Garden Logo
A
Anonymous Posted on Jul 08, 2013
Cub Cadet Wiring Diagram for an ignition switch 1330 model
5 Related Answers
Anonymous
  • 15935 Answers
  • Posted on Feb 20, 2009
SOURCE: A short in the pto wiring perhaps?
Form what you are desribing you have a direct short, probaly in the wiring going to pto. I t has rubbed somewhere and is causing your short. Unplug the wires at connector close to your pto clutch and try it again and see if fuse stuill blows after you unhook it.
If the fuse still blows it is in the wiring going back up to thje switch. If the fuse does not blow after unhooking wiring connector the problem is in the clutch.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jeremy Burns
  • 8 Answers
  • Posted on May 04, 2009
SOURCE: Cub Cadet 1610 Drive Belt Diagram
Go to Cub Cadet. com and click parts. Type your model number 1610. You will see parts diagram. Click that. It will show a long list of parts to click on. Choose drive and it will show you a diagram of all the pulleys and how the belt looks. Hope this helps. I had the same problem.
Anonymous
  • 246 Answers
  • Posted on May 11, 2009
SOURCE: i have a cub cadet model 3 1042 it starts but
Hello
After the Engine Stalls, Check the Plug for Fire. If No Fire then the Ign Module/Coil is BAd and Requires Replacing.
>>The Following is a Basic Instruction File I made for this. Any Input is Appreciated. I Usually Suggest you Check the Following in this Order for a Problem like yours. 1- Check the Gas Tank Cap and Ensure it is Venting the Tank. A Vacuum Builds in the Tank and the Gas Flow Stops or Slows (15 to 45 Minutes and if the Small Grainular Sand is in the Tank it can Take Several Days of Constant Running to Bring All the Sand Particales to the Tank Outlet Port) to a Point it Shuts Off the Engine. 2- Operate the Equipment Until it Quits (15min to 1hr). Then Immediately Check for Fire from the Plug. If the Plug is Firing, then 3- Check the Carburetor Solenoid. If the Carburetor Shut Off Solenoid has Current, then Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 3/4" Long. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid. ***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES*** Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jets. 4- Depending on the Model Mower, it can Also be the Pickup Tube in the Gas Tank. If No Fire, then Remove the Shut Off Wire from the Coil and Check for Fire. If Still No Fire, then the Ign Module or Coil is Bad. **Even if the Coil is New of Fairly New, it can Still be Bad.** On JD Mowers; Remove the Igniter/Module and the Coil and have the Local JD Dealer Test them.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on May 20, 2009
SOURCE: belt installation for a cub cadet lawn mower
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051
Anonymous
  • 10 Answers
  • Posted on Oct 18, 2009
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
3answers
My cub cadet shut down when I got off and will not start again. Nothing happens when I turn the key.
Most Cub Riders require the PTO OFF, brake ON, and ignition switch in START position.
Cub Cadet wiring diagrams are usually included in the parts diagrams. See the following URL.
https://www.cubcadet.com/en_US/service-and-parts#part-finder
If you can't locate a wiring diagram, comment below with the model number and I'll try to locate a URL.
3answers
My cub cadet LTX 1045 will not start. I parked it the last time I used it and it ran fine. Engine turns over, gas in the carb; but no spark. Safety switches all look ok. Oil level is fine.
Brake switch
PTO switch
Seat switch
RCM / reverse switch
Could be any of the above.
Troubleshoot by checking continuity from the M (magneto) pole of the ignition switch to ground. It should be open (no continuity from M pole to ground.
Methodically disconnect switches until M pole to ground shows open. Then test suspected switch.
A DMM or an inexpensive auto circuit lamp tester will do.
Wiring diagram;
https://www.cubcadet-parts-direct.com/cub-cadet-parts-diagrams/cub-cadet-ltx1045-tractor-2013-13ax91at010-2013-13ax91at056-2013-13wx91at010-2013-13wx91at056-2013-electrical-schematic/AD-4285-4664-168112
1helpful
Cub Cadet 2150 ignition problems. Need a wiring diagram to source problem.
don't have a diagram but i would check the safety switches jump them while looking for the bad one with a paper clip
Top Garden Experts
Jay Finke
Jay Finke
john h
