Question about Garden
How to change drive belt on mower
Self propel function not working. Belt feels tight, but is shiny.
    Master:
  • 969 Answers
Replace belt.
Posted on May 29, 2014
  • 11 Answers
SOURCE: SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Posted on Mar 15, 2009
landsend
  • 1066 Answers
SOURCE: Troy Bilt Self Propelled Lawnmower drive belt
belts usually come off for a few reasons.
They become loose...stretch or the tensioner moves,  Make sure that none of the tightening bolds are slipping.  You can dab them with a bit of paint.
when the pulleys are not in alignment or crooked or bent.  Eyeball the path from one pulley to another, also make sure the tensioner is in alignment and there are no other obstructions.
good, high quality belts are required, and they must be real drive belts...not regular v belts.  If there is a way to watch the belt in operation you can usually see what's going wrong.
On my lawnmower I had to grind some metal away where the belt went from the motor to the transmission.  Good luck
Posted on Apr 18, 2009
  • 109 Answers
SOURCE: My self propelled mower doesn't fully engauge
What usually causes this is called belt stretch, this happens due the weather and the heat from the engine
Posted on Apr 25, 2009
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
Posted on May 26, 2009
mickey813
  • 472 Answers
SOURCE: Self propelled mower no longer propells
SOUND LIKE THE TRANS IS WORE OUT
Posted on Oct 01, 2009
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
Selfpropelled portion stopped working, replaced broken belt,have correct p/n for new belt,belt is slack ,self propelled not working
There should be 3 pulleys one on the motor on top of the blade, one on the axle for the wheels and one that goes to your cable to engage that pully and tighten the belt, take the cover off that hides the axle and pull your handle for the self propell and see if its tighting, some mowers have a little adjuster to tighten the cable on the self propell handle or even on the cable itself, did you make sure to run the belt between the guides over the blade, let me know what you find so we can further help
May 15, 2016 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
SELF PROPEL NOT WORKING
usually john the belt will stretch and start slipping. if you take off the cover and see if the belt is still on the pulleys turn it a few times to see if it is tight if not replace the belt.
Apr 29, 2016 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Why won't my 22 in. Kohler Low Wheel Variable Speed Self-Propelled Gas Lawn Mower self propel anymore?
i would guess that the belt is'nt tight enough when engaged. when you press the drive bar on the handle it should make the belt really tight if not it will need replaced. sometimes the gears in the wheels will mess up. there are videos on you tube that describe that and also the belt.
Apr 22, 2017 | Garden
How to replace drive belt on Honda self propelled mower
Remove the plastic cover for the drive belt. Replace the belt.
Jul 08, 2013 | Garden
The mower will not self propell. could it be that the belt is worn out? Or do I have a bigger problem? If so what should I look for? Thanks, John
Hi john, yes your belt could be cracked and not tight enough to run the drive. Also check your cable adjustment to be sure it is right.
May 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Apr 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
