Question about Vehicle Parts & Accessories
Ldv maxus white smoke and oil coming from exhaust but drives
3 Suggested Answers
SOURCE: how is the central locking meant to operate on an LDV Maxus Van
the central locking can be programmed to either unlock and lock all of th edoors together or by opening the drivers door with the first press of the fob and then unlocking the doors with the 2nd press. the load doors will then lock after a pre determined time for security
Posted on Nov 30, 2009
SOURCE: How do you program remote central locking on ldv
it sounds like its either the fob or the esa unit if its the unit it needs to be programmed by an LDV dealer using the diagnostic equipment
Posted on Feb 26, 2010
Blueish white smoke comeing from exhaust
Hello There
White smoke when first started is normal. If white smoke continues you have an internal coolant leak, i.e., cracked head/blown head gasket.
Black smoke is caused by a rich fuel condition.
Blue smoke is caused by oil consumption.
You need to check your oil cap for yellow/white gunk on the cap if you have this then this is a sign your head gasket is cracked. Check to see if your radiator coolant level is down this is also another sign.
Hope this helps. Please don't forget to rate me.
Many Thanks
May 20, 2009 | 2004 Chrysler PT Cruiser
White smoke out of exhaust
Regarding 2001 audi a6 quattro 2.7t....i was driving to work the car was fine then white smoke starting coming from under the hood and tail pipe. i stopped veilce and alot of oil was dripping from front of car. I towed it home and i looked under the hood and there was oil from valve cover gasket. i let the car sit for a few days, had it running again for a good hour and no white smoke was coming out. I removed the valve cover and gaskets are all bad. i want to know can the valve cover gasket leak cause the white smoke to come from exhaust pipe?
Jan 11, 2014 | Cars & Trucks
How to fix 5th gear on my ldv maxus
Its likely you have a problem with the clutchnot completly disengageing or problems with disk or pressure plate
Jun 13, 2013 | 1997 Chevrolet Cargo Van
White smoke coming out of the exhaust when starting the engine?
Its the problem of oil.The oil is getting burned out. The vehicle is either burning oil or it is moisture in the gas chamber if you notice white smoke from the exhaust. This is a common possibility.but in some cases this white smoke is not due to oil burning.In that case   White smoke from the exhaust is a symptom of coolant entering the combustion chamber. Normally this is a sign of a blown head gasket or cracked head. And  this is not a common problem must be repaired immediately. You must STOP driving this vehicle or you will cause serious engine damage. you will have to get both this possibilities checked.
Thanks. you can rate this solution and show your appreciation.
May 20, 2010 | 2001 Volkswagen Golf
How do you program remote central locking on ldv maxus as the remote is sending out a signal as we ahve had this checked but it doesn't lock or unlock the van
Feb 16, 2010 | Vehicle Parts & Accessories
White smoke out the exhaust
You will need to check head gasket. Please check the oil for coolant (milky deposition or presipitation). Also check if you loosing coolant and if coolant has oil in it.
Please kindly let me know if you need more info
Good Luck
Feb 14, 2009 | 1990 Ford F150
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
