Megmeet mip 320 - Televison & Video
What does the inlet hose end look like?
Let's make sure we're in the right category. Is this a clothes washing machine or a dishwasher? If a clothes washing machine, there should be a hose inlet for the hot water and another for the cold water. The fittings will be the same, but one should have a C or "Cold" stamped or labeled next to it and the Hot an H or "Hot" next to it. Unless the machine is really old or maybe not from this country, the hose fittings should be standard.
If you're referring to a dishwasher, then there will only be one inlet for a hot water line. The fitting is probably a 3/8" MIP and will require a 3/8" MIP line. There a special dishwasher installation kits that come with the hose and common fittings which might be your best bet.
Nov 21, 2016 | Washing Machines
Where is radio fuse in 2005 Jeep Grand Cherokee?
which box.? well its marked, radio and in 1 min flat you cant
look in both?
see chapter 8w, see index see radio....
http://colorado4wheel.com/manuals/Jeep/WK/WK%20FSM/
fsm covers all that, and 10k morel.
radio or radio AMP?
fuse 28
in the MIP.
there are 4 fuses associated with radio, amp, media center, and remote radio controls, (no symptoms stated so....)
fuse 1 kills amp
fuse 27 kills monitor system DVD
open hood to see MIP (module integrated power)
see left side (right facing rear of car)
#1 is PDC
#2 is MIP, or IPM. (module int. power )
Mar 02, 2015 | Jeep Cars & Trucks
I HAVE A MEGMEET MCL386X CHANGED 3 CAPS ON SECONDARY SIDE ,NO LUCK .NEED SCHEMATIC OR INFORMATION ABOUT TRUBLESHOOTING OOWER SUPPLY THANKS
Sch. is hard to get for this brand. Is it similar to this one? http://s807.photobucket.com/albums/yy352/budm/MEGMEET%20MLT198A%20REV1_4C/
I google MCL386X and not much comes up, it may have more numbers on the board.
Are you at least getting the 5vdc standby? You must have this standby voltage for anything else to work.
Send me good clear pictures, budmrtn@aol.com to see what I can do for you.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 01, 2010 | Televison & Video
T.v. won't turn on
The following parts can be purchased at digikey.com or mouser.com web site. I am also posting all of the things I have found so far with these TVs.
Here are few possible solutions:
If you have no red light and you have a Megmeet MLT386 power supply, check these parts:
1) Swollen caps on the secondary circuit (may cause the red light blink problem, but also see below).
2) Blown fuse F1 (5A/250V) this is caused by a shorted FET at QA1 (20N60), you may also find that SMT cap CX23 is burned up (.001uf) which is in parallel with diode DA2 which may be damaged/shorted, replace these components.
If the power LED goes from red to green when powered up but no picture, then it might be lost +24VDC from the power supply:
3)Check fuse F2 (3.15A/250V, I put a 5A in), if it is blown, replace FET at QA2A (9N50C), replace QA2 as well (9N50C). Check SMT resistors at R233,R234,R235,R236 (.47 ohm). If open, replace with .1 ohm 1W or 2W resistor (easier to source). Also replace SMT transistor QF1 (2X4 or 2N4401 NPN transistor). And replace diodes at DS2 and DS1 (HER207), DS2 was shorted, DS1 was ok but I replaced it anyway.
I dont know as much about the Megmeet MLT169A, but it has similar problems and similar components.
4) I had to replace all of the capacitors in the secondary circuit (there are six in a 3x3 row marked EC9 (1000uf35V),EC10(1000uf35V),EC14(470uf35V) and EC18,EC19,EC20 (all 1000uf35V).
OK for the Megmeet MLT169A with red flashing LED when turned on I found that IC7 was bad. This is an SMT component on the solder side of the power supply. It is a 4407P (P channel 30V MOSFET). For testing purposes, we jumped across it to feed +5V to the TV permenently instead of allowing +5V to go into standby.
Aug 19, 2009 | Akai LCT3785TA 37 in. LCD HDTV
MEGMEET power supply. part no. MLT386X
I HAVE PROBLEM TO GET THIS POER SUPPLY TO BUY WHERE I CAN GET IT PLEASE
Dec 09, 2008 | Televison & Video
Cannot Access Internet from the DMZ
If there is proper policy in place then there wont be any issue.
if at all you need to access your DMZ from internet you need to configure VIP or MIP on the firewall and also a policy needs to be written to permit the traffic.
If you need more help you shall contact me.
Oct 10, 2008 | Juniper Networks SECURE SERVICES GATEWAY...
Is Axim ARM or MIPS?
The XScale processor in the Axim is compatible with the StrongArm (a.k.a. ARM) processor. When obtaining software, treat the Dell Axim X5 (or any other Windows CE device that has an XScale processor) as if it had a StrongArm processor in it.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Jornada 565 - Downloading software - format
Hi, MIPS, SH3, and StrongARM are types of processors used in handheld PCs. Some software requires a specific processor to run. For instance, Microsoft Pocket PC 2002 requires a StrongARM processor. The Jornada 565 has a 206MHz StrongARM processor.
Sep 12, 2005 | HP Jornada 565 Pocket PC
Help a new guy out PLEASE
1. Pocket PC is the OS by MS, H/PC is the the old handheld PC, bigger than PDA, smaller than a laptop, Hp made some nice ones. P/PC I thought denoted the Pocket version or PDA instead of handheld. I do not think people use H/pc or P/pc anymore. 2. Back in the orginal days there were 3 processors, MIPS used by casio, SH3 I believe the original Jornadas had it or were they MIPS, ARM is by Intel and Samsung (I think makes it for the 1945 and is what most if not all PDAs use now.
Sep 06, 2005 | Casio Cassiopeia E-100 Pocket PC
How to install emulators???
Try copying gx.dll into your windows directory or any directory the emulators are in...
Sep 06, 2005 | Casio Cassiopeia E-200 Pocket PC
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
