Question about Swisher 44-Inch 12.5 HP Trailcutter #RTB12544
Replace engage cable
I need to replace the engage cable and I need instructions.
I need to replace the deck engagement cable.
Craftsman Mower Deck Engagement Cable install - YouTube
? 6:26
www.youtube.com/watch?v=q6cKjePhdqw
Jun 27, 2013 - Uploaded by redneckcomputergeak How-to install a cable engagement on a craftsman lawn tractor. Craftsman, Poulan, AYP, Husqvarna part 175067, 169676 Deckclutch cable with ... seat, but other than that the video was a HUGE help in replacing that cable.
Sep 25, 2015 | Garden
It doesn't crank the battery is fully charged
Check: the ground wiring, power to the starting relay, the solenoid, the starter???
Sep 19, 2015 | Cars & Trucks
How do I replace the PTO Drive Cable Instructions or exploded diagam
Mower Clutch Cable Replacement - Craftsman Riding ...
? 5:37
www.youtube.com/watch?v=pSXOBQojHgg
Aug 22, 2014 - Uploaded by RepairClinic.com All of the information in this clutch cable replacement video is ....Riding Mower Electric PTO Clutch Won't Engage When Hot Problem Fix ...
Aug 05, 2015 | Garden
How to replace an engaging cable on my Craftsman 15.5 hp Lawn Tractor
here is link for owners manual which has parts and wiring diagrams.
http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0060063.pdf
If you need the "clutch" cable, the part number is 169676 from the owners manual. The manual doesnt have replacement procedures for something like that, but it should be pretty intuitive on your machine.
Aug 06, 2014 | Craftsman Garden
Replace a starter relay solenoid
no i do not know where to download it from but its easy to do
there are two different starter solenoids and you will need to know this information before ordering a new one
so follow these instructions and it will be easier for you
DESCRIPTION
a solenoid is composed of copper coil windings
with a metal projectile inside
when a electrical current is passed through it it turns the metal projectile into a negative magnet and shoots it into what ever it need to move
(1) is pre engaged and is connected to your starter motor
and will take quiet a bit of knowledge and quiet a few tools to disconnect the starter solenoid from the starter motor
these are designed to make it harder for the diy mechanic to work on
so that you have to spend money in a work shop getting it repaired
most machines now days are fitted with this type of starter
(2) is a normal starter solenoid and stands alone
you will need to find this out before you replace it
and obtain the new starter solenoid from your local dealer
and make sure it is the right one for your (wet bike / jet ski)
these are designed for the home diy mechanic
and are very easy to replace
LOCATION
if it is a pre engaged type
from your main live battery terminal there will be a long red cable that goes direct to your starter solenoid that is attached to your starter motor
disconnect your main red cable and the two wires
undo your starter motor complete it will be easier to work on
may be dearer but easier to replace the whole unit
the non pre engaged type
your normal starter solenoid will be close to your battery normally in a rubber housing of some sort
the solenoid has two main live polls (one main cable goes to your battery with a label mark this with BATT)
(the second main cable goes to your starter motor with a label mark this with START)
and two wires coming from it (they go to your starter button)
and is placed between your battery and your starter motor
SOLUTION
make sure your battery is disconnected and both live and earth cables are undone and disconnected and remove the battery
your main RED live wire from your battery
follow it until it attaches to a block that block is your starter solenoid
disconnect the block by undoing both the nuts that hold the cable in place on the polls
disconnect the two wires
and replace in the same position as the original one
reconnect the cables and the wiring in reverse to the way you took them off
reconnect your battery
and start up
hope this info is ok
good luck
Jan 10, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
Two springs broke underneath the riding lawn mower 3800 and we don't know where to replace them at, they engage the gears.
First make sure you can still engage the blades.Many mowers use a cable attached to a spring to engage the blades.If that is one of the springs,you need a new cable.For the other I will need more information,like what kind of mower is it?How many blades?Another thing to look for is worn or torn holes that the springs attach to.
Jun 29, 2011 | Garden
How do I replace the clutch cable on my honda self propelled hrx217hxa push mower , the one that engages the rear wheel drive.
I fixed the drive cable just yesterday. If the model is exactly hrx217hxa with the serial number between MAGA–1000001 and 139999 as mine is, it can be quite involved to replace the cable if this is the first time, because honda wants to replace the "control arm" as well. You can find a detailed instruction to replace the drive cable from the following link.
http://www.lawnsite.com/showthread.php?t=281234
The part number that you need to order is 06225-VH7-305, which comes with a very brief instruction on how to replace based on the service manual (not the user manual). The above link will guide you to how to replace the cable, but since the transmission end of the cable changed, you need to replace the "control arm" as well. This requires to disengage the drive "belt", which is the first challenge. Once you disengage it, it is relatively straight forward to replace the "control arm" if you have the right tools (1/8" pin punch and a challen lock plier which are described in the instruction that came with the cable kit).
Engaging the drive belt back on is the biggest challenge in the whole process, unless you have the right tool to handle the powerful spring that pulls the whole transmission to give friction to the drive belt. I spent two hours to try to engage the belt without the right tool (probably you need a "brake spring tool"), and I finally did it.
The rest of the assembly process is straight forward if you memorize what you did for disassembly. The above link can help you as well.
I took pictures of every step, and am going to post it somewhere soon, but if you want to replace it soon, please send me a message if you need help.
Nov 02, 2009 | Garden
Need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Aug 06, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Clutch will not engage
Have you tried adjusting the clutch cable? It may need adjusting, since before the replacement the gears were engaging.
Jun 21, 2009 | 1999 Suzuki GSX-R 750 X
Swisher 44-Inch 12.5 HP Trailcutter #RTB12544 Logo
23 people viewed this question
Top Swisher Garden Experts
Tim Whalen
dannydoesita
ray gallant
Are you a Swisher Garden Expert? Answer questions, earn points and help others
