Question about Kitchen Ranges
Baumatic bwr1206 washing machine showing error code 2
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
SOURCE: Baumatic washing machine instructions
the twelve programs are explained on the detergeant drawer.if not i will post them for you.
to use the dryer turn the middle knob clockwise to the amount of time you desire upto 140 minutes then select the temperature on the far left knob and then depress the half load button your dryer should now work.
Posted on Jan 02, 2008
  • 45 Answers
SOURCE: error code on washing machie
The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too.
Posted on Jan 03, 2008
SOURCE: Baumatic BTWM6 washing machine flashing F02 error
hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Posted on Mar 18, 2009
  • 1416 Answers
SOURCE: Baumatic WQP12-9213 - Error Code 004?
hello
The "004" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while 004 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the 004 error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Posted on Jun 03, 2010
Testimonial: "Thank you for your help."
How to clear error code E 11
Which model do you have?
What happened that led up to the error?
If you are sure there is no problem or problem has been fixed, try the reset button.
Reset Buttons for Washing Machines
Nov 27, 2015 | Baumatic Washing Machines
Machine stops during the spin, especially with heavier loads.
Maybe you overload your washing machine. Minimize your washing machine usage to avoid stopping during the spin.
Aug 23, 2015 | Baumatic Washing Machines
Baumatic fault code E11 Baumatic BFLW75 60cm 7.5kg
Look under the machine, for a bag with the
diagnostic manual, they do not want you to find
You will need that to run a self check & get it working
again
Try unplugging the machine, but most likely it has
the codes stored on the circuit board
Aug 15, 2014 | Washing Machines
I have a baumatic class a 6KG 1100rpm washing machine and it is showing error code F04 - what does that mean? How do I fix it? Please help Rachel
I have had this same problem - you need to clean the drain as a starting point. You can do this by removing the front panel at the bottom of the machine (you will need a Torx head screwdriver) then gently unscrewing the filter on the bottom right hand corner. Keep a tray underneath though - as water will flood out as you remove the filter! If the filter is full of fluff, you should be able to fix the machine by cleaning it out and then putting it back in.
Dec 19, 2010 | Baumatic Washing Machines
hello
Jun 03, 2010 | Washing Machines
Error code 4 on baumatic bkd64ss what does this mean ?
Baumatic E4 error is caused by a float switch triggering in the sump of the machine. Anything over about 1/2 a pint in the bottom of the machine will lift the polystyrene float and the fault code will show. If the water has been caused by over enthusiastic cleaning or a drip or two over time then all that is required is for the water to be removed. For a built in machine (DISCONNECT THE POWER) then just unclip the front bottom right hand black plastic cover (behind your kitchen kickboard). Using a jcloth or similar mop up and the fault will clear. Replace the cover and restore the power and kickboard.
Feb 14, 2010 | Baumatic 23 in. BFD61SS Free-standing...
Baumatic MEGA WDSS washing machine
go onto manualtree.com type baumatic megawdss washing machine, if this does not bring anything up scroll down until you see it in the listings. type in the code it asks for (this will be supplied underneath, its just to stop cumputers auto logging) and then download then manual. good luck
Jul 02, 2008 | Baumatic MEGAWDSS Front Load Washer /...
Code E2 showing in temparature display
I contacted the technical team at www.baumatic.co.uk and here is the reply I got.
-----Original Message-----
From: Samantha.Codd@baumatic.co.uk [mailto:Samantha.Codd@baumatic.co.uk] On Behalf Of Technical@baumatic.co.uk
Sent: 25 January 2008 13:02
To: Taline Bedrossian
Subject: Re: BWE40 wine cooler
Good Morning.
Thank you for your e-mail.
This error code means that your appliance has experienced a defrost sensor
fault. Please contact our service team on 01189 336 911 to arrange a
suitable time for an Engineer to visit you.
Kind Regards
Quality and Technical Department
Baumatic Ltd
www.baumatic.co.uk
Jan 19, 2008 | Baumatic BWE40 Wine Cooler
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
