Dometic Quick Cool duo therm fan motor
Does this motor have a capasitor? Does the motor change out easily? Should I cut the wires and splice them or open the motor to disconnect the wires? Five wires: Black, brown, white, red, yellow
22yooper
  • 828 Answers
SOURCE: duo-therm quick cool
Your compressor is trying to restart after it shuts off which is causing a power draw down changing the sound of the fan speed change. Check voltage power supply and insure that the power supply cord is heavy enough to carry the necessary load.
Posted on Jun 28, 2008
  • 143 Answers
SOURCE: CHANGING OUT A FAN MOTOR
The black and white wires get 220 from the contactor. The brown and brown/white go to the capacitor. I do hope you bought a matching capacitor to go with the new motor. They don't cost much and make the hook-up way easier.
Posted on Jul 25, 2008
  • 99 Answers
SOURCE: Dometic Quick Cool Duo Therm Model 59516.601 runs
Hi; How old is the unit. Sometimes the condensing coils get clogged and need to be cleaned. Or the compressor is not in operation due to an electrical problem or the compressor is out due to a safety feature called a thermal overload. This protects the compressor from failure to a high heat or pressure situation. Alot of consumers run to the need freon theory before checking a few other things. Take Your time and be carefull .I You do not feel confident in Your trobbleshooting skills call a qualified tech...alpharome416...P.S. If You are going to take on this complex task please remove power before doing anything like removing covers or electrical panels!!!
Posted on Feb 20, 2010
jumptrout51
  • 3361 Answers
SOURCE: "i'm replacing my Rheem RBGC
There should be a wiring diagram on the side of the new motor.
The brown and the brown w/ white go to the new capacitor you should have bought with the motor.
The black and white go to your L1 & L2 power source. The remaining wires must be capped off.
Posted on Feb 25, 2010
Testimonial: "Thanks for the info. although a day late it confirmed what a friend had told me also. Didn't see any wiring diagram on the new motor."
shastalaker7
  • 1515 Answers
SOURCE: I just purchased an fse1028sf
Hi, this is a different wiring diagram then what you have . The 2 brown/wht wires are for the run cap only. Black and white are t-1 and t-2. They sold you a motor that takes its own run capacitor to run it with just both brown wires. Take the diagram from the new motor back along with your original. They will give you the right run cap to go with this motor. Yes, the red wire is power to fire your existing cap and old motor. You will need another cap to run this motor. Don't put the 2 brn/white striped wires on the old cap! They have to be alone on there own run cap. Go back to the parts house and they will show you very fast the wiring diagram and give you the cap. This is a very easy fix when they give you what you need. Keep me posted and ask them to give you what you need to run the motor. A 5 uf run cap perhaps?
Keep me posted.
Shastalaker7
Posted on May 03, 2010
Duo therm quick cool ac
if you can spin blade freely by hand change capacitor.
May 21, 2013 | Dometic Rooftop RV Air Conditioner
Replacement Fan Motor
Try Johnstonesupply.com. Use the information you provided above.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
How do I install a blower motor in a duo therm model 57915.622? What tools will I need?
ITS NOT EASY. YOU NEED A LONG SET OF ALLENS TO LOOSEN BLOWER WHEELS. THIS IS A  DUEL SHAFT MOTOR , BACK COIL NEEDS TO BE PULLED AWAY FROM MOUNT WITHOUT BENDING COPPER. MOTOR BOLTS 3 OF THEM HAVE TO BE REMOVED AND WHEN BOTH BLOWERS ARE REMOVED AND WIRES REMOVED THEN IT CAN BE REMOVED . THE PROBLEM IS THAT THE NEW MOTOR IF IT IS NOT FROM DUO THERM YOU WILL HAVE TO CUT SHAFT TO RIGHT SIZE AND WIRES MAY NOT BE SAME COLOR. IF IT IS SAME MOTOR FROM DUO THERM YOU CAN CUT WIRES AT OLD MOTOR AND WIRE NUT THEM COLOR BY COLOR.
Apr 19, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm Quick Cool A/C fan motor cycles from low to high
sounds like the motor is either wired incoirrectly and getting 1/2 power all the time or it is going to ground. check out the woiring real good and duse your ohhm meter to check for gounds.
Dec 20, 2008 | Dometic Rooftop RV Air Conditioner
Duo-therm quick cool
Jun 28, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
