Question about Optoma Projector Multimedia Projector
Toshiba laptop won't work with new optoma projector
My Toshiba M35X laptop will not project the screen to the wall using a new Optoma EP716 projector. I've followed all the directions in hooking it up, including not cutting on the computer until after the projector has been turned on (and tried it the other way just to check and see if that would work). I'm trying to project a powerpoint presentation on the wall. The projector goes through the searching mode, but doesn't detect my laptop.
  • 2 more comments
  • jancart Aug 26, 2007
    Thanks for the help. I lowered the resolution and that worked!
  • chickieDP Sep 09, 2008
    Don't know how to lower resolution on my Compaq Presrio 2200...so hopefully it will project using my Optoma DLP 716 projector
  • Up533 Sep 26, 2008
    My new optoma DLP projector does not detect my laptop which has win xp home edition in it. but it detects my friends laptop which has vista installed and works perfectly fine.... i have checked all settings... on both the laptops but unsucessful. please help
    thanks in advance
    Upendra
  • dcabrera Nov 07, 2008
    my computer detect the projector but when i press F7 it doesnt show nothing.
Change the VGA cable...the cabel you are trying now may work with normal LCD moniter...but LCd tv required good sheilded cable..please try changing the vga cable..i tried with teh VGA cable comming along with BENQ lcd monitor works fines with almost all laptops..check teh screen resolution also.
1024*768 screen refresh ration 60 Hz..
Good luck..
Bijo varghese
[email protected]
Posted on May 13, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Posted on Aug 26, 2007
SOURCE:
Just purchased a refurbished optima ep716 projector won't synch-keeps rolling through search mode - I have it connected using the SCART setting.
Reduce the screen resolution of your computer monitor to 800 x 600 and check. Let us know the result.
Optoma is a SVGA projector. i.e. the maximum resolution supported by your projector is 800 x 600.
Sep 26, 2011 | Optoma EP716 Multimedia Projector
I have an Optoma EP716 projector. It has run for
either the lamp has/is going to expire, or the ballast is bad. if the lamp has bulges or black spots on the inside, replace the lamp and clean out your projector with canned air. too much dust keeps in the heat and makes a 2000 hour lamp go in 1100 hours.
Oct 22, 2009 | Optoma EP716 Multimedia Projector
My optoma EP716 projector will not power up
if there are no leds lit, replace the internal power supply.
Oct 21, 2009 | Optoma EP716 Multimedia Projector
EP716 Optoma Projector Fuse
There is no fuse. I took my EP 716 apart to find out why it died. I found a resistor had blown on the power board made by the Tiwan co. Quazarpower.
Dec 11, 2008 | Optoma EP716 Multimedia Projector
Power for optoma ep 716
TAKE TO THE AUTHORIZED SERVICE CENTER OF OPTOMA
WANT ADDRESS goTHROUGH WWW.OPTOMA.COM
Nov 11, 2008 | Optoma EP716 Multimedia Projector
Optoma ep716
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Nov 09, 2008 | Optoma EP716 Multimedia Projector
Optoma EP721 - reverse image
Go to menu, select Projection and choose your desired projection scheme (Desktop, ceiling mounted, behind the screen, etc.)
Jun 03, 2008 | Toshiba TDP S3 Multimedia Projector
My optoma ep716 is unable to communicate with my laptop
Hi there
Right click on your desktop and go to properties , then go to settings and check if your resolution matches that of your Projector's i.e. - 800x600 for SVGA or 1024x768 for XGA
Also check in the advanced settings if your secondary screen is activated.
Then hold down the Fn ( Function button - located just left of you space bar at the bottom row of buttons ) and press in your F-row buttons the one with a screen or two screens - at the same time.
This pushes the siganl to the Projector if it doesn't pick it up automatically.
Apr 17, 2008 | Optoma EP716 Multimedia Projector
Optoma EP716 source detection
It sounds like your module that controls the menu and the "cycling through" may not be in sync or may needs to be replaced. I had times have had to make sure the Optoma EP716 had to be first plugged in and "on" before the PC can communicate with it. Once the Optoma is "ON", then turn your PC/Notebook on. If there is no connection via USB, "S" cable and/or your VGA (be sure your PC/Notebook is set to have the external VGA "active"). Let me know if this works or not. Then we can try to move forward with other options for troubleshooting. BTW...how long have you had this multimedia and how many hours of use does it have?...JGUAM
Oct 21, 2007 | Optoma EP716 Multimedia Projector
1,661 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
