Question about Music
Korg D1600 recorder repair - Music
Repairing Korg D-3200 Digital Recording Studio
If you have electronic expeerience, take it to a repair shop. You can cause more damage okiong around if you don't know what you're doing.
Past that, contact Korg customer service for the schematic and parts list. The part should be available from Korg directly of from Mouser
http://www.korg.com/us/support/contact
Korg Parts Parts Is Parts Guitar Parts Amplifier Parts Korg Keyboard Parts
Mouser Electronics Electronic Components Distributor
Korg Full Compass
Jul 15, 2016 | Korg D3200 Digital Studio
Hi, I have a korg D8 recorder and that i use pretty regularly.One day i switched it on and it was completely dead - no lights, nothing. I've tested the power supply (the one it was supplied with ) and...
Most common cause are failed connectors. Power inout jack failures are common. Beyond that, tracing out the power input for a failure would be in order.
Jul 16, 2011 | Korg D888 8 Track Recorder
Where can I buy a power board for a Sp200 Korg piano. ( KIP-2052)
Buying a power supply can be expensive and hard to get.
A better plan is to repair the board unless it is totally smoked. Most components are available through Digikey.com or Mouser,com,
Search google for "Korg repair parts" for comlete module if not repairable.
Jun 09, 2010 | Korg Pa800 Synthesizer
I have a korg i4s do not have the manual can you tell me how to record a backing track on it and is there any site I can go to to download the i4s manual
There's so many steps to describe here.
So, this is link to Reference User Manual :
http://www.manualslib.com/manual/686295/Korg-I4s.html
To record a backing track (Backing Sequence Mode), see the manual, start from page 19.
Mar 18, 2010 | Music
Wont save over 1 song and always turns off
Try asking here:http://www.korguksupport.co.uk/page.cfm?pageid=370. Hope this helps.
Aug 23, 2009 | Korg Mr1 Digital Mobile Recorder
Korg mr-1
While this is Mac-related, the information regarding the reset button is helpful and seemingly little-known. This comes from a Korg rep, by the way:
Did you first manually eject the drive from the Mac before disconnecting it by either moving the drive into the trash or using the Eject option from the Finder menu? If you try to exit USB mode without ejecting the drive on the computer first and then disconnecting the cable, this can cause the unit to lock up. Additionally, you’ll notice there is a tiny hole below the volume controls on the side of the unit. You can use a paperclip to push in a button within this hole to manually reset the recorder however this is only recommended in extreme circumstances. Look forward to hearing from you.
-Matt
Sep 02, 2008 | Korg Mr1 Digital Mobile Recorder
Music Logo
14 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
