Question about Garden
Torro Lawn Mower side discharge spring
How do you attach the side discharge spring that holds the side discharge door down? It came detached and I can't figure out how to place the spring where it holds the door tightly down. So you can attach the side discharge chute and it will stay tightly secure. I've searched everywhere.
    Master:
  • 969 Answers
There are 2 bolts with nuts that mount the spring/door assembly to the mower deck.
Posted on May 29, 2014
3 Suggested Answers
  • 36 Answers
SOURCE: This is my second mower. First one damaged after
it could be a low lift blade on it. try to get gator blade for mulching..... or a high lift blade. lol, size does matter!!! this may fix the issue. there is so many blades out there now, experiment till you find what your looking 4......
Posted on Sep 22, 2010
vincob
  • 718 Answers
SOURCE: Spring which holds the rear discharge "gate" tight
Go jackssmallengines.com browse around and you find what you seek. Good Luck...
Posted on Jul 20, 2011
The spring fell off the throttle and I dont know how it is supposed to be reattached
Go to any Briggs and Stratton dealer and they will print you off a schematic to show you where and how it attaches.
May 10, 2016 | Mtd Yard Machines 158cc Briggs and...
I need to installhow to install a new deflector on Craftsman mower model 917273130?
Very simple. The 6 inch or so pin that holds it on is retained by a clip on one end. To remove clip use a pair of pliers. If you work steadily and carefully you will be able to reuse this clip. After removing clip, pull the pin out. Old deflector and spring be removed now. To get the spring right you have to try it in position before installing it. Just remember that the spring is holding the deflector down so when you are done installing, when you pick up on the deflector there is pressure holding it down. Don't put the pin clip on until you verify the spring force is correct because getting that spring clip off is the Hardesty pay off the job.
Oct 11, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I open the case around the pull cord on a Torro 22" recycler lawn mower?
It's been a while since I pulled one of those engines apart - the LV195 engines came in 2 versions. One has a detachable recoil starter that is held on by 2 screws, the other is an integral part of the cowling. Either way, the repair procedure is the same - remove the starter, or entire cowling as appropriate (may need to remove some plastic and the tank first), remove label on top, SUPPORT THE ASSEMBLY ON A DEEP WELL SOCKET or similar and drift out the central roll-pin into the centre of the socket drive the pin from outside to inside. If you don't support it, it WILL bend and make it useless. Make a note of the order of the washers and springs etc, then fit a repair kit.
May 03, 2014 | Toro Recycler 22" 149cc Personal Pace Lawn...
How to replace the cranking pull cord?
Ok, the spring will more than likely unravel when you remove the pull cord cover/assembly. There is notch in the spool for winding the rope around it. So make sure the spring is wound enough to fit it in the housing. Then take the rope, already knotted and in the spool. Turn the spool in the direction that tightens the spring.Push down on spool and allow spring to retract the rope. (Don't forget to tie the knot in the rope handle before placing on mower). Then lightly clamp in vise or visegrip, or channel lock pliers. I like to use visegrips on one side, and channel locks on the other. Place over the square flywheel nut,release channelock pliers, hold with fingers tightly so the spring does not unravel. Then release visegrips and hold with other free hand, Place over flywheel nut and slide down. Re-attach with screw previously removed. Your done. Don't forget to tie the knot in the rope handle before placing on mower.
Mar 28, 2014 | Mtd 22" Yard Machine Push Mower
How do i replace the side flap door on my mower
There is a rod that acts like a hinge pin. There is also a spring that keeps the flap door closed. The rod goes through both the flap and the spring at the same time. You need to hold the spring under tension while sliding the pin into both pieces at the same time. A little bit tricky, but do-able.
Hope this helps.
Jul 28, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Jul 19, 2011 | Toro Power Lawn Mower
This is my second mower. First one damaged after hitting a rock. My replacement mower will not discharge grass out of the side discharge. I have the mulching attachment in and the discharge chute as...
Sep 21, 2010 | Worx 19-Inch 24 Volt 17 Ah Mulch/Bag/Side...
I have a lawnboy self propeled mower model #10533. the serial number is 6907889. i do not know where the spring-choke return spring goes. if i had a picture of it installed i could do it becuase i am not...
For getting big view of picture please click on the link below http://www.ask.com/bar?q=lawnboy+self+propelled+mower+model+%2310533&page=1&qsrc=19&dm=all&ab=5&u=http://www.partsandservice.com/html/Lawnboy/Lawnmower/10533.html&sg=jTUCMw17SUPaA/y4FH3G/QzzCbOKvHGnvkxGP%2Bp36m4%3D&tsp=1276102809824 Part number 5 is what you want to see in the fig and fit. 1 1 Housing, Deck (Incl. Ref. #2 & 40)
2 1 Decal, Danger
3 1 Decal, Deck
4 1 Shield, Trailing
5 1 Spring, Extension
7 2 Screw, Hex Hd.
8 1 Ramp, Discharge
9 2 Screw, Shoulder
10 2 Clamp, Hinge
11 2 Bolt, Wheel
12 2 Knob, Arm
13 2 Washer, Flat
14 1 Seal, Door
15 2 Screw, Thread Form.
16 1 Brace, Door
17 2 Pin, Hinge
18 4 Nut, Lock
19 1 Decal, Warning
20 1 Door, Discharge
21 1 Panel, Vertical
22 2 Spring Arm ***'y, Front
23 2 Bushing, Door
24 1 Cover, Access
25 2 Hanger, Shield
26 1 Cable, Door
27 1 Handle, Hood
28 2 Screw, Tapping
29 3 Screw, Tapping
30 2 Seal, Door Side
31 1 Seal, Door End
32 2 Tire & Wheel Assembly, 8"
33 4 Washer
34 2 Arm, Pivot
35 1 Bracket, Discharge Ramp
37 1 Panel, Screen
38 1 Screw, Thread Form.
39 2 Bolt, Shoulder
40 1 Decal, Warning
41 1 Decal, Instructions
42 2 Cap, Hub
43 1 Decal, AppliqueThis are the parts in your mower.Thanks. keep updated for any morequery.you can rate this solution and show your appreciation.
Jun 09, 2010 | Garden
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
