Question about Watches
Cardinal Watch model X68402009E I everything worked fine, until I put a new battery in. After that my alarm quit working, any ideas why?
Everthing worked fine until I had to put a new battery in, then from there everything worked great except the alarm quit.
samd52
SOURCE: Cardinal Nite Light watch
Press and hold mode button, alarm time will flash. Press mode and reset buttons at the same time it will return you to regular time mode with seconds flashing. tap st/stp to set seconds. press rst/str minutes flash, press again hours flash. press set to exit to normal mode. the instructions I got with the watch were in chinese. whoever disigned this watch is a moron. I will never buy a cardinal watch again. why dont they put their instructions online like timex?
Posted on Sep 04, 2008
escapement
  • 2334 Answers
SOURCE: Timex IndiGlo Ironman Triathlon - bell stopped working
You have lost the coilspring wich connects the watch mechanics with the speaker integrated in watch caseback. This is why you do not hear any sound but still can see the icon.
Check the area where you made the battery replacement very carefully- you may find that tiny spring. Use the magnet if necessary.
If you can not find it, go to the nearest watchmakers shop and ask to supply the new coilspring.
Do not forget to rate, please.
Posted on Feb 03, 2009
escapement
  • 2334 Answers
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Posted on Feb 10, 2009
  • 4 Answers
SOURCE: beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
Posted on Jun 12, 2009
SOURCE: installed new battery and now all works except audible alarms....
You have the back on backward. The speaker is on the back plate. Rotate the back so that the circle DOES NOT match up with the battery. It'll work perfectly.
Posted on Oct 10, 2009
Hi, How to set the chime alarm off my cardinal watch WR100M. Thanks!
Try Googling (cardinal)(WR100M)(manual) without parens for instructions.
Aug 07, 2017 | The Watches
I just replaced the battery on my seiko. Watch is working fine EXCEPT the alarm will not ring. Help!
mcdevito75 here, By pressing the MODE button until you get to the alarm function and turn it to on or, set an alarm time for the alarm to go off.
Oct 11, 2010 | Seiko Coutura Chronograph Watch
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
New Battery but Alarm sound doesn't work
You will find an arrow head on the outside back of your watch where all the printing is. When you put this lid back on, this arrow needs to be aligned with a notch on the inside edge where the cover goes on. As you are looking at the watch from the back with the cover off this notch is in a northwesterly direction. If you doubt it then just hold the back on without popping it in all the way and hit your mode button to make sure that you hear the beeps again. If you do, then you've found the right spot.
Mar 16, 2009 | Timex Expedition 84601 Wristwatch
Citizen BL717459L - Alarm sound is too low
No, there is nothing wrong with the alarm in your watch.
The sound in all watches are generated by passing vibrations to the metal tweeter which is connected to the watch caseback inside the watch. As the surface of the watch is quite small, there is not efficient power to spred the vibrations over the caseback surface, hence low volume of the alarm. No wristwatch in the world is capable of loud alarm sound yet. This is something the scientists have to work with.
The plastic protector is definetly affecting the volume. Take it off and you will notice slightly better sound. This protector actually is ment to protect watch caseback from scratches prior to selling it to the customer and have no use after that. In fact it only collects the dirt and bacteria and can affect your skin as the caseback as well.
Another sound improvement can be the new battery if the original is underpowered. Alarm feature uses the most of the energy stored in battery and the power consumption is higher than all watch movement parts put together.
Rate me, please.
Mar 12, 2009 | Citizen BL717459L Watch
Citzen Aqualand 1997 Divers watch..Great condition!!
the alarm works by a spring rubing on the back of the base plate of the watch if this spring is bent or not in the right place the alarm will not work
Nov 02, 2008 | Citizen Aqualand Duplex JP104009E Wrist...
Dead watch
After putting the caseback back on, press all four buttons simultaneously to reset the watch. This worked for me.
Sep 22, 2008 | Timex Expedition 84601 Wristwatch
Casio G-Shock
Check out this YouTube video.
http://www.youtube.com/watch?v=ogCz2vjUKVg
Feb 19, 2008 | Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
