Question about Sony P6-120MP 8mm Tape
How many hours on a p6-120MP tape - Sony P6-120MP 8mm Tape
I cannot find my manual what is the speed to record on the vcr for 8 hours
Unfortunately, most VCR recorders/tapes don't have an 8 hour option. It is 2 hours on SP (standard), LP for 4 hours or EP (SLP, depending on the unit) for 6 hours. (The slower recording speed usually gives poorer video quality.)
You would need a non-standard VCR cassette to get 8 hour recording. If you do have a tape that would hold 3 hours at SP, then use an EP setting to get 8 hours of recording on your VCR. I don't think I've seen any tapes that do that recording length even when VCRs were popular.
I wish that I had better news.
Jan 28, 2012 | Sansui COM311AD 13 in. Combo
I have a VHS tape that has an hour worth of recorded material on it, but when I play it, it plays the first 11 minutes, then it goes to static and the counter stops counting. I can fast forward but when I...
You may think the tape has an hour of material on it, but the machine thinks otherwise. Either it didn't actually get recorded past the 11 minute point, or something erased the tape past that point. There's nothing to play after that time, so you're seeing the snowy screen. On most VCRs, the tape counter only works when a valid video signal is detected, which is why it's not advancing as the tape plays. There's nothing you can do to recover whatever was on the tape, so I hope it wasn't anything important.
Aug 11, 2011 | TDK E-HG 120 VHS Tape
When recording two vhs tapes back to back on one disk, it will not finalize. But, will finalize if one tape is recorded. Mind you now each tape only has one half an hour recording on them, and the disk is...
The disc requires some space for the finalizing process. Two half-hour tapes take up all the room on the disc and leave nothing for the process. You'll need to record at a lower speed.
Feb 26, 2011 | Cameras
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
Apr 10, 2009 | Sony DSR-11 DV / Mini DV VCR
Adding several short video tapes into one dvd
Yes, change setting on dvd recorder, consult manual.good luck.
Mar 25, 2009 | Televison & Video
Magnavox zv450mw8 Walmart VCR/DVD recorder. shuts off
on vcr's if the tape is hard to turn the tape will sense this and reject the tape. Try to get a tape that you can feel turn free eaiser. I would rewind it to the middle of the tape so each side is equal and it would make the tape run easier. If it runs ok then the unit is bad and is too sensitve to the pull on the tape. This is all designed in the electronics and there is not much you can do about it then get return it if you can.
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Tape life
it depends on which tapes are used.. it should be on the packing of the tapes themselves, it should tell you how many write cycles they are good for... just like video tapes and audio cassetes these tapes wear out in the same way.
Aug 06, 2008 | TDK Computers & Internet
Sony SLV 660HF
the problem seems to be with with the door. Mine dose the same thing I have to
hold the door open with my finger so the tape will not catch.
Jul 28, 2008 | Sony SLV-660HF VHS VCR
How Long Can I Record?
HS Mode STD mode LS3 Mode Tape: (1080i/720p): (Better than Mini DV): (DVD Quality): DF-300U 2.5 Hours 5 Hours 15 Hours DF-420U 3.5 Hours 7 Hours 21 Hours DF-480U* 4 Hours 8 Hours 24 Hours
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Sony P6-120MP 8mm Tape Logo
32 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Computer Links
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
