Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Screen Voltage I am getting random, faint, pencil lines, as well as thick shadows that stretch across the screen like when there is white lettering and a dark background (terrible description, I know). I have been told this has to do with the Screen Voltage. When I take the front cover off there is the black box on the front where you can adjust the colors and I was told you can adjust the voltage there to but there are no knobs to turn. Where else would they be. This is a Samsung HCN4226W.
  • Anonymous Nov 11, 2007
    I have this same problem. Did you adjust the screen voltage to get it resolved? How did you get the fron cover off. it almost looks like you have to loosen up the rear cover for the front to come off.
    Scholar:
  • 170 Answers
Check the crt's for the screen controls
Posted on Dec 03, 2007
Yea that is. The focus is the bottom three and the screen is the top three. Its looks like there is no way to turn the three screen ones. Also does adjusting the screen voltage sound like its the fix to my issue?
Posted on Sep 16, 2007
    Sergeant:
    Champion:
  • 375 Answers
Is the black box about 3inx3in insize and can you letters on it and may the words focus or screen if so thats it the pots are counter sunk and must be adjusted with an insulated screw driver ,if your not sure get a tech to do it for you.
Posted on Sep 13, 2007
SOURCE:
A small horizontal line going across the bottom.Now a horizontal shadow appeared above the line.Each day a new shadow appears & lighter then the rest.Now a thick box of silver/purple lines at bottom.
Seems like back-light fault. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 12, 2016 | Televison & Video
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
There is a faint line in the bottom half of my LG tv lcd screen
the projector is out of alignment making the bottom ghost. They are expensive to replace.
Jul 14, 2015 | LG Televison & Video
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
KP57WV700 - Blue Lines Across The Screen
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Sony KP-57WV700 57" Rear Projection HDTV
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
55 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
