Question about Frigidaire Heating & Cooling
Ac won't blow any air
  • Official Brand Answer
  • 4,342 Answers
Good Morning David - Here are some simple troubleshooting tips to help resolve this issue:
If the outside temperature or inside temperature is below 60 degrees, the unit may not run.
Confirm that the unit has power to it.
Check the power cord connection to the wall outlet is secure.
Make sure that the house circuit breaker has not tripped.
Make sure the unit is turned off, Press the TEST button, you will notice a click as the BUTTON pops out. Then press the RESET button. Again, you will notice a click as the button engages, now turn unit on. If the LCDI plug does not reset the cord may be damaged.
The "Cool" circuit has an automatic 3-minute compressor time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping and the fan will continue to run during this time.
If the unit has been turned off and on rapidly or if the thermostat was changed to a lower number and then immediately turned back to a higher number the compressor may not start. You must turn the unit off and wait a minimum of 3 minutes for the unit to equalize before restarting.
I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Posted on Jul 10, 2013
My engine light is on, my AC won't blow any cool
Need more information to assist.
Check your coolant level.
Sep 12, 2013 | Cars & Trucks
94 Buick Roadmaster AC fan blowing hot and won't shut off
If you have climate control it could be the main processor. Something could be shorting the blower relay to keep it on. You would also need to check and see if the system is still full of freon.
Jul 06, 2013 | Cars & Trucks
2008 kia optima a/c
have the ac check for gas leakage and proper amount of gas. Is the compressor clutch working and driving the compressor.. What you have is the fan is just circulating cabin air at ambient temperature. Best take it to an ac mechanic for full problem check.
May 22, 2013 | Heating & Cooling
I have a 1999 Caddac DeVille . The AC works fine during the summer but in the winter it won't blow out hot air unless I'm driving. I've let the car run in the morning to warm up but the inside...
your heater core is possibly stopped up if there has been a radiator leak and stop leak has been poured its definetly clogged or could be a faulty thermostat
Jan 07, 2013 | Cars & Trucks
My ac wont turn off and only blows at one speed
faulty resistor won't make it blow warm air.
sounds like the climate control is bad.
Sep 04, 2012 | 2003 Honda Accord
When I turn on the ac or the heater on my 1992 pontiac bonneville ssei supercharged it will now air to the windshield but when I change it to blow to me or my feet it won't blow any air. what coul
there is a paddle inside the sysem which moves to change the direction of the heat, i could be jammed or its actuator is broken or not getting pwer. if not it could be your switch is not working so the sigal to change position is not be received. first check all fuses are ok.
I hope this was useful.
Sep 02, 2012 | Cars & Trucks
MY AC blows hot, it wont take a charge. a shop told me it needs a compressor so put on a new one and still won't take a charge and blows hot air
Hello again. is your heater tap actually operating? its not stuck on hot is it? just check the tap actually moves when the hot cold selector is switched.
Jul 06, 2012 | Oldsmobile Cutlass Supreme Cars & Trucks
If my compressor wheel isn't spinning how do I know if it is the compressor or the ac clutch? System is charged but ac is blowing hot air
The question is: why isn't the compressor clutch turning
The compressor isn't likely seized,it may leak refrigerant,
but won't be what your asking.
The clutch can be jumped to test that
If okey, then you have to diagnose the entire
A/C Electrical System
How do you know it is properly charged,you put
refrigerant gauges on the system?
Jun 27, 2012 | 2006 Kia Sorento
Front ac not blowing
Sound like you have a failed fan motor assembly. Check for power to the fan motor connector.
Dec 20, 2011 | 2005 Dodge Caravan
Ac won't blow lights on dash says it's on no air
need more info ------------- year //make //model --------- sounds like a/c relay not energizing , which the ground side is controlled by the ecm or bcm . ---- possible bad relay // wiring // fuse// compressor
May 25, 2011 | Air Tools & Compressors
Heating & Cooling Logo
123 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
