WRG PHX-1000 CPU
How can this cpu be reset to eliminate the tamper error
5 Suggested Answers
map9966
  • 2351 Answers
SOURCE: Error Message on 1st page boot up
Hi Chris,
Reset the bios jumper on the board. Use your manual, go to the bottom of page 9. Please unplug the power cord from the PC.
Clear the cmos/ bios & remove the bios battery as well. (You may use a small flat tip screw driver to help lift the battery out). If you have a voltage meter check the battery for 3volts DC. (If you have a voltage meter suggest you check the battery for 3volts DC while its out).
Re-place the bios battery & reset the bios jumper back to Normal. Re-connect the power cord to the PC. Boot the system & enter the bios menu. Adjust all your setting as needed.
(DO Not over-clock anything)!
If you still receive an error message your only other option would be to flash the bios. Even if you have the latest bios software already installed. The current bios software may be corrupt.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=537&CategoryID=1&DetailName=Bios&MenuID=48&LanID=0
Good luck Chris!
Mike
Posted on Nov 08, 2008
Dipu007
  • 2110 Answers
SOURCE: BIOS error - CPU is unworkable or has been changed
try to reset cmos by removing CMOS battery from motherboard and reinsert again...
Posted on Dec 12, 2008
txkjun
  • 409 Answers
SOURCE: I replaced my cpu, and received a unknown cpu
Reinstall all *********** board drivers.
Posted on Feb 28, 2010
  • 80 Answers
SOURCE: error: "Intel CPU uCode Loading Error" - "Press F1
This could have been a RAM issue or a BIOS issue. Check your RAM first and reset your CMOS. If possible upgrade your BIOS version from the manufacturers website. but be very careful if you do so. a wrong move may spoil your Board completely.
Posted on Nov 30, 2011
Jaguar s type cd changer
It may be a coincidence so I would reset the CPU by using a code reader to eliminate that possibility.
Mar 08, 2014 | Cars & Trucks
Error poweredge system R510
Reset bios, test with a different power supply, ensure all cables connected securely to the CPU FAN header, and then conatact DELL support.
Oct 10, 2013 | Dell PE2800 Server
Dell Optiplex 330,won't boot memory parity error, tried new bios battery, new ram stick, still won't boot,actually had two at same time the other I ran a advanced diagnostic test said hard driv
I found this
Customer's Optiplex 330 did the same thing today; no beep codes (due to lack of on board speaker). Solid/orange light on front of case indicates board or cpu. I isolated every component not soldered down (RAM, HDD, Optical, etc). Considering all the fans and lights on the MoBo were functioning, and no physical damage to the CPU was apparent, and the BSOD presented the "memory parity error; system halted" (meaning it's memory, graphics memory, or cpu and we've eliminated possibly CPU and RAM) my conclusion is that the problem resides in Graphics memory failure. Considering the error message is very vague and generally insists "motherboard", the gpu in an optiplex 330 is integrated ON the board, lumping it all together.
and general memory parity fail information
memory parity error fix Google Search
Nov 22, 2017 | IBM ThinkCentre Computers & Internet
(1)cpu fan error (2)chassis intruded (3)fatal error.....system halted
The reason for this error is Overheat! Please replace the CPU Fan with a new one and add additional Fan for the CPU Cabinet in order to cool the CPU. Then, reset the BIOS to default value by pressing the F2 Key or Delete Key at the Startup and select Load Optmized Defaults or Load Fail Safe Defaults option. This should resolve the issue.
Mar 02, 2011 | Computers & Internet
CPU NOT DETECTING ERROR CODE FF
If you are having trouble booting the system and getting a screen try the following multi-step procedure. Power off your system first before completing any of the following tips.
1) Check CMOS clear jumper JP1 (JBAT1 on some systems). Set for CLEAR for 5 seconds, then move back.
2) Check CPU host clock jumpers (if any) are properly set. Note: does not control memory bus.
3) Check your power supply. Should be 110/115v for North America.
4) Unplug all data cables for IDE and FDD from the motherboard.
5) Unplug all power supply cables attaching to your IDE and FDD drives.
6) Remove all cards and devices EXCEPT for video, RAM, CPU, CPU heatsink/FAN.
7) Move memory into a different bank, if available.
8)Unplug the CPU and reattach.
9) Ensure your CPU heatsink/FAN is attached properly to the CPU.
10) If you use a variable RPM fan ensure its set for full speed.
11) Retest.
12) If 1-11 do not help power off and test the motherboard outside the computer case to eliminate a case/motherboard power short.
13) Retest. If the board now works check for case problems. If the system still is not working continue…
14) You may have a possible hardware problem. Any device in the system may be a possible culprit. Use process of elimination to determine the cause. Swap out as many components as possible starting with RAM, CPU, POWER SUPPLY, VIDEO CARD (if present) and/or MOTHERBOARD.
Jul 30, 2009 | Mercury P4VM800M7 Motherboard
Dec 12, 2008 | Abit KV7-V Motherboard
Fan error
You mite not want to reset this. This could be telling you that your fan is faulty/Dieing. If so then if it doesn't turn off your comp, your CPU will fry from the heat. Try replaceing your CPU fan within your computer. "Cool Master" is a good brand. you can find them at any Fry's Electronics Store.
Oct 05, 2008 | Averatec Sotec 3200 Series Fan with...
Aopen ax34 tamper alarm--how to reset????
I don't think that board actually has a tamper alarm in the bios, password security yes but I saw no mention of a tamper alarm. Besides, a tamper alarm won't stop the pc from booting, it just lets you know that the case has been opened....sorry. I think you likely have a mainboard/ram issue.
First thing is to clear the bios. Here's how. Right beside the floppy connector, there is a jumper labeled 'JP14'. Please do the following
  1. Turn off the pc and remove the ac power cord.
  2. Remove the atx power connector from the mainboard (from power supply).
  3. Locate jp14 and move the jumper from pins 1 and 2 to pins 2 and 3. Wait 10 seconds.
  4. Put jp14 back to pins 1 and 2
  5. Reconnect the atx power connector.
Or you can just unplug it from the waal and remove the bios battery for an hour.
sa code
Try to fire it up again. If it still won't boot, then let me know the number of beeps it makes and the pattern to the beeps ie: one long beep then another long beep or 1 long beep then 2 short ones. These beep are actually telling you what the problem is.
Hope this helps! Post a comment and let me know how you make out.
Aug 24, 2008 | AOpen AX34-U Motherboard
Got a gateway essential 450 mhz tried to upgrade the cpu to 1000 mhz
just cuse p3 doesnt meen it will work maby wrong fsb also ok
Jan 28, 2008 | Gateway Essential 500 PC Desktop
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
