Question about Garden
Suffolk punch Kawasaki FJ100D starts, runs for about 30seconds, cuts out. Wait aprox 3 minutes restart doesd the same. Fuel systems seems OK.????
  • 3 Answers
SOURCE: maintenace Manual for Suffolk Punch petrol-driven Lawnmower
Have you checked with the company that makes the mower for the manual? Hae you tried searching the internet to see if you find the manual there?
Posted on Dec 09, 2008
paulrelliott
  • 69 Answers
SOURCE: I have a suffolk punch 14s the engine cuts out
try repacing the fuel filter it sound's like not enough petrol is gettng up to th rail for high rev's, could even be a weak pump but try the filter first & make sure the cover cap is sealed properly I use a bit of silicone or hermetite red as air can back into the system overnight if not sealed & you have to re-prime with the ignition key swithing on & off at sec intervals, actually try priming first with the ignotion key, turn till dash lights come on and hold for 4 sec's then turn off wait 4 sec's & repeat, you shoul hear the petrol pump buzzing each time, might just be air in the system or a leak & that will show it up!
Hope this helps !
Posted on Sep 23, 2009
  • 110 Answers
SOURCE: My mower is not cutting level. I have a new base
If the baseplate meets the cutting cylinder across the entire cutting width, it's adjusted properly.
Check that the front roller is level - it usually IS as simple as that.
If the roller has ben replaced with wheels, check that they are the same height.
Posted on Sep 24, 2009
  • 110 Answers
SOURCE: i cannot start my Suffolk punch 43s petrol mower,
As far as I can tell, there are no downloads available. I eventually gave up and bought a copy from a mower museum. You will need to know the approximate age, as several diferrent engines have been fitted.
If you have the old red engine, the choke lever should be at right angles to the line of the carb IE pointing straight back.
The newer green engines are usually marked, but of not, remove the air filter and look into the carb throat. When the choke flap is CLOSED, the choke is ON IE cold start position.
As soon as the engie starts, move the choke to approx 50%, then fully open after 30 seconds or so.
If in good order, these engines are a 1-pull start. Fit a new plug, then spray WD-40 or similar into the OPEN carb thoat. If there is no sign of life at all, you have a coil failure (or possibly a points problem if it's ancient).
Posted on Oct 03, 2009
mikehowy
  • 177 Answers
SOURCE: AM TRYING TO RESTORE A SUFFOLK PUNCH COLT LAWN
more info
Posted on Jun 07, 2010
What could cause intermittent engine stalling?
A bad MAP or MAF sensor could cause this type problem .
Mar 16, 2017 | 2007 Volkswagen Transporter 1.9
Qualcast Suffolk Punch 35s lawnmower running problems
There is a small idling mixture screw on the side of the carburettor.
As the engine is not well suited to the carb. it mainly runs on the idle setting!
As long as you are not leaving the choke on. This is a little tab on the top of the carb. You start with it set on C then soon set it on the middle position, and after about 3 mins turn it off.
Jul 12, 2010 | York Yankees Bedding MLB Comforter
Can't remember how to keep my Qualcast Suffolk running!
There is a video on u tube and a wed site the old lawnmowers club .
Jan 10, 2018 | Garden
I have a suffolk punch 14s the engine cuts out when I apply revs idle is ok only does when throttle is opened
Hope this helps !
Sep 23, 2009 | Garden
Please advise on where to puchase replacement parts for old Qualcast punch classic 30s lawn mowers
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Aug 30, 2009 | Garden
1998 ford explorer stalls when driving, have to wait 30 minutes
possible fuel pump. Try spraying starting fluid into breather while someone is cranking engine. if vehicle tries to run it is fuel problem. If not it could be an electrical componet overheating and cooling and restarting. Coils, relays, ecm.
Jul 30, 2009 | 1999 Ford Explorer
Webb Diplomat 350 Petrol Lawn Mower stops running 10 minutes
The 'DIPLOMAT' series of WEBBs is bad news, its NOT a WEBB! Webb were swallowed by qualcast-atco-suffolk, who dunped Webbs tooling, & dressed up punches & commodores in thin disguises, dumped the briggs & stratten engine for their own alloy job, & charged a rip off premium for the Webb decals!
The qualcast suffolk alloy engine suffers from a WIPAC electronic ignition unit. As it gets old, it fails, sometimes completely, sometimes as it warms up. Once cool, it works for a while again.
Not too hard to replace, but hard on the wallet, £69 genuine, £40 fake! On the whole its not too bad an engine if cared for & oil changed often. better to look on ebay for a cheap used HONDA engine & transplant! R-E-L-I-A-B-L-E !............I did! ( £35 honda gc series, 5,5hp! )
Jul 27, 2009 | Garden
Garden Logo
173 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
