 | Frigidaire FEF336BC Electric Kitchen Range
F9 error message after power outage
The F9 is a door lock latch circuit problem, either the motor latch or the control/power supply board will need to be replaced.
Mar 22, 2008 | Jenn-Air JES8750 Electric Kitchen Range
I have a hotpoint older stove don't have the model # at this time. the digital display on my oven stopped working { stovetop works fine). After about 2 months of nothing all of a sudden it lights up...
The beeping indicates to me that the clock has power to it and it's the problem and needs to be replaced. ya need model number to order part it usually can be found on rim around door or inside of the bottom storage drawer, when ordering parts its call by 4 names, all are the same part its either clock, eoc,oven control,or relay board
Aug 03, 2011 | Hotpoint RB790SHSA Electric Kitchen Range
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
I have a Tappan gas stove. Don't know how old the stove is as the stove was in the home when I purchased it. Six years ago we had a power outage. When the power was restored the clock started beeping. Only...
Try disconnecting the AC to your range and leaving it overnight. If this doesn't help, the clock has probably been damaged by a power surge during one of the dropouts.
Oct 25, 2009 | Kitchen Ranges
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Constant beeping from the clock/timer
sound as if u got water in your controls which would cause the electronic clock assembly to short. unplug for 24 hrs to allow it to dry if the probelm coming back it eca is bad
Jun 01, 2008 | Tappan TGF320 Gas Kitchen Range
Setting Clock on Hotpoint Stove
push in on the center one I think
Mar 10, 2008 | Kitchen Ranges
Kenmore Stove Glass top
I have a Kenmore glass stove, not sure what the model number is I don't have it with me right now. Yesterday, the timer started to beep and F1 started to flash in the display. The stove top is working, but the oven does not. The only way I can get the timer to stop beeping is to unplug the stove.
Any suggestions as to what is going on with this stove. It's only 4 years old.
Oct 22, 2007 | Kenmore 46123 Stainless Steel Electric...
Hotpoint RB790SHSA Electric Kitchen Range Logo
47 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
John Tripp
John Tripp
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
