Question about Video Game Consoles & Games
Fix my ps2
The eye won't go all the way back and won't read discs at first it wouldn't spin but I got it to
    Problem Solver:
  • 15 Answers
Push it back first. maybe it'll help.
Posted on Jul 11, 2013
SOURCE: Slimline PS2 disc not spinning
my friend i have a ps2 that its cd does not rotate ( i open it completely ) and the lens is working the lens is producing a red ray and it is movinng up and down but just the cd motor doesnot rotate so i checked the smd fuses using my fluke dgital multimeter i found one that is open when i replace it the ps2 work perfectly fine for your information the smd fuses are marked ps1 ps2 ps3 ps4 etc
Posted on May 15, 2007
Cerfer39
  • 709 Answers
SOURCE: Disc won't spin. Disc doesn't show up in browser
You got a problem with the lasers data getting back to the Motherboard.
One of these could be your problem
  1. Laser lens is melted. Look at the lens with a magnifying glass to see if it or its supporting frame is melted. REplace the laser in this case.
  2. The ribbon Cable going from the Laser to the motherboard is damaged or loose.
  3. Your laser is burned out. Press the two interlock to override the door being open, to see if the laser even lights up. 2 switches, one at rear left corner, one behind the On/reset switch.
  4. Your Laser is dirty and needs cleaning look at it with a magnifying Glass to make sure you got it clean. Use Q-tip and window glass cleaner, not alcohol.
Posted on Nov 25, 2007
SOURCE: PS2 was dropped, now disc won't spin and can't be read.
I just looked at a friend's PS2. Same story, tripped over cord, unit fell to floor. Unit powers up and sys. config. screen comes on but the drive didn't seem to be spinning up. Opened the case and found that the shaft of the drive motor for the laser tray had popped out of it's centering retainer ( little black bushing/holder). With the top off the unit, looking at the unit from the front, on the right side in the rear corner you'll see the motor. The worm shaft (bronze colored rod) runs towards the front of the unit. Where it ends it should sit centered in a black plastic holder, if it's off to the side a little pressure will pop it back in. Put the cover back on, and power it up, you should hear the drive spinning up. If it does you should be set. Hope this helps.
Posted on Jun 02, 2009
SOURCE: the ps2 has trouble spinning and reading disc.
it means your playnstation lenses have a problem
Posted on Jun 15, 2009
sWatti
  • 188 Answers
SOURCE: Ps2 powers up, but disc is not spinning and
Following could be the reasons for not spinning any PS2 disc:
  • A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
WATCH this video to clean lens
  • An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
  • A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable.
No Spin At All If your spindle hub is NOT SPINNING AT ALL, NOT EVEN 1/2 OF A TURN, it may be bad or unplugged. A tell tale sign of it being unplugged is if you hit eject, the laser moves down the rail, and starts grinding because the PS2 keeps trying to move it down the rail even though it hit the end. There's a small switch on the spindle hub that tells the unit to stop pushing the laser because it's reached the end. Spindle hubs usually do not go bad by themselves, usually either the PS2 too a bad fall and it became bent [try spinning it by hand], or someone the cable out and put it in too many times [or incorrectly] and the silver contacts on the cable were detached.
Posted on Nov 29, 2009
PS2 Modchip and Laser Fix installation Failure ...
I bough ps2 with cracked after 3-4 days not working dvds are not read.
sometime it's working some dvds..
so plz solve my problem...
May 28, 2012 | Sony PlayStation 2 Slimline Console
PS2 Slim won't load games (won't load final fantasy x specifically)
Take the game out and see if the laser is towards the back. If so, pull the eye towards the spindle or where the hole of the game goes.....and clean the laser eye with a q tip soaked in alcohol.....
May 07, 2012 | Sony PlayStation 2 Slimline Console
Disk wont spin, but laser works
You need to put a small weight ontop of the disc drive and then it should work
Dec 04, 2011 | Sony PlayStation 2 Slimline Console
When cosole switched on it display loading & nothig else
It probably is not reading the disc. If it's a game the disc could be damaged, check it for any kind of rings on disc. Or the "eye" that the playstation reads the disc with could be dirty. If it's a burned DVD then alot of times the PS2 will not read those if the burned DVD is not formatted correctly.
Jun 17, 2011 | Sony PlayStation 2 (PS2) Console
I want to play duplicate dvds on my ps2 but i am not able to do what should i do can i do it at home
  1. If you have backed up a game for ps2, you're going to need a mod chip or swap magic for your ps2 so it can read the disc, so first things first, BUY A MODIFICATION TOOL!!!
  2. 2You should try using Swap Magic, because it's the easiest, and you won't need to modify your PlayStation too much.
  3. 3But if you use SWAP MAGIC, you will also need a special mod chip, SLIDE TOOL, or a FLIP TOP COVER, you can learn more about those on the swapmagic website
  4. 4Read directions on the installation of mod chip, and swap magic before you do anything (you don't want to mess up, or else your ps2 won't work properly).
  5. 5Install your modchip/flip top cover/slide tool. (This is important, because it allows the disc to be removed and "swapped" without the PlayStation knowing).
  6. 6Follow directions that came with your swap magic discs, and you're basically ready to go!
  7. 7HOW TO USE SWAP MAGIC,Note you must have Swap magic 3.6 to boot on slimline ps2 and you need to do a none solder modding(no soldering)
Purchase a flip top (recommended). Let's assume you have the flip top and a copied ps2 game
  1. 1Now Insert the swap magic disc into the ps2,
  2. 2Press power on button until screens comes up.
    • With option that says load cd open the top cover of the flip top.
    • And take out the cd when it stops spinning.
  3. 3Now insert your Copied game and click Load CD.
  4. 4its that easy
May 30, 2011 | Video Game Consoles & Games
DISK NOT SPINNIG AT ALL !
the stepper motor in yur ps2 has a either a wiring problem or it is disconnected.. please chec that.
Jul 07, 2009 | Sony PlayStation 2 Slimline Console
Ps 2 disc wont turn
I had this same issue with my PS2, honestly I think it was something to do with the laser eye reader that reads the disc, when it is dirty the disc won't even spin or attempt to read it.
you can either take an air compressor and when the ps2 is off, have the disc tray open and blow the dust out of it.
Or, i personally would take the ps2 apart and clean the diode itself with some rubbing alcohol. Just don't void your warranty or somehow break it.
This article will help you with disassembly: http://arstechnica.com/gaming/guides/2003/11/ps2-repair-guide.ars Hope this helps!
Mar 18, 2009 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 - Does not read CD
IT IS THE EYE. the eye th the little shiny piece that you can bairly see once the tray comes out.you might have put a disk in at a wrong position and scratched the eye. replacing it might be what to do, but i would check first.
Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
When I go to play a game on my ps2 and put the game in the ps2 eye prevents the disk from spinning I have the newer ps2 that is slim the eye that reads the disk keeps sliding up and the disk does not get...
Does this happen to all of your Discs? If you know someone who also has a PS2, try to run your discs first on that PS2...If they worked, then probably either the lens of your PS2 needs to be replaced, or it only needs cleaning. Or it is also possible that your disc isn't inserted on the disc tray properly...and by "inserted properly " on the tray I mean is to make sure that the 3 pins on the spinner of your PS2 are sticking out of the hole on the DVD and thus gripping the disc...
Aug 01, 2008 | Video Game Consoles & Games
Video Game Consoles & Games Logo
63 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
