Question about Sport & Outdoor - Others
Easy camp Modena tent instructions
The tent poles are colour coded in red and green. There are three green and two red poles. How many pole subsections are there in each colour?
2 Suggested Answers
mcdugal2
  • 4 Answers
SOURCE: square tent with 2 types gazebo poles, varenda, 2 side windows
the 2 longest of the poles go in an x over the center of the tent and the 2 shorter ones go arch to the sides. http://www.wenzelco.com/details.aspx?NavID=412
shows a picture very similar to your tent. If you go to image 2 it shows it with out the fly. now if you got 2 sets of 4 poles, 2 long and 2 short, and one set is all aluminum, then I would go with the aluminum set. It is less likely to collapse in high winds.
Posted on May 04, 2010
I need instructions for 89034 17x15 moab
Instructions
  1. Select a flat camping area and clean the area of sticks and rocks. Remove the tent from the bag and spread out the tent body with the floor on the ground. Assemble the tent poles by connecting the attached sections at the ferrules. Set the poles on the ground and separate by size.
  2. Locate the three long sleeves on the tent body. One sleeve is horizontal over the screen room and the other two cross the main tent body to create an "X". Locate the three long poles and slide one through each sleeve. Place the corresponding pins in the end of the poles. The poles will flex and erect the tent body. This step is best attempted with two or more people.
  3. Attach the clips to the exposed sections of the tent poles. The clips are attached to the ten fabric and will add rigidity to the tent. Locate the next largest pole and insert it through the sleeve on the screen house. Locate the metal grommets where the screen room meets the main tent and place each end of the pole in a grommet.
  4. Locate the two smallest poles. These are for the side rooms. Insert one pole through each of the side room sleeves. Attach the ferrule of one steel pole to each end of the side room pole. Insert the corresponding pins in the end of the upright poles to support the side rooms.
  5. Pull on each end of the tent to ensure the floor is tight. Use a rock to pound stakes through the ground loops on the tent. Place the floor mat in front of the screen room door and use stakes to secure the mat to the ground.
  6. Place the fly on the tent and make adjustments until the shape of the fly matches the tent. The fly will only cover the top of the screen room and the entire body of the main tent. Locate the D-rings on the base of the tent and attach the fly hooks to the closest rings. This will tighten the fly to the tent body.
  7. Locate the guy ropes on the fly. Pull the ropes to the ground at an angle and pound stakes through the loops to anchor the tent to the ground.
Read more : http://www.ehow.com/how_8092535_directions-ridgeway-tent-kelty.html
Jul 23, 2015 | Baby Gear
Anybody got instructions for pro action 6 man tunnel tent please
Pro action are generally quite good, colour coded poles and holes on the tent for the poles.
Aug 23, 2014 | Camping, Backpacking & Hiking
Hi I'm ddesperately trying to find instructions for a tent we just bought which is a Cantera 9. Would you be able to provide this for me please?
I have never seen your tent but found these instructions online. Hope they help:
Erection / Pitching
This tent pitches inner first and uses the popular ring and pin method to locate the poles on both the inner and outer and takes two to erect. The poles are all colour coded making it very easy to identify which poles go in which sleeves. The inner uses six poles to hold up, three for the main living area and one each for the bedroom pods. Once all poles are threaded, its advisable that one person gets inside the inner tent and supports the main poles as they are located. Tip here and for most tents of this design, make sure the first pole you locate on the main living area is the pole on the bottom of the crossover at the top of the tent, this then takes the weight of the poles above making it easier to secure. Locate the main poles and then the bedroom pod poles using the ring and pin system. The inner tent will then require pegging down and this takes around twenty pegs to secure. Finally once the inner is secure the outer flysheet is pulled over the inner, tied on the main poles and then finally pegged. The final thing to do is to locate the two porch poles and secure with the ring and pins and then peg out the guy ropes.
http://www.365campingcaravanning.com/reviews_familytents_1.htm
Also perhaps this video will give you an idea of what it is supposed to look like when it\'s up. https://www.youtube.com/watch?v=7SyVVIXV7l0
Good Luck!
Jul 24, 2014 | Sport & Outdoor - Others
Tesco 6 Person Vis-a-Vis Tent Instructions
Whoever they employed to write the instructions should be shot or go back to kindergarten....how difficult can it be?
Anyway, this tent is relatively easy to put up IF you know how to do it...which the instructions are painfully inadequate. It (un)helpfully uses colour coding on black and white print out and not explaining which way around the longer/shorter poles should be. Actually, once the poles are in, the instructions are ok....but it is a major point and wastes a shtload of time.
There are 2 LONG (well, slightly longer) poles, with a yellow sticker on the end (which comes off after 1 use of the tent). Start on one side of the tent with 2 poles (one longer, one shorter). Slide the long pole into the inner rib (ie towards the middle of the tent), then put in the shorter pole on the outside rib (i.e.the furthest away from the middle). You do need some grunt to force these into place, but at least they go (they won't if you put the wrong pole in the wrong slot). Then do the other side of the tent, longer first (inside), shorter second (outside). Then just pin everything else together like the instructions show.
The tent is ok, just ok, not great, not terrible, although it is pretty terrible in the wind, but what do you expect for 60 quid.
Jun 24, 2012 | Sport & Outdoor - Others
No instructions giving to erect our tent 6 man regatta hyperdome model no 927/5887
I bought one of these yeaterday. The instructions - for what they are worth are sewn inside the carry bag. So I decided to put it up today. Not as easy as i would have thought, but then this is my first tent of this size. ( saw a nice Outwell Montana 4 in Millets for 225.00 which would have been my tent of choice). But at half price in Argos I couldn't argue that one.
So to put it up.....
lay out the fly sheet in the approximate final position. put poles in as per instructions ..blue to back red to middle and blue to front.. across the tent. ( the pole guides are all colour coded.) Make sure poles are in pins at the base of fly sheet (bending gently to attach). these are attached by the black elastic straps.put in porch pole, put in front to back poles left and right.
Anchor back of tent temporarily with pegs. Lift from porch forward to lift tent. Temporarily peg base of poles, straighten out so that the straps inside tent are approximately perpendicular to each other. Move poles to tension flysheet and tighten anchor points on flysheet using straps buckles to pull flysheet down as far as possible ( to help prevent draughts)., anchor guy lines when happy with final position.
Put up inside ground sheet and attach to points on inside of flysheet. put up rooms starting with the rear yellow hook and work around to front red hook.
These instructions were not specifically provided but this was our first try and probably could be improved on. It requires 2 people for speed if nothing else.
Enjoy
Jul 31, 2011 | Sport & Outdoor - Others
Need instruction manual for the Ridgeway Moab Model 89034. 4 room tent
I borrowed one of these and got most of the job done. Here's what I ended up doing:
At a site with good drainage, a little uphill, stake down the floor of the tent
Longest two poles go through the twin sleeves in the center/top. They are color coded red and yellow
These two poles are anchored at the base by the center color coded ring_peg
The tube ends of the fiberglass poles. Fit over these pegs.
The slightly shprter fiberglass poles go trhough the two blue sleeves.
These poles get anchored on one end by a yellow ring peg and on the other by a red ring peg. They hold the vented windows up.
The arch shaped pole is threaded through a black sleeve atop the entrance to the. Tent.
The arch is anchored on either side by a red ring peg on one end and a yellow peg on the other.
Stake the lines from the screen windows outwards from the tent
Spread the tarp over the top and stake the corners to shelter the screened top from rain
Aug 23, 2010 | Sport & Outdoor - Others
How to put up a tent- ozark trails 16x12
I have this tent and have successfully put it up a few times. It's a big tent but it's frustrating to put up sometimes. Plan on having several people to help you. I find that it greatly helps if there are a total of 3-4 of you.
The poles are color coded. The center support are red rods. The two side supports are blue with the graphite looking rod that goes through the tent.
Spread the tent out on the ground and try to square it up and make it even. Run the center pole through the top and connect to the curved pieces which then connect to red dot poles on the side. Hoist the whole thing up. Have two people hold those poles for a while.
Get the bue poles into the black couplings and put the graphite looking rod through the tent. It will be a little tight. Hoist the blue poles into position. The bottom of the blue dot poles should be about two feet from the center. They extend outwards at about a 30 degree angle. Keep your center people holding the center poles and let the two blue dot pole section extend outwards. You'll start to see a tent shape. Your center holder people may need to keep and eye on the poles.
Now, start trying to get some stakes in. Work the corners. Once those are in and things start getting tight, it should start to hold on its own. Work all the stakes in and make adjustments to all the poles as necessary.
Extend the red dot poles up until the roof is at the proper height. I tend to do this last.
The fly basic basically clips on into holes on the blue dot poles.
It's kind of a pain to set up but its a big tent and works well once it is up. Good luck.
I took a ton of pictures after I got it up the first time. As I took it down, I shot the pictures. Then, I reverse the order and printed them to a book and now sort of use that as my manual.
Have fun.
May 20, 2010 | Computers & Internet
Square tent with 2 types gazebo poles, varenda, 2 side windows
May 04, 2010 | Wenzel 18'x10' Sycamore 3 Room Tent
I have a greatland tent item #15710. This is a two room tent (not dome) with a screened porch. The poles have numbers and some numbers are blue and some red. I cannot identify whether the numbers go in...
I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
Jul 21, 2009 | Sport & Outdoor - Others
No instructions on how to set up 3-bedroom Coleman tent.
First, I would try Coleman.com and see if they can send you a manual or direct you on their website.
Assuming the picture is the tent I can help (and even if it isn't, these are basic setup steps). Peg the tent down. Lay it out and pick about six spots to peg it down.
Next, get the two or three longest poles. These are the support poles. Run them diagonally or maybe side to side through the pole sleeves on the top of the tent. Once all the way through, put one end in the hole (or possibly in the pin) depending on if you poles have points or holes in the end. You'll then bend the pole, raising a portion of the tent to make the other end of the pole fit. Look for hooks to hold the tent poles to the poles. Do the same for the other pole/s. And it doesn't matter which pole goes together first.
Once you have the two or three longest ones in, the rest is extra. From the looks of it, you may have one pole running from the door area to the rear. If there is one, it's usually slid into a pouch and tied with a plastic string at the top of the tent to the other poles.
Other poles, if they are there are for side support or rain cover support.
Figure out which way the rain cover goes, then attach the bungie to the pole at the base of the pole. It should have some type of hook. Once the cover is on, it may take a pole underneath it. If so, there will be a small pocket or pouch for the pole.
Don't worry about the strings and extra stuff. (Unless you're expecting monster winds). You should have extra pegs, strings and maybe a pole or two. As long as you get the main two or three support poles up, you're solid. Good luck
Jun 06, 2009 | Coleman Family Dome 9271A141 Tent
Sport & Outdoor - Others Logo
94 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
