Question about Motorola Mobility E815
Bootloader usb init
The last few dyas i have had terrible reception on my phone and when i tried to use it today it gives me the blue screen that says bootloader usb init. I have tried everything and cannot get it working.... So do I lose all my #s and pictures now?
  • 1 more comment
  • Anonymous Nov 05, 2007
    it just says bootloader usb init
    i took the battery out; tried drying it with a cell phone even though it seems dry
  • lady dro Dec 24, 2008
    my phone shows a blue screen and at the bottom it says bootloader usb init
  • phllip_thorn Jan 01, 2009
    my phone willnot turn on, charge. the only thing it will do is when i plug it in to charge it, it will only put up a blue screen bootloader ect.. I need my contact numbers, please help. email: [email protected]
I have the same problem and emailed Motorola for advice. I didn't tell it was because my 9 month old was chewing on my phone. They to press the Menu key and the left soft key and that this should return you to an "idle" screen where you can scroll through the menu or place calls. Failing that try the left, then menu then left again. If it still does not work remove the battery for 10 to 15 seconds, reinsert and that should do it. This did not work for me so I'll try to let it air out for a few days and try again. Good luck.
Posted on Nov 11, 2007
Mine did this too, Remove the batery and look at the moisture indicator. Is it red? The indicator is a circular white "dot"...looks like a sticker. If it is red, you have moisture damage. Take the battery our and let it dry out......for awhile. It may begin working again. If it has a red dot, you might be out of luck with your provider unless you have insurance. I bought a new identical phone on e-bay and programmed it. Pne day I pulled out the old phone to retreive the battery and use it on my new phone and voila! The bootloader screen was gone! I took it to my provider and had them pull the old contact info off. This phone now can be reprogrammed by my provider. Weird.
Posted on Aug 27, 2007
SOURCE:
Screen is blue motorola logo says bootloader usb init when try to shut off black screen says verizon tried taken battery out same problem. Thanks
Your phone is starting in flash mode..You need to have either p2k phone tools or motorola phone tools..you can get them from www.modmymoto.com. once you have the software on your PC connect your usb cable and reload your phone
May 11, 2010 | Motorola Mobility VU204 Cell Phone
I'm getting a bootloader usb init screen
Your phone is partly fried. It needs to be re-flashed. You can do it with a USB cable and the proper software....Google "bootloader USB" for some help in finding the software. One thing to try, hold down the "*" and "#" keys while powering up the phone, this could possibly help, but I doubt it.
Good Luck!!!
Apr 24, 2010 | Motorola Mobility RAZR V3c Cellular Phone
Blue screen with " bootloader usb init" message
go to service center. need to be reprogram. tnx
Jul 28, 2009 | Motorola Mobility RAZR V3
Bootloader usb init
hold the end key(power) and it should restart back to normal. If it goes back into bootloader then your phones software could be corrupt or could have a wrong value in somewhere. What provider is this?
Jul 23, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Bootloader usb init
This means that the phone firmware is corrupt - you can try to reflash it using Motorola software update, but it might not work for a phone stuck in bootloader mode:
https://rsddownload.motorola.com/download/Motorola_Software_Update.exe
Jul 01, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Bootloader USB INIT
Get this Phone reflashed. Of course if you Dropped the Phone or if it went into water then Forget it about spending 35-50 Bucks on reflasing this phone. because it will go back to Boot Mode.
Sep 06, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Bootloader usb init
basicly the software is corrept.take it 2 a cell 4ne repair shop they will fix it it cost about 150.u cnt do it on ur own coz it takes a specail soft ware n only certain ppl have it
Jul 28, 2008 | Motorola Mobility RAZR V3
Blue screen Bootloader usb init I was charging my phone and when I went to use it I couldnt the screen was blue with the Motorola symble and it read Bootloader usb init I have tryed removing the battery...
take out the battery and sim card and youwill see a metal bended thing beside of the sim card insert placing not on it on the right hand top press it down or bend it and your phone will reset your memory of your phone will not be erased
Apr 12, 2008 | Motorola Mobility RAZR V3
Bootloader USB INIT
Same thing today. Can't get it to turn on, charge or anything. I was warned not to get this phone by Alltel, that there was major problems with it, they even showed me a memo sent around to all dealers. That due to all the problems with the phone that it would be cheaper to replace/try to repair...then recall. I heard that newer versions of this phone are better, minw has been ok until now...mfg.date 2/07...
Aug 20, 2007 | Motorola Mobility E815
Motorola Mobility E815 Logo
132 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
