Question about Philips HTS-3555 System
Code dvd How can I play usb without remote control?
Dvd dolby
generally auto plays without remote
if there is interactive menu then its a problem.
get another remote
Aug 05, 2014 | LG Electronics - DP132 Multi-Format DVD...
X-10 Universal Remote UR19A DVD code search
If there is no DVD button on the remote then it will never operate any DVD player. If you want to control all the components of your audio system without the remote ever getting obsolete when you change to newer equipment then check out a Logitech remote. It's more expensive that ordinary remotes, but you program it online at their web site. If you ever change a component brand you simply go back to the web site, enter the new information and your remote gets reprogrammed with the USB cable that comes with it.
Feb 20, 2014 | X10 Remote Control UR19A POWERHOUSE...
Can you play dvd without remote hitachi tv with built in dvd L26D204
No. You can do it without its remote control. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the sites by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Feb 09, 2014 | Hitachi Televison & Video
Lost remote control of my lg dp122 and now i dont know if i can play movies
get a logitect universal remote and set it up to the dvd player.
I know what you are asking and I don't think you will be able to move or select sub menus on movies without a remote.
or buy another remote
http://www.ebay.com.au/itm/like/261378869015?hlpht=true&ops=true&viphx=1&lpid=94
Jan 26, 2014 | LG DP122 DVD Player, Multi Format...
Sony avchd hdmi ddp-s360 no remote
Without a remote control, you can't select its inputs. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. If you wish to get more details about this, try the sites linked here. It has set-up code list, and set-up procedure to many popular brand universal remote controls. If you wish to get more codes and other details. It has setup code list, and setup procedure to many popular brand remote controls.
http://electro-medical.blogspot.com/
Dec 31, 2013 | Televison & Video
My remote control will not work at all help? I went a long time without using my dvd player and the remote use to work just fine however i tried putting in new batteries ive went online to get codes for...
Check the leads of the remote where the batteries are inserted. Sometimes the leads corrode that causes a non-contact. Scratch it using a smooth sandpaper or even a utility knife to erase the corroded part.
Hope it will work.
Thanks for using fixya...
Jan 16, 2011 | Durabrand DVD-1002 DVD Player
Lost remote control. Cann I play dvd without it?
As long as you have a play button on you dvd player you shouldn't have any issues playing the main movie, you may not be able to navigate to different menu options from with on the dvd it's self.
You may want to look into obtaining a universal remote you can pick on up at your local electronics store and are fairly cheap.
Sep 16, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Jsi js4110
The only operations available on the JSI JS4110 without a remote are play, pause, stop, and eject. Since this DVD player "remembers" position of the movie, a different DVD would have to be inserted and played to start that movie over from the beginning. As for fast-forward, this is only available with the remote.
May 13, 2008 | Philips PM3S Remote Control
Using DVD player without remote
yes when you get to the dvd menu press play
Nov 21, 2006 | Sony DVP-NS315 DVD Player
Philips HTS-3555 System Logo
19 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
