Im trying to program my Charter cable remote to control my samsung dvd/sound system and none of the codes provided will work.
SOURCE: Code Number for Remote Programming
Here is the link for the 8300 user manual if you need it; http://www.cox.com/support/digitalcable/dvr/pdf/SA8300HD%20connects.pdf here is manual for the dvd player http://www.yamakawa.it/dload/2xxenglish.pdf Not sure but try 438 or 445 as a code for your dvd, 445 most likely to work. (here is the link i got that from); http://dogbytecomputer.com/codes.htm#DVD%20CODES if this doesn't work then find a universal remote that you can get hold of easily near you and tell us the model number, we could probably tell you if it will be compatible with both machines and what the codes are. Hope this helps :)
SOURCE: Samsung program codes for ht-q100 Remote
You can try any of these 006, 011, 014, 015, 019, 027, 036, 037, 077
Hope this helps..
SOURCE: remote control not working and need programming code for cable television/universal remote control
remotes.com says oerseas item-not available?
SOURCE: Comcast 3 in 1 Universal Remote code for Samsung DVD-V5500
I had the same problem trying to use those three codes with a Samsung DVD-R155 recorder and then downloaded the pdf files for all of Comcast's remotes and came up with two codes (1) 20490 and (2) 21470. The second code worked for me. Hope that this will work for someone else.
SOURCE: Need product codes to program Universal Remote
I have the following toshiba codes
10154, 11256, 10156, 10093, 11265, 11060, 11356, 11369, 11524, 11635, 11656, 11704, 11918, 11935, 11936, 11045, 12006, 11343, 11325, 11306, 11164, 11156, 10845, 10832, 10822, 10650, 10149, 10036, 10070
