Question about Cycling
Shimano light action bar end shifter's exploded view required for 10 speed
I took the rear cog set bar end shifter apart - shimano light action - and I am not sure how to reassembleit
4 Suggested Answers
  • 18 Answers
SOURCE: Shimano st 7900 shifter,left lever apart and how to reassemble
You can download an exploded diagram of the 7900 series STI shifters here:
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-7900-2874E_v1_m56577569830670749.pdf
You can reassemble them according to this diagram.
Posted on Jul 07, 2009
johnegan84
  • 73 Answers
SOURCE: require assembly schematic for shimano dura ace
log onto Shimano.com, it is probably the limit screws (the two screws that limit travel) or you have a faulty ratchet in the lever, try the shimano website anyway they have great tutorial and manual support
Posted on Mar 27, 2010
dunnbiker
  • 8546 Answers
SOURCE: ive got campag 10 speed
All of the above since they should work with every gear.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Posted on Sep 24, 2011
Exploded view of shimano gear shifter altus st-ct90
Sorry, Shimano never intended those shifters to be taken apart and serviced, so they didn't release an exploded view. Here's a link to the orginial EV document. http://bernd.sluka.de/Fahrrad/Shimano/TM/ST-CT90_1995.gif
Mar 30, 2017 | Shimano Cycling
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Apr 08, 2015 | Shimano Tourney ST-EF40 3x7 Speed Brake...
Parts assembly diagram
Shimano Tourney parts are one of their lower end component groups and as such are not really designed to be serviceable. Shimano uses a system of "controlled obsolescence" so that their components cannot be repaired. they are inexpensive enough to just replace them, and with all of the plastic that they use these days it's not worth the effort when a new derailleur can be had for $30.
Apr 08, 2015 | Shimano Tourney ST-EF40 EZ-F 2-Finger...
How do sti shifters work?
there is a gear mechanism inside the shifter that uses a 2:1 ratio and is synced with the spacing of the rear cogs and the width of the chain. You cannot use a 9 or 10 speed rear shifter with 7 or 8 cog gear cluster. They are all integrated. You cannot use a SRAM shifter with Shimano gears, the ratio's are different (as a general rule of thumb, there are exceptions, but why mess with it?) Just remember that the shift, chain and rear cogs all need to be compatible and your drivetrain will work.
Feb 03, 2014 | Shimano Claris ST-2400 2x8Sp Shifter Brake...
Bicycle rear derailleur slips back to high gear.
It is likely that Phil has an old school Shimano Eagle rear derailleur.
I recently had a very similar issue with a Suntour friction shifter and derailleur. I tried replacing the shift cable and housing with no luck. Then I was told to replace the chain. Made no difference.
Then I took a closer look at my bike's shifter. I took my old one apart and the gear teeth that were supposed to keep the shifter from moving were worn down.
New shifter took care of it for me.
Oct 22, 2012 | Cycling
I have an old 12 speed racing bike with the shifters on the frame.i wish to either have thumb shifters on the handle bars or end bar shifters but i cant find either,any suggestions please
You haven't looked hard enough. eBay has everything. Unless you have a Campi drivetrain, go with Shimano or Suntour if you can find them.
http://www.ebay.com/itm/Shimano-6-speed-bar-end-shifter-6-spd-pair-shifters-/190569972448?pt=LH_DefaultDomain_0&hash=item2c5edb02e0
But they're 'spensive.
I recently acquired an old '84 Cannondale road bike (before they had model numbers) that had all original Suntour 2x6 with downtube shifters on it. Now it's a full Campi-Ergo-equipped 2x9 with FSA compact carbon crank, aero-bar mountain climbing road rocket.
http://www.cyclingcrowd.com/Uwe/Forum.aspx/technical/17391/Switching-to-Bar-End-Shifters
Sep 04, 2011 | Cycling
Hi Everyone! I have a Shimano 5603 Hollowtech 2 triple chainring.......(10 Speed) I want to add a Utlegra 6600 front derailleur and Ultegra 6600 rear derailleur. Also 10 speed cassette, Ultegra...
No -
If you are going to use the front triple crankset, then you need to use the 6603 components. These are for Triple set-ups.
If you intend to keep your bike a triple, then everything in the drivetrain must be the triple designation, hence the XX03.
If you want to change the crankset to a compact, then you can use the 6600 (double) equipment, but you will need to change the left (front shifter) to a double as well. The compact crankset, will give you virtually the same range as the triple and be much lighter and shift better.
The cassette: You can use any 10 spd cassette from Shimano or SRAM as long as the rear cog is no larger than 27. if you want to use a larger cog like a 28, then you will have to use the 6700 group, assuming yoiu want to stay with shimano ultegra.
Final Note: Since you are chainging everything, you may want to consider the SRAM Apex group, this gives you more gear ratio than the Ultegra, is slightly less expensive and around the same weight. Great alternative to Triple bikes.
Parts you will need to convert:
Rear Derailleur
Front Derailleur (if changing to compact double or Apex)
Chain
Shifter set (if Apex)
Crankset (if Apex or compact shimano)
Bottom Bracket (if Apex)
The biggest thing is that Shifters and rear derailleur must be from the same company (shimano, SRAM, etc.) after that just make sure that yoiu use 10spd with 10spd, 9 with 9, and so on. Everything else can mix and match.
Dec 18, 2010 | Shimano Ultegra Triple Front Derailleur Fd...
Shimano Deore LX right hand rear shifter
HERE is Shimano's exploded-view diagram of the shifters, but it really only gives you a ballpark idea of the assembly. You will have to piece the rest together from memory, i suppose. Sorry, i could not find more information for you.
Hope this helps a little,
matt
Oct 07, 2009 | Mountain Shimano Deore Bicycle...
May 11, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
Cycling Logo
94 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
