Question about Refrigerators
Rla34 what is wrong if the circle in the fridge is black not green
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: i have a hotpoint future
Hi and welcome to FixYa, I am Kelly.
What your seeing is the result of an automatic defrosting problem. One of three things has failed
1. Defrost Control (most common failure)
2. Defrost Heating Element or
3. Defrost Thermostat
A refrigerator must automatically defrost 2 to 3 times a day or you will see the symptoms you are experiencing now. You can do a manual defrost by unplugging the unit and direct an external fan into the freexer compartment for just over 2 hours to get the temps down again. The only thing is after about 2 days the ice build up gets to the point that your freezer temps start warming up again. The correct remedy is to repair the automatic defrosting system.
Thanks for choosing FixYa,
Kelly
Posted on Apr 13, 2011
  • 747 Answers
SOURCE: my hotpoint fridge RLA34 isnt keep my food cold
you'll cooling coils may be dirty thermostat may be going bad or it might be just a setting worse case a coolant leak requireing a repairman
Posted on Jul 30, 2012
Can you tell me where the drip tray goes on the hotpoint rla34 fridge please
Usually at the bottom after you remove the kick bracket in front.
Jun 12, 2017 | Hotpoint Refrigerators
The bobbin case went ajar while sewing blue jean fabric. I cant figure out to put it back in. Your help is very much appreciated :
Hi Debbie,
This type bobbin case can be a pain to get back in. On photo #1, at the top left you see a silver piece (circled in red) with a rectangular hole in it (circled in green)...take a flat head screw driver and insert it into the slot then twist to the right so the little bar/flange (circled in blue) will twist to the left past the bobbin well wall (marked in neon green). Photo #2 Now the bar/flange (marked in blue) should be on top of the bobbin well wall (marked in neon green). Now set the bobbin case in the bobbin well (marked in pink). Photo #3 as you set the black bobbin case in, kind of angle the flat part that is marked by the orange X so that it will begin to underneath the bar/flange with large orange circle. It won't go in all the way but just start it and then set the rest of the case down in the well. Now twist the entire black case to the right and the flat black are marked with the orange (X) should slide underneath the bar/flange marked with orange circle. The flat piece marked with a purple (X) should be sitting in the area marked with an (X) in the bobbin well. Now take your screwdriver and stick it in the rectangular box and twist it back so the silver piece marked in blue with go back over the edge of the black bobbin case to help hold it in. Hope you can understand my instructions and good luck!
Apr 11, 2016 | Singer Merritt 8734
I put in the battery pack and the green button blinks 2 at a time the shuts off
Make sure the batteries are fully charged. If their not, that could be whats wrong. But other than that, something could be wrong with the connection from the xbox to the controller? Try turning the xbox on, then clicking the little black button near the power button. On the controller theres also a little black button, by where you would put in another battery pack, click that when the xbox has the green line going in circles. If those two don't work, then something could be wrong with the wiring in the controller.
Nov 24, 2012 | Microsoft Xbox 360 Console
My hotpoint fridge RLA34 isnt keep my food cold
Jul 30, 2012 | Hotpoint Refrigerators
I have a hotpoint future fridge - inside the door there is a black circle which used to have OK in the middle and it used to be green - this is now black - also the back of the fridge is frozen
Kelly
Apr 13, 2011 | Refrigerators
Sony wega 28 inch colours wrong, circle on screen
It sounds that there is some magnet near by TV that is affecting picture tube. Please remove any extra speaker or any thing that has strong magnet inside, unplug TV for 20-30 minutes, replug back in, turn it ON, hope that will solve your TV problem.
Thanks.
Nov 16, 2009 | Sony WEGA KV-28HX15 28" TV
Thermostat
HI, your intuitions are correct. this is defiantly a thermostat issue here. replacing this defective thermostat will fix this abnormal issue you are having with your unit.
When a unit of this nature cannot control the Coldness level, it is always due to a defective thermostat.
Jul 08, 2009 | Hotpoint Refrigerators
Fridge dont get cold.
If the compressor is running then it could be one of the following:
The compressor isn't pumping properly. The thermosat has failed. It has lost refrigerant or there is a blockage.
Not alot of help I know but without seeing the fridge it's hard to say.
Feb 22, 2009 | Refrigerators
Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
Jun 07, 2008 | Fisher and Paykel Active SmartĀ® E522BR...
Green circle on the screen when I turn off TV
there is something really something wrong with your tv.try to reheat the main board.
Oct 30, 2007 | Sony KV-27FS13 27" TV
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
